Question about Dayton (4F424A) Ceiling Fan
Need wiring diagram for dayton ceiling fan 4f424a
Need wiring diagram for connections between the Fan Control reverse/forward switch and the motor
jfpogie
  • 104 Answers
SOURCE: dayton 24 inch two speed fan
yes, it will work and not damage your motor.
Posted on Jan 28, 2008
  • 87 Answers
SOURCE: How to wire a 1dgv1 speed control to a 1tdu8
You will wire this just like a single pole light switch, take your power from your panel (black) to one of the pigtails or set screws and then take another black wire leaving the speed controler to your blower motor. Take the common/white wire directly to the blower, polarity sould not matter which leads you connect them to in the blower.
Posted on Oct 09, 2009
MOTORWIZJ
  • 1363 Answers
SOURCE: I have a Dayton 36
GRAINGER.COM THEY HAVE A TECH LINE, BUT ON THE MOTOR LABEL IT SHOULD HAVE THE WIRING DIAGRAM .. GOOD LUCK AND I'FN I WAS ANY HELP PRAISE IS APPRECIATED .. SO VOTE JAY MOTORWIZJ
Posted on May 28, 2010
SOURCE: Dayton Attic fan running backwards
If the fan blade is on properly, then you probably have the wiring reversed. If you connect a line from motor to red box wire, and other motor line to black box wire, it will turn clockwise. If you reverse the wiring it will turn counter-clockwise ;-)
Posted on Jun 01, 2010
SOURCE: wiring diagram for dayton ac electric motor
i need wiring diagram for a dayton electric motor 4mb22
Posted on Oct 21, 2010
Could sure use a wiring diagram for a Dayton 5k961c motor.
Electric Motors: dayton motor, Electric motor repair Kansas ...
en.allexperts.com > Industry > Machine Tools > Electric Motors
Aug 24, 2010 - Electric motor repair Kansas City MEAR Service 816-650-4030: Tyler, it is ... i have a dayton motor with no wiring diagram. i need a wiring diagram for a dayton motor with a model # 5k961c and a reference # r67745ck733 ... 1992 Dodge Dynasty Blower Motor Wiring Diagram · 1998 Ford Escort Blower ...
wiring diagram (ideally color) for Dayton belt drive motor Model ...
www.electro-tech-online.com > ... > General Electronics Chat
Apr 29, 2012 - 9 posts - ‎3 authors
There is a sticker on motor indicating wiring, but seems only an. ... This is a motor for vented - big blade ceiling fan -- a belt driven Dayton Motor ...
DAYTON 1/4 HP Condenser Fan Motor,Permanent Split ...
https://www.grainger.com/.../DAYTON-1-4-HP-Condens...
W. W. Grainger
Rating: 3.8 - ‎6 reviews
Shop DAYTON 1/4 HP Condenser Fan Motor,Permanent Split Capacitor,1075 Nameplate RPM,208-230 ... Typical HVAC Condenser Fan Motor Wiring Diagram ...
DAYTON 1/3 HP Direct Drive Blower Motor, Permanent Split ...
https://www.grainger.com/.../DAYTON-1-3-HP-Direct-D...
W. W. Grainger
Jan 23, 2016 | Dayton Dryers
WIRING DIAGRAM FOR A DAYTON EXH. FAN FOR A GREENHOUSE. tHE FAN GOES TO A THERMOSTAT THEN TO ELECTEICAL BOX
So far, I cannot locate a wiring diagram for an installation. However, this is a single phase "shaded pole" motor.
For a single speed, shaded pole motor, there are only two power wires. For a dual speed motor, a third wire provides a second speed. One wire will be one side of the motor coil(s)...connected to the white power wire. The other wires are the opposite side of one or two motor coils, connected to the black power wire or through a thermostat. A thermostat is simply a temperature operated switch. An additional wire may (should) be a green "grounding" wire.
Specification Sheet from Grainger.
http://www.grainger.com/product/DAYTON-Exhaust-Fan-4C361
Installation manual.
ftp://207.99.53.68/array1/pacs/AS-BUILT/D1112-50-GLOBAL-Terminal&Container(15KV_ARC-RES-Swgr_Outdoor)/D1112-50-O&M/D1112-50%20Global/BM%20%23%20549%20Exhaust%20Fan.d20100210-u113426.pdf
Mar 23, 2014 | Dryers
Lights come on at random .has a remote how to fix ?
The fan remote control receiver used in the Hunter 25730 model fan (see picture) is not available from Hunter. Remove the fan from the ceiling. Remove the receiver and take it to recycling. It can be replaced using a readily available and inexpensive replacement universal remote and receiver controller. There are limitations though. The Hunter receiver provided fan reversing functions. The universal controllers do not. You therefore have two options.
Option 1: The universal receiver can be installed such that the fan direction is fixed, either up or down, all other functions operate normally.
