Question about Dell 966 All-In-One InkJet Printer
Will not print red
Won't print red on print, copy, scan.
  • Dick Hil Feb 17, 2012
    Its a new cartridge, and cleaning didn't make a difference. Anyone else? Thanks for the prompt reply tho.
  • Fabio Feb 20, 2012
    Try wiping the nozzles with a clean try cloth as described in this document:
    http://support.dell.com/support/edocs/sy...
    And also try to reset printer to default settings ,also make sure you are not using an expired ink cartridge and that it is an original cartridge.
  • 400 Answers
Hello
Have you tried changing the colour cartridge with a new one? ,if yes then try to do an ink cartridge nozzle clean which can be done from the maintenance section of the printer itself or through the printers installed software.
Hope this helps.
Posted on Feb 17, 2012
    Its a new cartridge. Read partially prints with heavy grey tones to it. Nozzle cleaning did not work. Thanx tho. Any other suggestions?
Barcode scanner won't read printed labels
1. The printhead in your printer might be scratched (evidenced by thin white streaks through your print). This is common, and the most likely cause. Printhead must be replaced.
2. Material might be stuck on your printhead (usually evidenced by wide white streak vertically through print). Printing surface of printhead can be cleaned with rubbing alcohol and cotton ball.
3. The ribbon might be wrinkling due to uneven tension, producing intermittent diagonal streaks in your print. This is somewhat common, but doesn't fit your description as well as 1 & 2 above. Mechanical adjustment and/or proper media loading solves ribbon wrinkles.
4. Poor pressure and/or printhead alignment. Evidenced by grainy, light or no print on one side or the other of the media. This is somewhat common, but doesn't fit your description as well as 1 & 2 above. Mechanical adjustment solves printhead pressure and alignment issues.
Dec 11, 2012 | Datamax E-Class E-4203 Label Printer
Kyocera CS-C2525 won't scan
Do you have the option installed on you copier??? Also, there is another ether connector for scanning. If it is installed it is right above the print PCB.
May 22, 2012 | Kyocera Copystar CS-5035 Copier
Hp 380 allinone won't print or copy but will print something i scanned in
it is better dont purchase HP series.. its all waste... they are simply selleing by advt. No customer service. Useless....
Dec 14, 2011 | HP DeskJet F380 All-In-One Printer
My HP 6280 will not print the full picture after it has been scanned. I put it in the right hand corner, chose the correct paper size and it still won't print correctly. Can you please help
Check corner marking for placing the document, place the document & scan through system, verify whether you got full scanned image? if not adjust the placement in correct position, once its OK, go for print there select correct image size(could be 100%) & paper size..I hope it will solve the issue..Best of luck
Sep 25, 2011 | HP Photosmart C6280 Printer
FAILS TO COPY FROM A SCAN
Hi
Scanning takes an image on a document on the scanner's platten and converts it to a digital file format stored on your computer.
Copying is scanning + printing.
To copy, you do not need to separately scan first and then print. Just select how many copies you need on the number pad, then press either the Black or the Colour COPY buttons on the scanner (or open the printer's/scanner's software and click on COPY), while it's connected to the computer and the document will automatically be scanned and printed (copied).
I hope this helps.
Aug 24, 2011 | Office Equipment & Supplies
Does not copy or scan. light flickers
everytime i try to print something it goes to this box and won't print
Jun 23, 2011 | HP DeskJet F380 All-In-One Printer
My HP deskjet 2050 all-in-one printer only shoots out blank paper and won't print. It used to say there was no paper in it, which there was. It scans & prints just fine - just won't print...
Any error messages on the printer digital screen or the desktop? I take it the "The ink is fine" means that there is ink in the cartridges!
Try a test print via the Control Panel> Printers and Faxes> properties > Print test page.
May 31, 2011 | HP PSC 2210 All-In-One InkJet Printer
How do I copy documents?
Unfortunately you won't be able to copy directly from this machine since it's only a printer. If you have access to a scanner you can use it to scan your document, save it to your machine, and then print it on this device. Otherwise you'll need to purchase a Multi-Function machine that includes a Scan/Copy feature.
May 05, 2011 | HP Hewlett Packard LaserJet 1018 Printer
Will not scan or copy windows7 64 bit
If the machine won't make a copy (by hitting the copy button on the front panel) it may be a hardware issue.
If it will copy, but not scan - it's likely software related, as many devices have issues with the 64bit version of Windows 7 (and XP for that matter).
You may try installing the 64bit versions of the drivers and software. I've included the link below...
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=4063&lc=en&cc=us&dlc=en&sw_lang=&product=441240
May 02, 2011 | HP Photosmart 2575 All-In-One InkJet...
Dell 966 All-In-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
