Question about Gateway M-7315U Notebook
Laptop won't turn on
What does this mean? My machine is very new & won't drain it won't go through a full cycle & won't spin properly now it's bleeping with this flashing up on it!
Turn off machine and check water waste filter to see if blocked should be at front at bottom of machine or at back,not sure this is the cure but hope it helps
Apr 06, 2013 | Washing Machines
I have a 1999 Gilera Runner 180FXR, New bat 12V 9 amps. Starter turns and spins pinion gear but won't engage starter ring. If it does it turns ver slow or won't turn engine over. In manual it
Yep, not enough amps to engage the starter clutch, and when ti does engage, not enough amps to turn the engine. You need a 12 amp battery.
Nov 17, 2012 | Motorcycles
Blueparrrot B250 is 1 year old & it went dead so I
how do you know it is fully charged? i think it may be dead battery
Nov 06, 2012 | Computers & Internet
Compaq Presario CQ60 won't turn on
If you already replaced the motherboard then try replacing the power cord. If you meant you replaced the cord already, the it might be your motherboard is bad.
May 15, 2012 | Compaq Presario CQ60-220US PC Laptop
Netbook charging indicator light won't light and battery won't charge. AC adapter works on other computers
If the battery won't charge and the laptop won't turn on but the ac adapter works with other laptops, then the problem is the port where you plugin the ac adapter. Some of the laptops has it built in to the motherboard. So you might need to have it repaired by a technician. Or if the laptop is still in warranty, you might need to send it to the manufacturer to have it repaired or replaced. But if the laptop works without the battery, or it will turn on but the battery indicator is not lighting up, you're facing one of these problems.
1. The battery itself is dead. 2. the battery bay is loose 3. the battery itself is loose
Hope this helps...
Sep 15, 2011 | Gateway LT2021u Netbook
My laptop won't charge. I have an acer aspire 5315 that won't charge, I had problems with the charging adapter before so I thought that was the problem and replaced it, the replacement worked for...
For a test -Remove the battery from the laptop. (leave it out) -Plug in the adapter and turn the laptop on. -Gently wiggle the adapter plugged in
If the computer powers off the solder and/or pins have broken loose from the DC jack. This is very common. Average repair bill is around $150, if your in the Denver Colorado Area I can do the repair for about $50
If it won't turn on while you wiggle the adapter and hit the power button then the adapter is bad again sadly
Jul 09, 2011 | Acer Aspire One Netbook 8.9" Notebook
My webcam won't turn off (the light is still on, showing it's still functioning), & I'm not on any program that is involving the webcam.
Did you try restarting your computer....?????
If the problem still persists then I would advise you to press the windows key and R. You will get the run dialogue box. In it type MSCONFIG.
Turn off all program's related with your webcam and your laptop manufacturer(you can turn it on anytime you wish to) in both services and startup. Now restart. It should have gone. And even then if it's there I would advise you to call the manufacturers and claim your warranty if it's still there.
Good Luck
Jun 23, 2011 | Computers & Internet
My Yahoo Messenger hangs then it would say (not responding...). What can i do to fix this? Help me please?
Few sugesstions :
1) Check whether if your windows is installing new updates, sometimes YM does crash when window is updating. If you are using Win7, then just go to:
--> Control panel/ System & security/ Windows Update/ Change setting. In the setting panel, you will see " Important Updates " box selection. Change it to "Check for updates but let me choose whether to download & install them". Restart your pc/laptop, then try log in to your YM.
2) *This step won't be necessary but won't do any harm too, go to:
Control Panel --> System & Security --> System --> Advance System Settings. In the " Advance " tab, click "setting" at the " performance " column. Select " Data Execution Prevention ", select " Turn on DEP for all programs & services except those i select", Insert your YahooMessenger.exe (C:/Program Files/Yahoo!/Messenger/YahooMessenger) into the add list. Restart PC/laptop & try to log in to YM.
3) If those won't work, uninstall your current YM, restart your pc/laptop, then try installing a new one. Link : a)http://www.mydigitallife.info/yahoo-messenger-10-final-full-version-offline-standalone-setup-installer-download/ b) http://www.geckoandfly.com/6309/download-yahoo-messenger-10-full-offline-installer-15-8mb/
** If it still crash, then your internet connection might be the problem, & also, Yahoo! can be down sometimes too.
Jun 08, 2011 | Yahoo Messenger
Gateway M-7315U Notebook Logo
46 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
