Have a 96 thunderbird with no heat. Replaced heater resistor ,switch still works and fan blower still comes on but still no heat. Do anyone have any ideals what might ne the cause of this????
    Problem Solver:
  • 5 Answers
The heater matrix is blocked
Posted on Feb 18, 2012
2 Suggested Answers
SOURCE: RLP 30 portable heater
out of fuel
Posted on Jul 29, 2007
MY HEATING AND AIR CONDITIONING DOESN'T SEEM TO BLOW OUT AS HARD AS IT ONCE DID
is the fan working in all speeds?could be a fan resistor if not or cage on blower motor restricted some how thats what i would check first
Jan 15, 2013 | Cars & Trucks
The heat in my 96 mazda protege dosn't work
With the ignition and fan switches turned on check for power at fan motor.If you have power at the motor then wiggle and maybe pull on the blower motor resistor and if fan comes on just fix the connection.But when you check for power at the blower motor and don't have power then check the fan relay if it does'nt click when you turn it on then its faulty.
Oct 29, 2012 | 1996 Mazda Protege
Dodge caravan heat fan won't work
If it is the fan/blower that is not working (as opposed to what is coming out is cold), then the problem could be 1) fuse 2) Blower Resistor. I just replaced the blower resistor in about 15 min with a $25 replacement resistor. The unit is right behind the glove box.
If the problem is that the air coming out is cold and not hot, then the thermostat, radiator, heater core, etc... are the more likley causes.
Jan 10, 2012 | 2004 Dodge Caravan
Heater and defroster not working on 96 thunderbird 4.6 V8
my heater isnt working. i replaced the blower motor but i had my brother in law check it and there is only like 4 volts going to the resistor where the blower hooks in. he says there should 12 volts going to it. is there something else causing the blower not to work?
Dec 07, 2010 | 1996 Ford Thunderbird LX
The heater on my 96 accord lx wont work. i hooked a toggle switch up and the blower and the hot and cold switch work but fan speeds do not. I was told it was a possible resistor problem. where do i look?
It is not a resistor you blower motor is going out it needs to be replaced. When fan speeds don't work as they should this is clearly the problem.
Jan 26, 2010 | 1992 Honda Accord
Blower motor for heater only works on high....what do you think I need to change. Relay or Resistor.
If the heater only works on the high setting, your problem is the heater fan resistor, not the relay.
Jan 07, 2010 | 2005 Jeep Wrangler
Getting heat in the heater core,heater door are opening, but no heat coming out the vents,help thanks
It sounds like the blower motor is not working. If you don't hear it running when you switch it on, check the fuse first. If the fuse is OK, you will probably need a new blower motor. It could also be a faulty fan switch or blower motor resistor. Once you remove the blower motor assembly, you can test it by putting battery voltage across the contacts with jumper wires, making sure to get correct polarity. If it does not spin, it should be replaced. If the blower does work when removed, the fan switch is probably at fault. The resistor is usually indicated when the fan works only at certain switch positions, but not all.
Dec 19, 2009 | 1998 Jeep Grand Cherokee
1998 BMW 328i heater/AC blower is not running
You have clean the blower unit , may be its dirty then . and then check the blower resistor unit for malfunction.
Aug 04, 2009 | BMW 328 Cars & Trucks
Heater blower switch broken
mine was doing the same, then just quit all together. I went and got a resistor and everything is working again. Pretty easy to replace as well.
Dec 29, 2008 | 2001 Dodge Dakota
Blower motor problem
Replaced automatic Control module in dash and module at blower and the blower Still have no heat. Original problem was smoke for vents and no blower help...1994 thunderbird
Jun 13, 2008 | 1996 Ford Thunderbird LX
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
