Only a small amount of water will flow through the cold water valve on the washing machine. When I switched the hoses cold water will go through the hot water valve on the washing machine therefore it is not a problem with the hoses or the taps - it is something wrong with the ability of the water to get through the cold valve into the machine. I have also checked the filters on the machine and they are clean and the hoses were not blocked. A small amount of water does flow through into the machine via the cold valve, but just a very slow trickle and the hot valve is completely normal. Any help would be rgeatly appreciated!
either the valveis faulty or the dispenser box is blocked, remove the internal hose from the valve anf see if you have full pressure at that point if yes box is blocked. Regards Advisor
I have inherited a Hoover Nextra HNF6147 with no operating instructions. Need to know which setting...
(More)
I have inherited a Hoover Nextra HNF6147 with no operating instructions. Need to know which setting in best for my requirements. Thank you, Donna
i have a Hoover washing machine heavy duty 10.1 kg Giant Capacity Plus with same problem, cold water...
(More)
i have a Hoover washing machine heavy duty 10.1 kg Giant Capacity Plus with same problem, cold water doesn flow but warm water yes. Please help
The springs on the drum doors have now both gone. It has been difficult to open for a while. Now I...
(More)
The springs on the drum doors have now both gone. It has been difficult to open for a while. Now I can't close it as if I press the grey knob the door just presses into the drum. I think both springs need to be replaced. How do I replace the springs and what are the part numbers. Thank you, Gill from Scotland.
