Question about Panasonic TH-42PD50U 42 in. Plasma EDTV
Panasonic TC-P42S2 .. Transparent 2 inch wide vertical discoloration on panasonic 42 inch plasma, very left of the screen.
The two inch wide band of discoloration is transparent and hardly noticable on whites and I can't see it when the Picture is black. It becomes very noticable when the screen is red or blue. It's up against the left side of the screen. I unplugged the TV overnight, plugged it back in when morning came around and the discoloration was gone; for about 3 minutes. Then it came back. Sometimes there is a very thin red line on the right of the band. It's becoming annoying.
Fixed mine, myself! Black 3 inch vertical band (stripe) appeared after a cros country move on our PC-T50G10. Occasionally we would see white band with multicolored pixel width stripes. Took the risk of taking off the back to see if I could see anything. Found places on sides and bottoms where plastic like 2" flat cables could be seen. Guesstimated where the band was and found that I could flip down a black cover on one end of the cable. Tried to pull it, gently. Mistake. Realized it wouldn't one out like computer hard drive cables, so I took out the screws holding the plate on the other end (it's only an inch long). That allowed me remove the cable. Took it out, cleared away dust, put t back and closed the black over. It worked! Put the screws back in, back on and... we are happy (although I do have four extra screws!). Just be gentle.
Posted on Jun 29, 2012
Screen issue with Panasonic plasma tv. Model TC-P42S2.
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Aug 25, 2016 | Panasonic Televison & Video
Panasonic TC-P50VT20 blank screen with vertical lines
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Apr 05, 2017 | Panasonic Televison & Video
I have a 2" wide vertical dark line in the center of my screen.
Before you go to the dealer, try disconnecting it from the wall for 15 minutes, disconnect all inputs, then plug it back in - do not reconnect any inputs. Turn it on and see if the line is still there. If yes, then off to the store you go knowing its a fault in the guts of the unit. If no, then reconnect the TV input and see. If it reappears then the fault is the signal not the TV.
Jun 28, 2015 | Panasonic Tc-p42s2 42-inch 1080p Plasma...
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
How much would it cost for screen on a 42 inch plasma screen
tcp42x3.jpg Panasonic Viera TC-P42X3 42 inch Plasma TV with 2 HDMI inputs
Your Cost: $640.79
  • 600 Hz Sub-field Drive: Yes
  • Image viewer: Yes (AVCHD/MPEG2/JPEG/MP3 playback)
  • Energy Star qualified: Yes
  • HDMI: 2
  • USB: 2
Apr 27, 2011 | Televison & Video
42 in Panasonic Plasma TV - 4in wide vertical black band obscures image. What is wrong, how do I fix it, and what does it cost.
take it apart and reseat connectors on bottom buffer boards if not may need to replace buffer boards on bottom of tv
Jun 07, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Wide vertical bands of color through the viewing area. The sound is fine
One of your "X" buffer boards is defective. In Panasonic plasma tv's they are located at the bootom of the set and connect directly to the plasma diplay panel via a thin ribbon cable. The board you want to replace will be directly in line with the discolored vertival line in the picture. The part number is on the circuit board and usualy starts with "tnp..." or "txp..."
May 24, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Plasma TV with vertical lines
chake to make sure it is hooked up right and not lose
Feb 02, 2009 | Panasonic TH-37PX60U 37 in. Plasma HDTV
42" Panasonic Plasma - Vertical red stripe 6" from left side
We originally had a red stripe roughly 3" wide running vertically on the ride edge area of our Panasonic 52" Viera plasma tv. It has now been joined by a solid black stripe of the same width running from the top to the bottom. Living in Germany and purchased at local PX long enough ago that the warranty is likely expired. Now what?
Jan 18, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Panasonic TH-42PD50U 42 in. Plasma EDTV Logo
995 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
