Question about Saeco Royal Digital Plus Coffee Maker/Espresso Machine
"Fill water tank" prompt
The "fill water tank" prompt continually goes on and I can not brew coffe when this is on ... The tank IS full!  Even after making just one cup, the propmt comes back on. Can this be fixed?
  • 2 more comments
  • evolve429 Jan 07, 2009
    "watertank empty".
    just bought this saeco royal digital used and can't figure out how to remedy this. checked the magnet and valve mechanism.
    daunted,
    bizzy lee
  • denacamp Jan 13, 2009
    I have the same problem and it went to being an occasional issue to a permanent situation. The problem with the magnet no longer floating was encountered early on and was solved by rigging the magnet so it stays in the up position (of course must visually confirm that the tank is not empty). However the current problem appears as if the logic chip has become stuck and there appears to be no way to reboot it. Any other ideas?
  • Bernie Fay Jan 20, 2009
    Yes I also had the same proble with the "fill watertank" status. rigged the magent and it solved the problem.
    Bernie
  • cwr_music
    cwr_music Jun 07, 2013
    Make sure the smaller, tapered end of the magnet is facing down. I cleaned and replaced it upside down and got errror messages until I figured out it reinstalled it incorrectly.
    New Friend:
This has happened to me too just yesterday (26 May 2013), I replaced the tank because I was lucky to have kept the spare bits off the old machine I had and it worked fine. Over time, the water gets into the float and corrodes the magnet. Best to just replace the magnet if you can or the whole tank. Good luck
Posted on May 27, 2013
  • cwr_music
    Just to add....even when I installed my magnet upside down...it did float but still worked incorrectly. Again...the smaller end of the case MUST face down...it's possible if the larger end is down the magnet gets stuck in a lower position - thus telling the machine "you're out of water".
  • 5 Answers
Posted on Jun 07, 2013
I have the same problem after wedging the magnet up for 2 years. now nothing works - except take the tank off and place a magnet in position over the sensor. This worked! however since I can't put the tank back AND keep the magnet in place, I still have no coffee.
Coffee drs in phoenix said a new tank should fix the problem. The magnet float gets a hole and fills with water, doesn't float. Over time the water corrodes the magnet and the sensor doesn't connect.
Posted on Jan 27, 2009
  • 515 Answers
Make sure the magnet in the water tank flow up when you fill it with warter.
Best regards
/Mirran
Posted on Oct 26, 2008
My bunn coffeemaker NHS-B trip the GFI. Where do I find the code date on my brewer?
The NHS-B has a semi-sealed tank that keeps +1 pot of water heated and ready to brew. Pouring in a full pot of cold water will fill the top tray and allow a slow trickle of cold water into the top which forces hot water to over flow into the brew basket. This continues until all the cold water drains into the heater tank. So the brew is matched volume per volume. UNLESS the thank was empty or not filled prior to brewing. Follow the brewing instructions from Bunn (on line for *FREE* download at Bunn.com)
* If it leaks (from the bottom) only when you pour in water. Then your pouring it too fast and over flowing the fill tray. slowdown, watch the level in the tray. do not fill past the lid.
* If it leaks just sitting (not brewing) then there is a hole in the tank. Call for service.
* If it leaks after filling the tray half way. then the top of the tank has a leak, loose, cracked, or missing gasket. There is quite a few gaskets on the lid. Call for service.
* Final; Leaks are always bad around electrical equip. Best to unplug and call for service to be safe.
Aloha, ukeboy57
P.S. If you did splash too much water then wipe up as much as you can. Leave it out on a towel or paper towels to allow the excess moisture to evaporate. If you dump all the water out of the brewer (and tank) then you will need to pre-fill it with a pot of water PRIOR to plugging in the brewer. Follow the set up instructions in the manual. Let it heat up and try again. If it's still leaking then there is a hole in the tank. Call for service.
Dec 29, 2017 | Bunn Coffee Makers & Espresso Machines
Bunn VPR 12-cup pourover is leaking water from the back at the bottom every time I pour water in. It leaks about 1/2 cup or more. Is there a seal or gasket I can replace to remedy this?
