Question about Braun Coffee Makers & Espresso Machines
I am looking for a rubber "O" ring.
The ring drives the cooling fan.
    Problem Solver:
  • 7 Answers
Go to Home Depot plumping department has O-Rings.
Posted on Feb 17, 2012
Testimonial: "Thanks for the advice but as I'm in England and I believe Home Depot is in America I think I'll look closure to home."
How to replace a water pump on a 2000 ford ranger
Water Pump 2.5L Removal
  1. Drain the cooling system.
  2. Remove the drive belt.
  3. Remove the fan blade and clutch assy.
  4. Remove the bolts and the inlet tube.
    • Discard the O-ring seal.
    • Remove the bolts and the water pump.
    • Installation
  1. NOTE: Apply Premium Long-Life Grease to three locations on the water pump. Position a new O-ring seal.
    syl~us~en~file=aq0296a.gif~gen~ref.gifNOTE: Apply Pipe Sealant with Teflon.
    Install the inlet tube.
    Install the fan blade.
    Install the drive belt.
    Fill the cooling system.
Sep 22, 2014 | Ford Ranger Cars & Trucks
What are the signs i may have a bad radiator cap?
See if it's wet around the cap when it's warmed up, spring could be weak but probably the rubber seal is rotten.. try putting some heavy grease on the rubber and see if that stops it from leaking. Look at your radiator make sure it isn't full of bugs and dirt.. try squirting water thru the radiator with a garden hose [not too much pressure]
Jun 05, 2014 | 2006 Chrysler Town & Country
Front seal replacement 5.9 cummins
Hi Dale, I'm glad to help! Below is the removal procedure for the front crankshaft seal on your 5.9 cummins engine. Hope this helps and have an awesome day!
REMOVAL
  1. Disconnect both battery negative cables.
  2. Raise vehicle on hoist.
  3. Partially drain engine coolant into container suitable for re-use (Refer to 7 - COOLING - STANDARD PROCEDURE).
  4. Lower vehicle.
  5. Remove radiator upper hose.
  6. Disconnect coolant recovery bottle from radiator filler neck and lift bottle off of fan shroud.
  7. Disconnect windshield washer pump supply hose and electrical connections and lift washer bottle off of fan shroud.
  8. Remove viscous fan/drive assembly. (Refer to 7 - COOLING/ENGINE/RADIATOR FAN - REMOVAL).
  9. Remove cooling fan shroud and fan assembly from the vehicle.
  10. Remove the accessory drive belt (Refer to 7 - COOLING/ACCESSORY DRIVE/DRIVE BELTS - REMOVAL).
  11. Remove the cooling fan support/hub from the front of the engine.
  12. Raise the vehicle on hoist.
  13. Remove the crankshaft damper and speed indicator ring.
  14. Remove power steering pump.
  15. Remove accessory drive belt tensioner.
  16. Remove the gear cover-to-housing bolts and gently pry the cover away from the housing, taking care not to mar the gasket surfaces. Remove crank seal dust shield with cover.
  17. Support the cover on a flat work surface with wooden blocks (Removing Seal from Cover), and using a suitable punch and hammer, drive the old seal out of the cover from the back side of the cover to the front side(Removing Seal from Cover).
Apr 10, 2014 | 2004 Dodge Ram 2500
Sometimes it opens and sometimes it dont , sometimes it plays discs and sometimes it dont turned it on and had the red rings of death turned it off then on and they were gone some times the fan dont start...
This is called Red Ring of Death or RROD by the community, it means that the CPU or GPU or both have a bad solder joint, that is caused from rapid heating and cooling from poor cooling design of the xbox 360. To fix it is pretty simple. Follow these instructions to take apart your 360: http://www.rrodfix.com/how-to-take-apart-the-microsoft-xbox-360-game-console.html Stop once you've removed the dvd drive. Now Remove the fans from the back, and set them on the heatsink on the right the flat one, and make sure they are pointing where the air is going up. Put a peice of of carboard or plastic something non conductive in between the heatsinks to prevent airflow from the fans. Turn on the 360, and leave it til it goes from 3 rings to 2 rings, wait 3 minutes, then switch the fan over to the other side. Wait about as long as you did for the other one then turn off the 360. Wait 1 hour for the 360 to cool off. DO NOT move the 360 while it is cooling down durning this period or you will permantly ruin it, the solder is being reflowed. After an hour, put the fans back, and turn the 360 on, it should work. Once its working, I recommend doing a 12 volt mod on the fans to prevent RROD from happening again, and changing out the thermal paste with artic silver 5. As for reading discs, open up the drive air it out, but not the laser, use a qtip and some rubbing alchol, clean it off and put it back together. Fans all you can do is replace them which I recommend just buying off of ebay or llamma.com
Sep 16, 2011 | Microsoft Xbox 360 Console
A black plastic ring fell off underneath at the bottom left... looks like it goes around something... ? bissell steamcleaner
Plastic or rubber? If it's a rubber ring it's the drive belt for the brush cylinder and should be replaced. You can buy one online or at a hardware store.
Apr 06, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Oil Leak on engine drips down from oil filter area, possibly behind manifold. Any common leak problems on this engine?
I would say the rear Valve Cover Gasket is leaking. Common problem on this model. They get old and brittle and...leak.
Feb 14, 2010 | 1994 Cadillac DeVille
Rings of death
problem with hard drive get a new one or take it out then put it back in and it might work but getting a new one will work ofr sure
Oct 02, 2009 | Microsoft Xbox 360 Console
Cooling fan hits the harmonic balancer. Took the fan blades off and the belt still runs off the pulley. Something seams to be miss aligned but I cant see what it is.
Your harmonic balancer is coming apart. The Balancer has rubber ring that eventually wears. I also know that when people try and use WD40 on the tensioner pulley because the bearing is squeeking the WD40 sometimes works its way to the balancer or accidently sprays on the balancer. The WD40 eats away at the rubber. You will need a removal tool to do this. Where you pick the balancer up they should have this.
it looks like this
http://www.nextag.com/harmonic-balancer-puller/search-html
Mar 29, 2009 | 1996 Jeep Cherokee Country
Honda civic 1994 keeps over heating
!!!ALWAYS MAKE SURE YOUR CAR HAS FULLY COOLED BEFORE PERFORMING ANY WORK ON YOUR COOLING SYSTEM!! It may sound kind of elementary but First thing Id check your radiator fluid there should be a plastic reservoir for coolant check to make sure its up to the proper level. Next check your radiator cap look for any signs of wear there's a spring and a rubber ring in the cap make sure both are working (replace if damaged) . If that looks fine check all the hoses coming in/out of your radiator. Check the ground for any leaks. check your radiator for any cracks, holes, dents. Also locate your fuse box(es) there is generally one in the cab and sometimes on under the hood. Check all your fuses. Next check your belts make sure all your belts are running properly. Look at your cooling fan make sure it is not damaged, and all electrical connections are good. If it is none of these things check your thermostat, also check your water pump for proper function.
Sep 29, 2008 | Honda Civic Cars & Trucks
Coffee Makers & Espresso Machines Logo
212 people viewed this question
Top Braun Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Are you a Braun Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
