Question about Stanley Bostitch F21PL Nailer
Framing a 2x6 wall
Built the wall and got down to the last stud and it stopped shooting nails....oiled the gun ( before and during ) and there were nails in it!
I was able to shoot a nail out by pulling the nose piece back and pulling the trigger.....I know I shouldn't do that , but...
There is not a nail jammed in the gun.The temp is about 20 degrees.We are in Wasilla Alaska.
What should I do?
Thanks Wayne
  • mustang 2 Oct 30, 2008
    Hello , I looked closer at my Bostitch F21PL and noticed a button that adjusts the nose piece in or out... How does it affect the shooting of the nails if I adjust it in or out?
    Thanks
  • Anonymous Jan 21, 2009
    just stopped shooting has worked real good since i got it but won't shoot and is spittin air out around trigger and just makin that PFUU!!! sound. not that old of a gun really need to get it fixed
    Problem Solver:
  • 6 Answers
Does the nose piece go back as far when you actually use the gun as when you pulled it back? I had the same problem with a different model, The nose piece acts as a safety to stop the gun firing when not up against whatever you are nailing. If it a similar design to mine (and most are) if you follow the nose piece up the gun somewhere along that will be some sort of bend in the metal to form the safety. it sounds like this needs to be bent a little more so it actuates the safety off valve/switch. Be careful though that safety is there for a reason, dont bend it too far and make the safety too sensitive. Hope this helps
Pete
Posted on Oct 29, 2008
My airace framing air nail gun blows air when i try to shoot it
Look for an O ring kit,,many times the firing cap seal splits thus loss of air
Mar 30, 2013 | Air Tools & Compressors
Paslode framing nailer: compressor powered, hisses but will not shoot nails, appears to be in the sliding mechanizism that touches the wood first before it will shoot, help
I've used paslode for years and whenever there was a "hiss" of air and no fire- it was o-rings- When were the o-rings changed last? And how do you know they are in 'good shape'? You can't tell by just looking at them. If that isn't the problem then I can't help. Just as an aside- do you oil the gun (down the air intake nipple) every time you use it? Lack of oil will wear out o-rings fast. Sorry if this isn't overly helpfull but most gun problems are o-ring or seal related unless you've worn out or damaged a mechanical part.
Feb 10, 2013 | Air Tools & Compressors
I have had to strip the nail gun down to get water out of it after being flooded. What type of grease or Lubricant do I use when re-assembling
Most nail gun manufacturers make an assembly grease but a light grease like lithium will work, it's just to lube the rings during assembly. Most of it will get washed away by the gun oil you put in the gun each time you use it.
Feb 04, 2011 | Hitachi 3 - 1/4" Framing Strip Nailer
Will not use the whole stick of nails Breaks the last 3-4 nails from the end Is this normal
I'm not sure what you mean by "breaks the last 3-4 nails from the end' but because of the damage that can be done by firing an empty nail gun most manufacturers are making their guns stop working when the magazine gets down to the last three nails. You would need to check your operators manual to see if your model is one of these.
Dec 30, 2010 | Dewalt Round Head Framing Nailer D51845
Some times it dont shoot and when it does it shoots 2 nails
Spray wd40 on the nail track and oil gun well. if that doesn't work you have a bad push pin in the gun will have to replace
Dec 20, 2010 | Dewalt Round Head Framing Nailer D51845
Brand new unit. Used last weekend, no problem. Today, won't shoot nail. Air is released when trigger pulled, but no nail plunged.
Orings /other parts tend to stick when nailer is new. Dewalt uses some vinyl orings that have been causing premature failure. Be sure to add a few drops of oil when used. Too much oil is not good. Wrong oil will cause orings to swell and cause problems such as yours. Your nailer's firing valve can be reset by rapping the nailer against rubber surface such as a thick rugger mat or coiled rubber air hose. Remove airline and nails, being carefull not to damage the head, rap had against rubber mat and retest gun. If it did not reset rap against nose of gun and test. If no joy, you will most likely need to remove head and manually move cylinder up/down and /or check vinyl orings for failure. Before you try to reset the gun, make sure that the safety is pushing the firing pin all the way in. Air removed, look under the trigger as you push down on safey, if it does go all the way in try bump-firing the gun (for test have nails removed). Hold in trigger and quicky /firmly strike gun against rubber pad. Good luck
Nov 14, 2010 | Dewalt D51850 Heavy Duty 20 Degree Full...
Nail gun doesn't shoot and air blowing out vent constant.
We used nail guns for years. I still own 6 guns, but they aren't used much anymore.
You have a 'blown head gasket.'
Or there is debris from the air hose that got lodged into the gun.
There is a head gasket and a trigger gasket.
Both can blow out any time from use, lack of oil, or they can stick open from debris.
You can take apart the head and clean it up and add oil to see if that solves problem.
You can order a gun re-build kit for your model and put in the parts yourself.
You can have a nail gun repair shop do the job.
Nail guns require gun oil.
If you don't use gun for a while, oil should be put into air hose opening and then left to run down into gun. More oil is better.
If you use 3-in-1 oil or some oil besides gun oil, then it will corrode the gaskets.
When storing air hose and guns, put tape over openings so they stay clean.
Before hooking air hose to a gun, you can also put a blower on hose and blow out the line first
Oct 21, 2010 | Dewalt Round Head Framing Nailer D51845
Gun stopped driving nails, air escapes from top,
has the gun been cleaned and oiled, i think not.
take the head bolts out of the top of the gun. make sure you pay attention to how everything comes out so you can put it back together.
shake the gun upside down so that the piston comes out. wipe everything down with any petroleum based cleaning solvent to remove all the gunk and reassemble.
pour about 10 dropsof oil down the air input, let it sit there about 5 mins and hook up the air and it should work
Sep 23, 2009 | Tools & Hardware - Others
Craftsman framing gun shoots every other nail how cam i fix it?
make sure the track is clean and lubricated, also spray we40 in the nose
Jul 20, 2009 | RTO Paslode 902000 IM250 Ii Cordless 16...
Stanley Bostitch F21PL Nailer Logo
293 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