VPR has a semi-sealed tank that keeps +1 pot of water heated and ready to brew. Pouring in a full pot of cold water will fill the top tray and allow a slow trickle of cold water into the top which forces hot water to over flow into the brew basket. This continues until all the cold water drains into the heater tank. So the brew is matched volume per volume. UNLESS the thank was empty or not filled prior to brewing. Follow the brewing instructions from Bunn (on line for *FREE* download at Bunn.com)
Aloha, ukeboy57
May 12, 2017 | Bunn Coffee Makers & Espresso Machines
Bunn coffee maker leaks
VPR has a semi-sealed tank that keeps +1 pot of water heated and ready to brew. Pouring in a full pot of cold water will fill the top tray and allow a slow trickle of cold water into the top which forces hot water to over flow into the brew basket. This continues until all the cold water drains into the heater tank. So the brew is matched volume per volume. UNLESS the tank was empty or not filled prior to brewing. Follow the brewing instructions from Bunn (on line for *FREE* download at Bunn.com)
Aloha, ukeboy57
Jun 17, 2014 | Bunn VPR Coffee Maker
How do I fix my bunn #053213cs from leaking from the bottom
Aloha, ukeboy57
Jun 04, 2014 | Bunn VPR Coffee Maker
Water overfill
The A10 has a semi-sealed tank that keeps +1 pot of water heated and ready to brew. Pouring in a full pot of cold water will fill the top tray and allow a slow trickle of cold water into the top which forces hot water to over flow into the brew basket. This continues until all the cold water drains into the heater tank. So the brew is matched volume per volume. UNLESS the tank was empty or not filled prior to brewing. Follow the brewing instructions from Bunn (on line for *FREE* download at Bunn.com)
Aloha, ukeboy57
PS. Check your using the correct size decanter for this brewer. If it's a 10 cup brewer then make sure all the decanters in the office is also 10 cup. Pouring a 12 cup pot into brewer will have 12 cups of coffee come out (over flowing the 10 cup pot.) Note that not all decanters are made the same size. Other brands may be different. Test by filling a pot with water (from faucet) then pouring directly into pot in question. It should match and not under fill nor over fill.
Apr 04, 2014 | Bunn A10 Coffee Maker
Water leaks from the top of the right side of commercial coffee maker
Aloha, ukeboy57
Apr 03, 2014 | Bunn VPR Coffee Maker
Short pot of coffee
Aloha, ukeboy57
PS, Check the pots in the office. Make sure they are all the same size. Decanters come in 3 sizes; 10 cup, 12 cup (standard), and 3L (3 litters). Check the decanter brand as each brand is a bit different in size. All metal decanters are usually very small (8 cup). What ever size you use, just make sure they are all the same.
Mar 09, 2014 | Bunn VPR Coffee Maker
Our Comfort machine won't brew and constantly displays, "Fill Watertank" even with the tank full. In order to brew, one has to remove the water tank then gently lower it only partially down in place. As...
Hi
The magnet in the water tanks is either upside down or has sunk to the bottom of the tank. It should float to the top of the cage it is in and it should have a flat top not rounded. If its rounded side up the magnet is upside down. This is what would cause your problem.
Sep 22, 2010 | Saeco Magic Comfort Plus Espresso Machine
GE 169165 12 cup digital coffe maker
after 60 cycles it goes into the clean function, the clean light comes on..., remove the charcoal filter from the water tank, fill tank with 1/2 water and 1/2 vinegar if you want to clean it, just water if you want to get it out of clean mode..., press clean button/light for 3 seconds and clean button flashes and the cleaning process begins...It takes 60 minutes / 1 hr. to complete, light goes off when complete. reinsert filter in tank .
Oct 26, 2008 | GE 106591 Coffee Maker
Make sure the magnet in the water tank flow up when you fill it with water.
Best regards
/Mirran
Oct 26, 2008 | Saeco Vienna SuperAutomatica Coffee...
Saeco Royal Digital Plus Coffee Maker/Espresso Machine Logo
1,120 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