Option 2: A reversing switch can be purchased from Radio Shack for about $4 and installed in the fan. This does require cutting a square hole and drilling two bolt or rivet holes in the side of the cylindrical housing which previously housed the Hunter receiver. I'd suggest the Radio Shack DPDT slide switch part number 275-403.
Refer to the wiring diagrams and connector pinout diagram for connections. Please note that the connector pinout diagram is the connector that is soldered to the circuit board as shown in the photo of the Hunter receiver. If your motor wire colors are different then with the connector unplugged from the receiver use a multimeter to probe all the motor wires in order to identify two pairs of wires that indicate approximately 70 ohms each pair. These will be the motor windings. 6b0a1409-5a20-4efe-a059-c600652e9512.jpg 5da8e4ef-1b54-40d0-a8a4-21d4608b1d23.jpg 9fc8772d-3ac3-41b7-aa55-78ccc6e5ea00.jpg 0759e340-6464-4c4b-90f5-6d9926e74e42.jpg
Jan 23, 2014 | Hunter Ceiling Fan Light Remote Control
I need a wiring diagram for a dayton 120/230 v capacity start motor model 6k157 or equivalent
I have dayton motor 3/4 hp 120-240v it has 3 contacts 1-2& 4 it has 5 wires 2 white 2 red 1 blue. I want forward rotation! what do I do?
Jan 14, 2011 | Dayton Permanent Split Capacitor Motor Fan
Ceiling fan capacitor hook up problem. I have a 3 speed fan. 4 switch. A 3 wire capacitor - CBB61. Kids lost wiring diagram. Any which way I try to wire it up only one of the speeds works. Any wiring...
The reverse switch on my Hampton Bay ceiling fan didn't work. I cut the 6 wires; 1 white, 1 gray, 2 pink, 2 yellow. Here's what I did. Removed reverse switch. Had 6 wires white, gray, 2 yellow, 2 pink. Connected gray to yellow, connected white to pink and fan runs fine. Is this OK? I do not need to reverse fan. It's been running for 1 hour now with no problems. Don S.
May 15, 2010 | Dryers
Need a basic diagram to wire a ceiling fan.
Depending on how your place is wired will dictate the solution here.
The light box in your ceiling should have two or three wires. Black and White, or Red, Black and White.
If you have two wires (one switch to control everything):
Black is power - hook this to the fan's power wire (and the fan's light wire if applicable)
White is neutral - hook this to the fan's neutral wire.
If you have three wires (two separate switches):
Red is power for the light - hook this to the fan's light wire if applicable
Black is for the fan - hook this to the fan's motor
Sep 18, 2009 | Hunter 52" Ceiling Fan With Light And...
Hunter ceiling fan-just installed -possible speed control problem
Sounds like the fan is defective. All internal wiring from the switch to the motor is factory installed. The fan has power going to it. Just to make sure, double check the wiring from the ceiling fixture to the fan.
Problem could be a faulty switch on the fan or faulty motor(bad winding for med. speed). Try reverse switch on the fan to operate the opposite direction and see if medium speed works. If medium does work in opposite direction, it pretty much points to a defective fan. In any case, unless you discover that the ceiling wires were reversed going into the fan, I'd say new fan to the returns dept.
Jul 21, 2009 | Hunter Ceiling Fan Control Switch
Hampton Bay ceiling fan - will not reverse
It sounds like the direction switch has a broken connection on the "reverse" side.  Should be an easy fix (but you might need a soldering iron).
Dec 07, 2008 | Kitchen Appliances - Others
First see if the switch has a reverse position. Sometimes you turn the fan assembly in the frame, sometimes you turn the whole frame around. Take the cover off the wiring compartment to see if there are instructions there. Also check on the name plate on the motor, there may be instructions there. Attic fans are usually engineered to blow out.
Aug 02, 2008 | Dayton (2C373) Fan
How to wire a remote control ceiling fan, without using remote.
If you don't want the to use the remote you don't have to, but you don't have enough wires to switch the upper light, the lower light, and the fan. You can, however, switch the upper and lower lights together if that's okay. In order to do that you'd connect the white from the ceiling box to the white (neutral) on the fan, then the green from the ceiling box to any green(ground) wires on the fan, then the black from the ceiling box to the black(motor) from the fan, then the red from the ceiling box to the blue and orange (lights) from the fan. I'm assuming that the black and red in the ceiling box are also in the switch box where the fan/light control switch is going. Those are the ones you'll connect to the controller.
Jul 05, 2008 | Hampton Bay 04383 Calibre Ceiling Fan
Dayton (4F424A) Ceiling Fan Logo
163 people viewed this question
Top Dayton Dryers Experts
Jay Finke
Jay Finke
AZBen
AZBen
Piyal Perera
Piyal Perera
Are you a Dayton Dryer Expert? Answer questions, earn points and help others
