Question about Ryobi Garden
Fuel line diagram for sears mini cultivator
The fuel lines are disconnected and don't know where they are to be connected?
    Sergeant:
  • 316 Answers
Hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, ``
Posted on Feb 21, 2012
3 Suggested Answers
wentlanv
  • 710 Answers
SOURCE: fuel lines became brittle and
You didn't give me your model number, so I will direct you to a website where you can see a diagram: http://www.searspartsdirect.com/partsdirect/brands-products/Craftsman-Parts/Tiller-Parts?Type=Gas
Just click on your model number and a schematic and parts list will pop up.
Hope this helps. If it does, I'd appreciate your vote. Thanks for visiting fixya.com
Handie Andie
Posted on Apr 13, 2011
  • 112 Answers
SOURCE: how to hook up fuel lines &were
top one usually goes to primer bulb and bottom to carb if its like the one I got.
Posted on Jul 24, 2009
I need the primer bulb and fuel lines that have rotted out
Go to sears and pick them up,they are waiting on you.
Aug 08, 2015 | Craftsman 2-Cycle Mini Tiller
Fuel line diagram for troy built tiller
Try reversing fuel lines. They may be connected to the wrong ports.
Jul 05, 2014 | Yard Machines Cultivator
I need the fuel line routing diagram for a Craftsman Model No. 358.791510 Weedwacker 32cc/1.9 cu.in. 2-cycle
The fuel line in the tank connects to the nipple. It then goes into the small hole in the tank and then the fuel line from the carb connects to the nipple. This line is the line that is attached to the body of the carb, not near the plate.
Jan 18, 2012 | Homelite Consumer Products 4.0 Amp, 13 In....
Fuel pump issues, car won't start, but cranks. I want to know where the fuel pump is and how I can see if it is working properly. How do you diagnose the fuel system issues.
the fuel pump is located in the fuel tank.
I assume you don't have a fuel pressure gauge so the first thing you can do is climb under the vehicle and disconnect the plastic fuel line where it connects to the metal line about in the center of the van up where the front seats would be. Have a drain pan under this area to catch any fuel and be ready to be sprayed if there is fuel pressure in the line. Safety glasses would be a good idea and you can wrap a rag around the line right before you fully disconnect the two lines to help avoid spraying gas everywhere.
keep the drain pan under the area of the disconnected line. Turn the key on but do not start the vehicle. You should see gas spray out of the plastic line. If you don't you're on the right track.
If there is no fuel, reconnect the lines and look back by the fuel tank. You will see the harness. find the dark green with white wire. It is the power supply to the fuel pump. Check for power on that wire. If you have power than you have a bad pump.
If you have any questions let me know. Thank you for using Fixya.com!
Oct 14, 2011 | 1999 Plymouth Voyager
I need a diagram for the fuel lines on 1997 kawasaki vulcan 750. i took the fuel lines loose and i don't know where they go
Hi.
There is no "diagram" showing the whole routing of fuel lines in the bike. You need to use different diagrams in Fuel System section of the service manual. Fuel system section starts at page 15 in service manual, but what you really need starts at page 40. I have posted fuel service manual at the end of comment.
There is one forum where users discussed the routing. One user has colored the diagram from service manual to indicate lines routing. Here the diagram:
Here the forum, I quote:
"The red and yellow are the fuel lines that go to the petcock. The green one you left unmarked also goes to the petcock. The line with a question mark is a vacuum line that connects to a part in front of the battery along with the larger lines to the cylinders."
Here the service manual in PDF format.
Regards.
Ginko
Sep 05, 2011 | 1988 kawasaki VN 750 Vulcan
Ryobi cultivator #RY60511A : Need diagram or text to show the fuel lines from the tank to the primer and the carburetor.
here is a manual,Tim:
http://lawnandgarden.manualsonline.com/mdownloads/38dcb043-331f-461b-a08c-072d67fc76c0.pdf
here is a diagram:
http://photos.hobbytalk.com/showphoto.php/photo/34693
in a nutshell:
1 connect top carburetor line to short nipple on primer bulb.
2 bottom carburetor line to fuel line with filter (inside tank).
3 connect remaining fuel line that comes out of fuel tank to the large nipple on primer bulb.
Hopes this helped Tim
May 29, 2011 | Garden
I am replacing all the fuel line including primer bulb on a craftsman mini tiller/cultivator. is there a drawing or diagram to show which line goes where?
I see that this machine has a 2 stroke engine. These directions work on the 2-stroke engines of Sears trimmers. I've never seen a diagram but many explanations are out there.
The small diameter line out of fuel tank (has fuel filter in-tank on end) connects directly to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. The shorter nipple on the bub has a line from it going to the metering chamber side of the carburetor. If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank.
Oct 21, 2010 | Craftsman Gas Mini - Tiller/Edger
Fuel lines on my cultivator corroded. I do not
ok you have two fuel lines coming in from tank the one that has the fuel filter atached inside should go to the top & the other is just the return line try that & let me know if it helps wade at wadembly@aol.com
Jun 04, 2009 | Ryobi Cultivator
Tiller doesn't run
There are two pictures of the position of the fuel lines at this site, http://www.hobbytalk.com/bbs1/showthread.php?t=147204. You will have to register in order to get the pictures. The registration is free. Hope this helps.
Don
Mar 18, 2009 | Garden
Garden Logo
1,323 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
