Question about Dishwashers
Dishlex dx102 drain problem
Dishwasher goes through cycle but does not drain water audible noise is heard but no water is drained
  • 641 Answers
SOURCE: Water Will not Drain
It could be cause the water level switch. The level switch is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with your machine,but if you will open the rear panel you will find it easily. Clear tube from any obstruction. Good luck !
Posted on Jul 27, 2007
SOURCE: dishwasher not always draining
If the dishwasher drains through the vent pipe on your sink it may be clogged. I had that problem as well. Unscrew the vent cap and look for junk. In my case of all things it was dog hair!!
Posted on Nov 24, 2007
  • 126 Answers
SOURCE: dishwasher not draining
if its new call your dealer its a warranty call
Posted on Dec 22, 2007
aborcass
  • 2651 Answers
try pressing the cancel/drain button.Do you hear water draining into sink freely?? if not i would disconnect drain undersink look for a clog right there first
Posted on Feb 22, 2008
  • 1019 Answers
the first things to look for, are the simplist faults.
1:) Check that the Outlet Hose-Pipe Isn,t Blocked-Kinked Or Bent.
2:) Check that the Pump, is not clogged/Blocked or not-functioning.
Hope this helps you start, your fault-finding successfully.
Mike @ Compurepair.
Posted on Aug 02, 2008
Dishlex dx 203 buzzer
solenoids that control water flow (taps) buzz when failing Check out the water in solenoid.
May 26, 2013 | Dishwashers
Dishlex dishwasher won't complete a cycle. Number 60 shows up and a small flashing line. ??????
Drain pump is blocked. .If you are good with tools you can clean it yourself. Let me know
Mar 28, 2013 | Dishwashers
Dishwasher dishlex, continues to drain, ECO light flashing
if your dishwasher is constantly draining then it is most likely trying to remove something either water or debris that is stuck in either the drain line or the pump you would have to pull the unit out and remove the drain pump as well as the drain line and assure that the water is flowing into the drain sometimes ive also seen this happen when the drain goes into the disposal it sometimes gets clogged going into the disposal first thing you should do is look down the drain while its trying to drain and see if its a steady stream going into your drain or just a trickle this is one of the first ways to tell if you have a clog Thanks again Rick
Jan 10, 2011 | Electrolux Dishwashers
The dishwasher makes a noise only during the drain cycle.
If the valve opening sound & pump sound ignore it. If the sound was not there earlier and it is newly heard now check the drain water pump.
May 21, 2010 | Maytag MDB9600A Jetclean II Built-in...
Ge triton xl makes loud noise when filling with water - water pump proboem ? or other possible cause? easy fix?
GE Triton dishwasher loud noise after draining water. We started to hear a sustained and loud noise after water is drained. This noise is not heard during washing and draining times. What is wrong? Thanks a lot!
Oct 19, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Siemens hydro sensor dishwasher not draining
sounds like a drain pump ... you may have a damaged drain pump or something stuck in it.. turn off the power the the dishwasher... .remove toe panel and you can see the drain pump on the left ..you can remove plastic hose on the left to drain the dishwasher ...be sure to catch the water will come out ... you can remove drain pump press release tab and turning drain pump ...hope it helps
Sep 19, 2009 | Siemens 24 in. SE53200 Built-In Dishwasher
Dishlex Global 450
Jiggle the float in the dishwasher, turn dial or push button to cycle drain, or rince and off. Vitally
May 13, 2009 | Frigidaire 24 in. FDB126RB Built-in...
Hotpoint FDW60 flashing eco light
if the eco light is flashing, this indicates that saftey float switch has activated in the base of the dishwasher usually caused by a leak, a polystyrene float activates a microswitch which cuts of the water inlet supply
Mar 28, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Bosch Dishwasher wont drain
have you removed the filter? if it gets clogged the dishwasher wont drain. other wise is sounds like a faulty drain pump
Nov 17, 2007 | Bosch 24 in. SHY56A05 Stainless Steel...
Dishwashers Logo
Top Dishwashers Experts
