Question about Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White
FROST ISSUE WITH FREEZER - Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White
Make sure your door is sealed . No airleaks.
Posted on Feb 18, 2012
How do you make a freezer frost free?
Frost free means that the evaporator coil will not accumulate a thick layer of frost. It will not prevent frost from accumulating on the walls of the freezer. To slow down the amount of frost build up inside the freezer, do not keep the freezer door open for any longer than necessary. The freezer door seal may be defective. This would allow moisture in that would freeze on the inside walls. A heater with timed intervals to come on is one way for a frost free feature. But this will not work for frost build up on the inside walls of the freezer. It would only melt the frost and then it would refreeze again.
Aug 31, 2015 | Frost Freezers
How do I defrost my chest freezer
Hello friend, thanks for your post!
If you Frigidaire freezer is frost free and not defrosting the best thing to do is to manually defrost your appliance. You can do so by disconnecting power from your freezer for two to four hours. If you have a frost free freezer you could be experiencing an issue with thermostat or sensor and they may need to be replaced.
I would recommend reaching out to a professional to come out and diagnosis your freezer to avoid any unnecessary part purchases. I hope this is helpful. -Matt
Oct 07, 2014 | Frigidaire Freezers
Our Frigidaire frost frost free upright freezer from day one has frost build up on the food inside the packages. The frost is not a problem in the freezer itself, but on the food. Freezer burn occur
Hi Dale Dibb, thank you for your inquiry!
I understand that the food inside of your Frigidaire freezer is getting frost on the inside of the packages. I would recommend turning the temperature up inside of your freezer. Additionally moisture inside of the package would cause frost to develop on the inside of the food packages.
Please assure that all possible moisture has been removed out of the food packages prior to placing the items inside of the freezer. If there is anything else that I can help you with, please feel free to reconnect! -Matt
Sep 30, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Model FRS-U201A fridge freezer and fridge is not keeping cool, only 3 years old, ssems to have occured in a couple of days
look on back wall of freezer if there is frost build up you have a defrost problem can be defrost heater defrost control board or bi-metal is open and not tuning heater on if no frost you may have low freon problem this can cost check first part of this post 90 % of the time its a defrost issue
Aug 18, 2011 | Daewoo FRSU20IA Freezer
Freezer do not turn off automatic.
Good day,
If the freezer gets to normal temperature, then the cold control (thermostat) is defective and needs replaced.
If it fails to reach 0 degrees or colder, then there is an issue with the system.
Loss of refrigerant is one item. If it's frost free then it could be a defective fan motor behind the back panel, or the defrost system has failed. (frost building up on the rear panel).
Dec 20, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Freezer has frost in back- frig not coolling
You have a defrost parts issue.
Unplug the fridge. Remove the back freezer panel and check the defrost heater and defrost thermostat.
Without a model number I can not tell you where the defrost timer is.
Mar 04, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer frost
That you have to 2 defrost your freezer it's normal depending of many factors. Do you open it often, is it in a warm place, is the food that you are putting in it is warm? many factors contribute of building up frost faster.
Francois
Dec 29, 2008 | Freezers
Excess frost not keeping food frozen
you have a refrigeration issue. let me guess. is the frost real thick around a small area not the entire lining? if so you have a restriction or leak. cheaper to replace by the way
Apr 14, 2008 | Danby 3.6 cu. ft. / 102 liter Chest...
Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White Logo
Top Frigidaire Freezers Experts
AJMAL KHAN
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
