Question about Dishwashers
What does the code A01 mean on indesit dishwasher, model ide 1005
1005
4 Suggested Answers
SOURCE: error code A01 on indesit model D73
I looked at other people's suggestions on the web and tipped the machine over to the right side at an angle of 45deg (making sure I had old towels on the kitchen floor.) Water came out from the bottom right-hand corner. When I started up the machine it worked again.
I am writing a letter of complaint to Indesit because in under 3 years I have had to call out the engineer 3 times. Twice the door dropped on it's hinges and just a week ago, when opening the door, the board with all the electronics came away.
This is the first time I have had a malfunction as such and was amazed that a list of error messages was not in the handbook!
I shall not be buying an Indesit again. I have had a Zanussi washer/dryer for 15 years at least. It has had a new door but is still going strong.
Posted on Mar 25, 2008
IFIXALL
  • 868 Answers
SOURCE: indesit IDE 1005 error code
Replace the control board
Posted on May 22, 2008
  • 70 Answers
SOURCE: my dishwasher is showing error
Hi, the interpretation for error code A10 is: A10 = fill solenoid valve triac closed/open circuit - check valve/ operation - machine drains until level switch resets + 30"
Now, to try and solve the problem yourself: Turn off the water supply to the dishwasher & remove the hose, Run the machine for several minutes in a normal position. Turn the machine off, reconnect the fill hose, turn the water back on then turn the machine back on.
If this doesn't solve the problem, then you'll need to call a service person.
Posted on Jun 12, 2011
What is Error A01 ?
this is a float switch fault
Sep 08, 2014 | Indesit Dishwashers
My dishwasher is showing error code a10 model ide 1005
Jun 12, 2011 | Dishwashers
A05 code
Indesit Error Messages and Error Codes Indesit Dishwashers
  • F10 - Fill or empty time out. Check that the hoses are not kinked, that the taps are on or whether the drain pump or hose is blocked.
  • F11 - Heater timed out. The heater has not reached the required level. Book a service engineer.
  • F20 - Temperature under range. Book a service engineer. .
  • F21 - Temperature over range. Book a service engineer.
Fault codes for Indesit LCD Dishwasher Models
  • A01 - Float switch operated - Book a service engineer.
  • A02 - Open/Short circuit heater relay - Book a service engineer.
  • A03 - Short circuit on thermistor - Book a service engineer.
  • A04 - Unable to reach or sense temperature within 70 minutes - Book service engineer.
  • A05 - Pressure switch has not been reset - Book a service engineer.
  • A07 - Open/Short circuit wash motor triac - Book a service engineer.
  • A08 - Open/Short circuit auxiliary wash motor triac - Book a service engineer.
  • A09 - Open/Short circuit with main wash traic - Book a service engineer.
  • A10 - Open/Short circuit fill valve traic - Book a service engineer.
  • A11 - Half load valve traic or alternating motor action - Book a service engineer.
  • A12 - Open circuit heater rely - Book a service engineer.
  • A13 - Open/Short circuit dispenser traic - Book a service engineer.
  • A14 - Drain hose too low causing syphoning. Check drain hose and re-adjust.
  • H20 - Check tap and pressure of incoming water.
_uacct = "UA-1207243-4";urchinTracker();
Sep 14, 2008 | Indesit 24 in. DE73 Evolution...
Indesit IDE 1005 error code
May 22, 2008 | Dishwashers
Error code A01 on indesit model D73
Mar 24, 2008 | Dishwashers
De73 evo
A01 keeps coming up. Can you help
Nov 07, 2007 | Indesit 24 in. DE73 Evolution...
Error code AO1
Error message A01 means -Acqua stop operated due to a leak or overfill. Check if there is still water in the machine after it stop pumping. In case you still have water - your problem is with the pump or with a blockage drain line. If there is no water in the machin, it might be a water level sensor issue - stuck physically in the high level position or become defective. Try to reduced the water presure and leveled it up by the water entrance tap to the machine, it might solve your problem. Goog luck !!
Jun 27, 2006 | Indesit 24 in. DE73 Evolution...
Dishwashers Logo
77 people viewed this question
Top Dishwashers Experts
