Need convergence circuit for 60" phillips mag
Picture bows in the middle and has red and green shadows at sides and behind words and numbers. I have tried to locate my model # in the box below and am having no luck. I would like to find the part to fix myself if possible.
  • 899 Answers
Can you solder? the big chips will start with STK
here is an example http://www.nteinc.com/specs/7100to7199/pdf/nte7178_81.pdf
Posted on Oct 26, 2008
  • jason Oct 26, 2008
    then you can't do it yourself!
9p5544c102 Horizontal bow
ok meoff check the convergence circuit. shadow in the picture is defective convergence circuit... replace a new.
Sep 28, 2007 | Philips Magnavox 9P6034C 60" Rear...
Hello, I have a 60" Phillips rear projection TV
It sounds like a convergence problem; depending on your skills it may or may not be something you can do (parts cost on EBAY will be under twenty dollars).
I will attach some convergence photos: does your set look anything like these?
If it does and you can solder etc I can tell you the best place to get the parts and how to do it.
Before you rate this information let me know what you find.
SD TECH
Aug 16, 2011 | Philips 60PP9202 60" Rear Projection...
I have a Phillips 60" rear projection TV. recently
Tv have a problems known as a convergence problems,it is dead.The tv convergence board it is dead,that why ur tv picture are R,G,B colors lines mis alignments,have colors shadows picture or 3D picture lood alike?The tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Jun 01, 2011 | Philips Televison & Video
3D picture with bowing effects
model number is located on bottom rear cover, your convergence circuit has failed but without model nobody can give you further info, re-post and we`ll try to help, video-tek
May 28, 2009 | Televison & Video
RCA Projection TV Model #p46921, Has bowing effect of pictures
Go to Menu then setup look for convergence if you do not see convergence on menu then you have a open FUSE FL231 it is on right side of FBT flyback transfomer there is 3 of them small brown rectrangler looking caps it will be the one in the Middle.
Jan 31, 2009 | RCA R52WH73 Projection Television
Convergence contols on Philips 60PP920217F
You have bad convergence amps and most likley 2 bad resistors in the convergence circut.
Jan 10, 2009 | Philips 60PP9202 60" Rear Projection...
I have a phillips rear projection 51PW9303 red and green lines showing in the left corners and red line thru middle of screen, bottom of screen shadows and so does left top corner if numbers and...
sounds like youre describing a convergence problem. Do the letters look like theyre 3D? If so you will need to replace both Convergence ICs STK392-120 you can get replacements at the following link and they include installation instructions with pictures plus gree tech support. heres the link.
http://servicemanuals.vstore.ca/
Apr 24, 2008 | Televison & Video
Color shadows
PVAT!Check for evidence of coolant leak on pcb's, If none found,replace convergence IC's,then align convergence in servicer mode.Check service literature for procedure.
Sep 02, 2007 | Hitachi 60UX58B 60" Rear Projection...
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
Electro Med Services...
