VOLUME CONTROL KNOB FOR PIONEER A400 WHERE CAN I GET ONE
4 Suggested Answers
marsrover
  • 682 Answers
SOURCE: volume control problem
bring good contact luricat cleaner from near radio shack and apply it over volume and move it forward and backward many times.
Posted on Jul 05, 2008
SOURCE: Pioneer Stero Receiver model SX-3700-
It sounds like your volume control pot has dust in it.You need to remove your cover from the receiver,spray pure denatured alcohol in the small openings in the back of you volume control dial and turn the knob all the way up and down several times and then blow low compressed air threw the same small openings while rotating your dial.That should fix your problem.Be sure you unplug your receiver before performing this procedure.
Posted on Feb 20, 2009
  • 35 Answers
SOURCE: Pioneer Amp VSX-D409 Volume
I have a VSX D508 Looks just like the VSX D409. Had the same prob with the volume control when I bought it. I first tried the cleaner. Better than what it was but didn't compleatly solve the problem and before long it was getting worse again.
It does have a rotary encoder instead of the traditional varible restance volume control. I finally broke down and removed it from the board and lightly sanded the contacts with fine sandpaper.
This involves removing the whole face from the main board and chassis. Not that bad, a couple screws and some ribbon jumpers and latches and it's off.
Next carefully pull the volume control straight off the shaft, remove the nut under it and lay it face down on a soft surface. Remove the screws that hold the circuit board to the face and slowley seperate the too, you'll have to release some latches also to sepperate them.
If you replace the volume control with a new one or clean the old one you have to go this far because it's soldered to the front side of the board. Yes, it has to be de-soldered from the board.
This control was not designed to be dissassembled but I was able to carefully open it and remove the shaft to totaly expose the contacts for a complete even couple of passes with the sandpaper.
I did have to use some 5-minute opoxy when I put it back together because I couldnt get the metal tabs to close as tightly as they were before it was opened.
I soldered in the volume control, put it back together and it's worked perfectly ever since. I don't know how much pioneer wants for a new one but I can tell you they wanted $69 plus shipping for a new remote for my receiver. And with this style of volume control you might be at their mercy as far as finding one from another source that fits.
Posted on Apr 03, 2010
Pioneer receiver -no volume or volume display on screen. As if the function has disappeared. Knob still turns; just NO effect
Did the volume control get an impact? Could be internal damage to the digital control. Did it act up prior to this non-function, like volume went up on a down command or jump up or down when a slight turn was made? Thnose would reinforce a damaged volume control.
Jun 02, 2015 | Pioneer Audio Players & Recorders
Pioneer vsx1021k volume drops by itself at 3db increments until there is no volume. M volume is displayed when this happens as if someone was manually turning the volume knob.
Dirty rotary encoder (volume control ). If you are confident with opening the unit yourself, a spray of contact cleaner into the encoder might help. Ideally u should replace it.
OR
The volume minus button on your remote is dirty/shorted. Try removing remote control batteries and see if the issue disappears.
Aug 14, 2014 | Pioneer Audio Players & Recorders
I Need the main knob for the pioneer dehp5000ub also. Any suggestions?
If you are talking about the volume control knob you can get it at either pacparts.com or pioneerelectronics.com. The part number is QXA3012. It is rather expensive though.
Mar 13, 2012 | Pioneer DEH-P5000UB Car CD/ MP3 Player
Why does my pioneer vsx-d557 automatically go into MUTING WHEN I turn it on?
Maybe you have MUTING selected. Turn the volume knob up or toggle the Mute control on the remote.
If it defaults to muting on power up find the manual and search it for a default volume setting.
May 15, 2011 | Pioneer VSX-D557
Replacement volume control knob for pioneer deh
an authorized service centre in the back of the pamphlet that came with the reciever,or direct from pioneer.
Jan 13, 2010 | Pioneer DEH-P6900UB CD Player
VOLUME KNOB
Contact Pioneer directly or find a Pioneer authorized service shop in your area.
Apr 03, 2009 | Pioneer DEH-P6800MP CD Player
Volume problem with VSX-D409
Had the same problem. I had to replace the volume contol. It was inside the receiver behind the knob. It has a part# on it. Mine was part# AWX7386 (control assembly) from Pioneer.com. If you can figure out how to open the case than you can change this piece. Good luck
Dec 23, 2008 | Pioneer VSX-D409
The rotary volume knob on my DEH 9400MP head unit has stopped working. this also happened to my friend's. the steering wheel remote still works. is this common? can it be fixed please?
Although I can't check this fix works for 1 month, a really simple explanation and fix was offered.
The rotary knob/control has 2 contacts, which when the knob is rotated c/w or anti-c/w it generates a pulse. The diagnosis is that as the remote still works, the PCB & volume circuit is fine. What is likely is that the 2 contacts/switches have become dirty or clogged.
SUGGESTED FIX: Take head unit faceplate apart to access PCB & rear of rotary control (4 screws). Spray WD40 into rear of volume control and rotate liberally to clean contacts. Dry of with lint free cloth, tissue or air dry.
I am confident this will work and the volume control will function again.
Sep 27, 2008 | Pioneer Car Audio & Video
Display
go into your tools menu by pressing the center of the multi knob.(the volume control knob) turn same knob to bring up the entertainment field, press center of knob to set then turn till you get to the prompt about alternating screen. switch to no. done.
Apr 06, 2008 | Pioneer DEH-P790BT
Volume control
Well here goes a spelling problem for me. You need to replace a component called a podentiomiter. It is the actual volume control behind the knob. I have had to replace a few of these, and pioneer seems to to more prone to these problems.
Jan 30, 2008 | KLH KL2400 Tuner
110 people viewed this question
 Grubhead
Grubhead
