Question about Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine
"Fill water tank" prompt
My machine keeps prompting to "fill water tank", eventhough the water tank IS completely full.  I know that you have to remove the tank and replace it, but it still says "fill water tank" .... The machine will not let coffe be brewed and sometimes I have to repeatedly remove and replace the tank until it says "ready" Then it will only brew ONE cup and it says "fill water tank" AGAIN! Can this be fixed?
  • Anonymous Mar 21, 2014
    Coffe grinding but no water getting through
  • Steve Shaw May 15, 2016
    This is happening to me the float is working as it should but still the red fill tank lights is flashing any other ideas?
  • 515 Answers
Make sure the magnet in the water tank flow up when you fill it with water.
Best regards
/Mirran
Posted on Oct 26, 2008
    New Friend:
The magnet float may become stuck or may not move freely in its chamber. Clean the chamber and the magnet float gently with warm water and dishwashing liquid, moving the float up and down the chamber. Ensure you rinse thoroughly following procedure. Fill water tank again with cold water and replace into machine.
Posted on Jan 09, 2016
  • Stephen Anderson
    Stephen Anderson Aug 03, 2016
    Thanks a lot! This tip saved my (Impressa S7) machine.
What does the red light descaling prompt light stay on? how can i know i have everything possible?
Fill it up the tank with descaler and start the machine on descaling. Leave it to trow all the liquid and must finish to the bottom,leave the machine to get AIR when descaler finished.Then the machine will stop and will tell you to put fresh water to clean . Fill the water tank to the MAX level and continue with the program. When the water is on minimum ,machine will stop,and the descaling process must be finished.
Good luck
Jan 11, 2018 | Gaggia Coffee Makers & Espresso Machines
"GROUND TOO FINE ADJUST MILL! Insert water spout
  1. Insert steam spout and push OK.
  2. Fill your tank and add descale solution.
  3. Go to program settings - Descale.
  4. Follow the prompts on the readout.
  5. After descale and rise are complete refill your water tank.
  6. Your system should now work as normal.
Note: If you do not have a descale solution, run the above with just water. Remember to descale when you obtain a descale solution.
Sep 27, 2013 | DeLonghi Perfecta ESAM 5600 Espresso...
The machine says fill watertank. ventilate. the
Open the hot water valve, and run about a cup of water, this will engage the pump and fill the circuit.
Jun 04, 2009 | Saeco Vienna Digital Coffee Maker,...
Says "Fill water tank" and the tank is full
did you open the side valve to ventilate the air in the system in our water tank do you have a little magnet its in the water tank maybe it stuck downshake the water tank to move the magnet up pierre
Jan 09, 2009 | Saeco Magic Comfort Plus Espresso Machine
this has happened to me too just yesterday (26 May 2013), I replaced the tank because I was lucky to have kept the spare bits off the old machine I had and it worked fine. Over time, the water gets into the float and corrodes the magnet. Best to just replace the magnet if you can or the whole tank. Good luck
Oct 26, 2008 | Saeco Royal Digital Plus Coffee...
Water fill light stuck on
you say our fill the water light stay on lot they put a magnet in the water container fill it with water and gently tap the water container if the magnet stuck that should do it if it persite the magnet receiver under the cover is diffective normaly a few little tap do the trick
thanks for using fixya
pierre
Feb 25, 2008 | Saeco Incanto Classic Espresso Machine
Fill Water Tank But Water Tank is Full
hello in the water tank they is a float it was probably out of water for a while and the float is stuck take the container in our hand and tap it gently by doing that the float gonna get loose move the container you gonna ear the float move put it back fill with water enjoy cheers
Jan 14, 2008 | Gaggia Titanium Espresso Machine
Fill Watertank Message
The black thing floating in the water tank is a plastic shell with a magnet inside. If you clean it...make sure you reinstall it with the tapered (smaller) side down. There is a slight size difference BUT it will make ALL the difference in the world.
I had no idea there was a magnet in that black/greyish case. The direction of the casing is important.
I had the same problem and that solved it!
Jul 29, 2007 | Miele CVA615 Espresso Machine
Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine Logo
3,309 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
