Question about Canon Office Equipment & Supplies
How to fix waste toner cartridge Canon IR 3380
I recently ran into an issue where my Canon ir3380 gave the error "replace waste toner cartridge" and would not print any more. The waste toner cartridges are pretty expensive, but with this simple 'hack' I was able to get back printing in no time. How to reset waste toner cartridge error in 5 minutes. #1 remove waste toner cartridge #2 empty contents (gently) in a waste container. (note, BE CAREFUL not to breathe in the toner. have a fine mist spray bottle ready to water down the dust with repeated sprays of water mist as you are emptying the toner waste into your second waste container. I used a plain plastic bag in a waste basket) #3 When you have most of the toner out of the cartridge through the neck (don't need to be completely empty), go to next step. #4 you will notice a small clear plastic rectangular piece held in with two small phillips screws on the bottom corner of your waste cartridge. Remove the two screws and gently dump the toner out of this little piece and clean it (so its clear) with a cotton swab. Then reattach and tighten both screws back in. (There is an optical sensor in the main printer that detects the waste toner level with this piece, so once its clean again, then the printer will reset the error). #5 Replace the waste toner cartridge and you are back in business!
  • yanek
    yanek Oct 22, 2013
    Works for Canon IRC 2380i too, Thanks!
  • 400 Answers
Thanks for the tip.
Posted on Feb 17, 2012
  • yanek
    yanek Oct 22, 2013
    Works for Canon iRC2380i too. Thanks!
How to solve canon ir 3300 error code e0000190000
Neele, Error code E000019-0000 is a waste toner full , to get rid of this error, remove the waste toner bottle located left rear side of the machine,dispose of waste toner and clean the neck of the bottle because waste toner could obstruct the toner sensor beam. Switch off then on, OK to use.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Thread Canon IR 2200 Error E000019 0000
Canon ERROR 19 Waste Toner Tank
Jun 13, 2014 | Canon (6981A002AA) for imagerunner 2200,...
I have an error message in Canon IR 5020 "error E000004-0000.. how do I fix it?
Hi.
Power off CANON ir5020 then try to pull-out cartridge toner. check up paper feeder for paper garbage
cleaning using vacuum to get dust and small paper dirt.insert toner cartridge fix and power on again.
if same problem error display.your canon mainboard need repair.
Hope can help you.
Jun 28, 2011 | Canon Computers & Internet
Canon ir 2318 shwos "out of toner.I unpacked the
this is the common problem with 2318. u have to take out the developer assembly out and if u are a rep then check the toner shutter in the dev assembly.it some times does not move in accordance with the toner cartridge. u have to align it with cartridge in home position. and be sure to check the toner cartridge sometimes the churner in the cartridge is broken but 90% is the above said
Jun 03, 2011 | Canon Office Equipment & Supplies
Cannon ir 3530 all error code and solution
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
Mar 03, 2011 | Canon ImageRUNNER 3570 Copier/Printer
EO19 error
You have problem with waste toner, to be specific You need to empty the waste toner compartment in drum unit.
Open front cover and left side way door, on front side you will see the blue handle beneath the drum unit, lower her and pull the drum unit out. On top side of the drum unit you will see the cork which you need unplug and empty or vacuum the waste toner.
when you put all in first state turn off and on the copier.
Hope that helps!
Jan 10, 2011 | Canon iR 2016i Black and White Copier
Canon iRC 3380i error code E00025-002...help please?
Service Bulletin
Issued by Canon Europa N.V. Copier Color
HARDWARE
Revised:
Addition of the Affected Machines
Hopper Assembly
Subject:
Measures against E025 error due to toner leak
Detail:
<Symptom>
The toner leaking from the toner cartridge flows onto the inside toner sensor (PS3/PS4/PS5/PS6), causing erroneous
detection and E025 error (Error in the toner motor).
Model:
iRC2380i
iRC2880
iRC2880i
iRC3080
iRC3080i
iRC3380
iRC3380i
iRC3580
iRC3580i
Ref No.:
iRC3380-023 Rev. 2
(F2-T01-NO1-10097-03)
Date:
January, 2009
cartridge, the toner in the supply route between the toner cartridge and the
hopper may leak between the gap between the toner cartridge case and the holder of the machine.
<Factory Measures>
The gap between the toner cartridge case and the holder of the machine is covered with the plastic sheet and the shape
of the front unit cable guide on the toner sensor is changed to prevent the toner from flowing onto the toner sensor.
P-1 Position where the toner cartridge is installed
nside and replace the front unit cable guide into its new type.
Points to Note About Service Work:
When the front unit cable guide is replaced, implement periodic cleaning (every year) for the area around the photo
sensor (PS3/PS4/PS5/PS6).
For the affected machines or later, implement periodic cleaning (every two years) for the area around the photo
sensor (PS3/PS4/PS5/PS6) and the area of toner leak [1].
Service Parts:
Supply of the new part(s) will follow a normal supply pattern.
P-2 GUIDE, UNIT CABLE, FRONT
[2] Change Point
Parts Number Description Q'ty Interchange
ability Fig No.
Old FC6-9380-000 GUIDE, UNIT CABLE,
FRONT 1->0 N
620
New FC6-9380-010 GUIDE, UNIT CABLE,
FRONT 0->
and later IR C3580 230V EUR : CZS00218 and later
IR C3580I 230V EUR : CZT04670 and later IR C3580 230V : CZU00011 and later
IR C3580I 230V : CZY00752 and later IR C3580I 230V AU : CZZ00857 and later
IR C3080 UL 120V : DBE01554 and later IR C3080I UL 120V : DBF02861 and later
IR C3080 230V EUR : DBM00294 and later IR C3080I 230V EUR : DBN10330 and later
IR C3080 230V : DBT00011 and later IR C3080I 230V : DBU00714 and later
IR C3080I 230V AU : DBV01085 and later IR C2550 UL 120V : DCA03694 and later
IR C2380I 230V EUR : DCF16473 and later IR C2550I 230V : DCK00864 and later
IR C2550I 230V AU : DCL01033 and later
Jun 15, 2010 | Canon C3380i Color Copier
Canon irt 2022 says "system error 007"
dear sir !
my canon ir2022 has one problem which is system error E007 how i can solve this above problem , i am wait for your answer .
Thanks & Regards.
Nayeel
Aug 13, 2009 | Canon iR 2022 Printer
Canon imageRUNNER 2020 alternates between displaying Error Code E019 and saying "Waste Toner Full".
hi you have a waste toner error code, the waste toner is apart of the drum unit in these machines so you will need to order a new drum unit for it.
easiest way to fix the problem.
Canon Tech
May 28, 2009 | Canon imageRUNNER 2000 Copier
Wast tuner is full!
you need to empty the waste toner inside the drum cartridge,open the front door pull the lever down and take the drum cartridge out(with care) there is a cover on top of it.
May 23, 2009 | Canon iR 2022 Printer
Toner waste container location
The waste toner is in the front, open front cover and the white bottle in the middle is the waste toner cartridge. Remove the black screw, and empty or replace the cartridge.
Mar 30, 2009 | Canon iRC3100 Printer
931 people viewed this question
old marine
old marine
