Question about Black & Decker DW713 10 In. In. Comp Miter Saw
I juist replace the brush on my B & D 1710 miter saw. Now I can't get it to work. Is there a special way to replace ethe brush?
  • Ludlow Muir Feb 24, 2012
    Hi sorry for the delay in responding to your kind help...perhaps I have another problem...when I squeeze the trigger I get a brief moment kick over and then all went dead. I remove and replace the brushes a few time, but nothing happened. Maybe something not making contact.
    Thanks guys
  • 2,176 Answers
No as long as they move freely in the brush tube they should be fine. You have another problem, let me know what the old brushes looked like and I will try and help
Posted on Feb 21, 2012
3 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: I need to know how to change the blade on a Black
Go to Dewaltservicenet.com and in the middle of the page towards the bottom type in the model number 1710 and it will go to another page requesting either a breakdown or instruction manual, you have to use the manual for a type 4. They do not offer the type 2 as an online version. Hope this helps
Posted on Mar 30, 2009
  • 509 Answers
SOURCE: where can i find a users manual for a black &
I found an online manual. I hope it's what you are looking for.
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/387479-00,1710.pdf
Posted on Mar 10, 2010
Will worn out bushings cause a miter saw to not work
Worn out brushes can cause a saw not to work - they are usually easy enough to remove and check. Make sure they slide easily in the brush tube and that they travel all the way down to contact the armature.
Mar 11, 2015 | Saws
I replaced switch and still doesn't work
Check your cord & insure you have continuity to & through the switch first.
Second, check the brushes - make sure they are not worn down & that they slide easily down the brush tube to contact the armature. I have had a few of these with bad field windings - the winding breaks off right at the field connector (you will need a meter to test this)
Aug 10, 2014 | Dewalt Dw718 12" Dual Bevel Sliding...
Stop spinning
Check brushes making contact with armature, ensure switch operates correctly & carry out continuity check of field coils.
Feb 22, 2014 | Dewalt Miter Saws 12" Double Bevel...
Skil 3316 Compound Mitre Saw 10"
I suspect that the brushes have fallen out between the end bearing and the armature bars.. Try removing the brushes and see what happens.
May 18, 2013 | Skil 10-in 15-Amp Compound Miter Saw...
Miter saw won't start
It is a burned brush holder...new one cost $15
Nov 11, 2012 | Saws
LS1030 miter saw. blade brake not working all the time.
Could be dirty or worn brushes not making contact properly, if not it is the switch which needs to be replaced.
Sep 05, 2011 | Makita 10" Miter Saw LS1030N
Where can i find a users manual for a black & decker miter saw 1710. manualsonline does not have it.
Mar 09, 2010 | Black & Decker DW713 10 In. In. Comp Miter...
I have a Dewalt dw 705 miter saw.when you pull the trigger the saw starts for a second and then shuts off. I have replaced the brushes and it worked for a few minutes and quits. the brushes do not seem to...
the armature needs to be cleaned or it is possibly bad (open bars) They make a special cleaning stick called a commutator stone that you might be able to purchase at a local repair shop. If you are not comfortable trying this I would recommend taking the saw with you, To clean properly you have to remove a cover and have the saw running, I would also check for proper movement in the brush tube allowing the brush to freely contact the armature. Let me know if you need more assistance and I will try and help.
Nov 10, 2009 | Dewalt Saws
I need to know how to change the blade on a Black and Decker 1710 Type 2 10'' Miter Saw.
Mar 30, 2009 | Black & Decker DW713 10 In. In. Comp Miter...
Black & Decker DW713 10 In. In. Comp Miter Saw Logo
181 people viewed this question
Top Black & Decker Saws Experts
Jason
Mike Carew
Are you a Black & Decker Saw Expert? Answer questions, earn points and help others
