Question about Lexmark X2600 InkJet Printer
IT WONT COPY OR SCAN
THE THING INSIDE THE GLASS I THINK IS STUCK BECOUSE IT MOVES A LITTLE AND START MAKING A NOISE
  • Official Brand Answer
  • 3,344 Answers
Please try this approach:
  1. Remove the sheets of paper from the printer.
  2. Open the printer cover and remove the cartridges.
  3. Close the printer cover.
  4. Re-brick your printer by pulling out the power supply - the black box where the power cord is plugged into. Re-plug after 30 seconds.
  5. When the printer turns on, reinsert the cartridges. Close the printer cover.
  6. Load some paper.
  7. Try to scan or make a copy again to verify that the problem is fixed.
I hope this helps.
Posted on Feb 20, 2012
  • Lexmark
    Lexmark Feb 20, 2012
    6. Load some paper.
    I hope this helps.
Grinding noise in copy mode?
The Grinding Noise has something to do with the scanner not the Printing Part, I think the scanner could have something stuck on the moving tray....!!!!!!
Apr 18, 2013 | Lexmark X8350 Print, Scan, Copy and Fax...
Agitator only moves a little bit and making noise
Most likely agitator dogs / gears are stripped out inside agitator. If it's a double action agitator where the top turns independently from the bottom, the top should turn one way and not the other. If top of agitator turns freely in either direction, then replace those dogs. If it's a single action agitator, then grooves that slide onto transmission shaft in agitator itself could be stripped out. If that's the case, replace agitator
Oct 27, 2017 | Kenmore Series 70 Washer Motor 387780
I cant copy or scan because the message scanner lock error
The scanner which moves left to right underneath the glass is either stuck or has gone bad. Turn on the machine with the top cover open and see if the scanner moves all the way to the right and then to the left. Good luck.
Jul 14, 2011 | Sharp AM-900 All-In-One Laser Printer
Cannon ImageRunner 210S - When I try to make more than one copy the copier makes one copy in regular mode and then for the second copy it goes to the far side to make a copy like you are copying a book...
Sounds as though the black lens cover is not secured correctly. When the scanner moves across to make a scan its hitting the cover. Take the copyboard glass off and try physically to move the scanner to the right to see if it hits any thing. You may have to remove the cover and then look to see how its supposed to be secured. It should lay flat on the reader shelf and be secured with I think 4 screws. It's been a long time since I've work on one of these copiers. Hope this helps you.
Jun 22, 2011 | Canon imageRUNNER 210S Copier
No copy/no scan
Down inside that scan assembly are mirrors and a lens, one cover to snap off. Try cleaning the lens, and mirrors, shining a flashlight straight down you can see a sort of fog on the glass. Also the white strip on the underside of the glass needs to be clean. After that you'll have to check around for a new scan assembly.
Jul 31, 2009 | HP OfficeJet G55 All-In-One InkJet Printer
When scanning several pages of a document some pages scan fine, some you'll hear a draggin noise and there are smudge lines thru the document (putting thru feeder). Other times when you place 1 copy to be...
Well, if both feeder and pattern glass also having line on print, suspect hardwares problem...
U can check below items:
1. drum
2. laser unit
3. fuser unit
Mar 03, 2009 | Office Equipment & Supplies
Black line when scanning or copying from top feeder
Please check whether their is any thing on the glass of the scanner or there might be some dust or something might be stuck the glass that's why this problem occurs. so kindly clean the scanner glass with neat and clean cotton with some spirit on it and this will help you resolve your problem.
Dec 04, 2008 | HP Officejet 7210 All-In-One InkJet...
7210 can't fax or scan
Soft/firmware issues. Try updating.
Jul 29, 2017 | HP Officejet 7210 All-In-One InkJet...
Lexmark x7350 Still under warranty does not fax, scan or copy anymore
Definitely sounds like the scan bar or some related hardware is bad. I would call Lexmark tech support at 1-800-332-4120 and ask them if it is still under warranty and if it's covered by warranty. Hope you registered the product when you first bought it.
Jul 16, 2008 | Lexmark X7350 All-In-One InkJet Printer
HP psc 1315v noise
hi,
there is no way to oil it. u can clean the scan glass, rollers etc with a lint free cloth. check for any paper stuck inside.
if it is still making grinding noices, you may have to service the unit.
thanks and regards
agnel
Mar 13, 2008 | HP PSC 1210 All-In-One InkJet Printer
Lexmark X2600 InkJet Printer Logo
24 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
