Question about Euro-Pro Shark 60 - 384
Machine will not sew, the needle just moves up and down
Can you please tell me what I'm doing wrong. The needle just moves up and down. Fabric does not move- thread jams up, Please help- this is not my machine, I just happen to be the lucky one to sit in front of it when it stopped working!!!!!!!!!
  • pleaseinsert Dec 29, 2008
    I have the same problem. The manual says to raise the feed dogs, but I have no idea how to do that.
    Scholar:
  • 65 Answers
There is a lever in the back or bottom of the machine. See the pictugraph on your machines parts, this will locate that for you.
If there is a ton of thread jammed in the bobbin casing, you will have this problem as well.
Posted on Mar 30, 2009
My janome 9000 sewing machine has stopped working 3 times when I sewed over heavy material. What s wrong with machine.
Did you take it for service? If so, the technician should be able to tell you what was wrong and what probably caused it.
If you didn't take it for service, how were you able to get it to sew again? Could be the fabric was too heavy for the needle and caused the needle to bend. It could be knocking your machine out of time. Be sure to use a heavy needle like a #16 or #18 (and for most fabrics try a "sharp" like microtex, top stitch, leather needle) and sew slowly with heavy fabric. Perhaps the fabric is too heavy for your sewing machine. I sew heavy fabric like vinyl, canvas, etc but I use an old metal mechanical machine that I can help along by turning the handwheel when the going gets tough.
All About Needles
Apr 03, 2017 | Janome Sewing Machines
Machine stops when needle is moved up or down
Five Common Sewing Machine Mistakes + How to Fix Them
www.tillyandthebuttons.com/.../five-common-sewing-machine-mistakes-...
Sep 23, 2014 - Sometimes the needle will push the edge of the fabric down into the ....also helps stop that problem, too .... makes for very frustrating sewing .... handwheel wont turn and so the needle doesn't move up and down, please help.
Trouble Shooting a Sewing Machine - YouTube
? 2:35
https://www.youtube.com/watch?v=A2QqmEh5qcw
May 25, 2009 - Uploaded by MonkeySee
my machine needle won't go up and down on a white sewing machine. ... won't go up and down it'll go but then it will stop moving after i push ...
Nov 30, 2015 | Sewing Machines
Keeps breaking needles
Slow down and watch what you sew over.
No needle is going to sew through the metal part of a zipper.
With many layers of fabric you have to slow down. If you have multiple layers of a thick fabric you may have to resort to using the hand wheel to get through the layers.
Another tip would be to not pull on the fabric. The machine is capable of "feeding" the fabric at the rate it requires. When sewing with many yards of fabric the weight of the fabric may create a pull on the needle. If the needle is pulled so that it no longer goes through the need plate properly it will hit the metal of the needle plate and break. Instead rest your hands on either side of the fabric and gently steer the fabric. Do not pull it out of the back of the machine or shove it into the needle. With large yardages wad up the fabric around the machine so that the weight of the fabric isn't causing strain around the needle.
One other tip. If you have a needle plate in your machine that only supports straight stiching, that is one with a needle hole that is just big enough for the needle to move up and down, and you switch to a zig-zag stitch, you will break the needle. Most factory installed needle plates have a needle hole large enough to support the largest zig-zag that the machine can support. But some machines have custom needle plates (for quilting) that only support a straight stitch.
Dec 08, 2014 | Sewing Machines
Our simple 3116 won't zigzag stitch,the needle is off to the right and will not do any other stitches. Help!!
It won't do straight stitch?
Take the needle out... see if it is moving the fabric when you press on the presser foot. If it is not, then you need to raise the feet (it's under the accessory box/table face. If it does move the fabric. Make sure your machine is set to Zig Zag. again without needle... sew. Does the needle bar move? change to straight stitch, does the needle bar move? If it does I think you have the wrong size needle. If it does not, I'm afraid your plastic machine has broken... take it in for repair.
Oct 04, 2014 | Singer 3116 Simple
Why does my Empisal sewing machine miss stitches , sew, miss, sew?
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
5. If the above suggestions don't help then the machine needs to be checked
For a timing problem,, the feeddogs may need to be checked to see why they are not moving the fabric thru the machine.
the
thettttt
the the
Aug 26, 2014 | Sewing Machines
Why is the needle not moving or feeding fabric but motor is running
the needle only sews,, it's the feed dogs in the needle plate area that feed the fabric thru the machine, if the feed dogs are in the up position then the machine will sew, if the machine is not sewing then the feed dogs need to be checked to see if the feed dog lever is up or down, look in the manual to see where the lever is and check it, if the lever up the then feed dogs will need to be checked to see if there is something's wrong with them at a sewing machine repair shop.
Jul 31, 2014 | Janome Sewing Machines
I have a Singer CG-550 and am sewing a heavyweight fabric using needle size 18. The engine whirs but the needle no longer moves up and down once it hits the fabric. It occurred suddenly, and I wonder
The motor may not have enough torque to force the needle through the fabric and back in a cycle. If you continue to force the needle into course material, it could bend the shaft, needle, or cause a misalignment of the needle pitch and direction. It sounds like the machine is a light duty appliance and you cannot force it to do commercial appliations.
Dec 25, 2013 | Sewing Machines
Feet not feeding and thread bunching up
the presser foot or what ever foot your sewing with does not feed the
fabric,, the feed dogs in the needle plate are what moves the fabric
to be sewed, the feet only hold the fabric against feed dog so the
machine can use the needle to sew the fabric.
if the fabric is not moving then the feed dogs have to be checked
can you see the feed dogs in the needle plate area are the up or
down?
do you have a manual for the machine?
a manual help to know where the feed dog lever is, I'm sending
you a link for a manual for the machine, so you can look for the feed
dog lever, if the feed dogs are up then there is something wrong
with the feed dogs & they need to be checked.
but if the feed dogs are down then look in the manual & see where
the feed dog lever is & put it in the up position & see if that brings
the feed dogs up to the sewing position, if the feed dogs do not
come up then the feed dogs need to be checked.
http://www.sewingpartsonline.com/instruction-manual-necchi-6015.aspx
Oct 16, 2012 | Necchi 6015 Mechanical Sewing Machine
My machine brakes needles please tell me how to fix this
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
Jun 05, 2012 | Sewing Machines
Kenmore 385-16231 sewing machine. we are having problems with it breaking needles while sewing, we have never oiled this machine could this cause the needle breaking problem?
some sewing machines are self oiling some are not, instruction manual should tell,, when a sewing machine breaks needles it very possible that the machine is out of time & only a sewing machine repair shop has the tools to time the machine
Jan 24, 2012 | Kenmore Drop-In Bobbin 16231 Mechanical...
Euro-Pro Shark 60 - 384 Logo
142 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Greg Cann
Greg Cann
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
