Question about GM Carts 1985-90 Chevrolet Caprice Car Radio Install Kit Gm1480b
1985 Caprice run-on problems
After driving for a time, when i go to shut the vehicle off it will run-on (continue to run roughly after the ignition has been switched to off) Does anyone have any suggestions as to how to correct this? Thanks!!
  •  Tyler S. White ESQ.
    Whoops. Dodnt see the car stereo heading. Sorry.
    Thanks! That was very helpful! I got er fixed.
    Sergeant:
    Champion:
  • 390 Answers
Dieseling as its called,can be caused by a few thing,carburetor or fuel injectors leaking into the cylinders after the engine is shut off.Also the ignition might not be shutting off all the way.Could also be a carbon build up in the cylinder,that will cause it to keep running on after its shut off,with fuel leaking into the cylinder.Check all of the ignition/fuel parts to see if they are operating normaly,Try to clean all of the fuel system,(ie)the fuel tank,lines,filters(might be more than 1 if fuel injected,1 in tank and 1 external,only 1 should be there if its carbureted.)Depending on which 1 you have be it carb or injectors,you can try some carb cleaner or throttle body cleaner to clean it.
Posted on Feb 17, 2012
    Thank you! That helped a lot. I got er fixed!
My grand1994 caprice will start up and then it
if vehicle starts, you can usually rule out ignition
Sep 30, 2014 | 1994 Chevrolet Caprice
Tip
Saturn S series runs rough
It is very common on ALL SATURN S series vehicle for ignition module failure. Usually the symptons are running rough and possibly a check engine light with misfire codes-P0300,P0301,P0302,P0303,P0304.
Some people have attampted replacing plugs and wires,even coils and continually have the problem reoccuring. What happens is the ignition module bolts(x4) stretch out through time and corrosion builds up underneath the module causing incorrect spark displacement. In turn this damages the plug wires and even at times the plugs. What needs to be done is replacing plug wires, plugs if needed, the ignition module bolts(saturn dealer item only)and the ignition module-NOT JUST THE COILS.
This should fix your problem.
on Feb 18, 2010 | Saturn S-Series Cars & Trucks
Car: 94 Chevy caprice, 5.7L engine/port fuel injection Problem: very hard cold starts, rough idle at cold temperatures and stalling at low idle(when able to start after minutes of continuous cranking)...
Have your temp sensor checked. It may not be setting off a code but a sign of a failing temp sensor is hard starts, rough idle, until the car heats up. It sends a code to the ECM to help adjust fuel mixture. If it sends gals readings, the computer will adjust the fuel-air ratio and cause vehicle to run too lean until warmed up. Some people have had to keep pumping the gas pedal to keep it going from a bad temp sensor.
Oct 14, 2017 | Cars & Trucks
Random shutting off on incline. How do i fix it? After changing ignition coil pickup this prolem started. help me fix my 93 Chevy caprice!!!
the 1993 chevy caprice had a 5.7 engine with distributor in which you need to adjust ignition timing with a timing light.the 1994 - 1996 vechicle timing controlled by pcm, your problem does sound like timing off.
Feb 18, 2012 | 1993 Chevrolet Caprice
Began running rough at start up and would correct itself after a bit. Now runnung rough all the time. Check engine light has now come on, but doesn't stay on continuously.
If the check engine light goes on for any length of time, there probably are codes stored in the computer that can give you clues as to what is wrong with the electronic engine controls, or mechanical parts on the engine.
Reading Codes 1985–94 vehicles Codes are displayed by the MIL flashing ON and OFF. The time duration of the flash identifies the significance of the digit. Three flash durations are used:
  • A flash duration of 0.5 seconds indicates no malfunction (OK).
  • A flash duration of 1.3 seconds indicates that it is a 10's digit.
  • A flash duration of 0.2 seconds indicates that it is a 1's digit.
For example, if 3 flashes — 1.3 seconds long — are followed by 4 flashes — 0.2 seconds long — a Code 34 is indicated. These code sequences are separated by 1.8 seconds to avoid confusing tens and ones digits.
  • Read Memory Mode: used to pull codes which have been stored in memory. It is most effective in detecting poor contact of wiring harness connectors. To enter this mode, connect the read memory connector with the ignition ON.
  • D Mode: used to diagnose and test the entire injection system. To enter this mode connect the test mode connector with the ignition ON. On the Legacy and SVX, the ignition must be ON with the engine running.
  • F-Check Mode: used to measure the performance characteristics of the injection system components. When working in this mode, a Select Monitor or equivalent scan tool is required.
  • U Check Mode: operates during normal engine operation. It signals the driver using the MIL only when components necessary for start-up and drive are faulty. The read memory and test connectors must be disconnected with the ignition ON for this mode to be operational.
Clearing Codes 1985–94 vehicles With the ignition ON and the engine running, connect both the read memory terminal and the test mode terminal
Aug 05, 2010 | 1991 Subaru Legacy
1985 Chevy: I have a 1985 2.8L chevy 4x4 Blazer I just re...
All GM have ignition coil problems , your getting too much fuel , I have seen O2 sensors and plugged catalytic mufflers too many times , be careful the next ride the vehicle will catch on fire..Try the coil first
Apr 14, 2017 | 1985 Chevrolet Chevy
Stopped running 1991 caprice classic 8 cyl.
it could very well be the ignition module. i had these go out on a couple different vehicles before. whe the motor gets up to temp it will shut off and not start back up. it will start however after it cools down. if yours does this then that is your culperate. if its all the tim then id say your coil pack it bad.
Mar 28, 2010 | 1994 Chevrolet Caprice Classic
Ignition coil keeps busting open
YOU EITHER HAVE A COIL DRIVER CIRCUIT WIRE SHORTED OR FAULTY ENGINE CONTROLLER(PCM)..CHECK NEAR TRANS DIPSTICK FOR ANY DAMAGED/MISROUTED WIRING..HAVE SEEN IGNITION COIL DRIVER CIRCUIT PROBLEMS WITH PCM'S IN THESE VEHICLES ALSO
Jul 04, 2009 | 1998 Chrysler Town & Country
1985 chevy Blazer cranks up, runs rough, then
have you checked, cady, fuel tank, is it getting the right amount of gas and air? plugs and wires, go with general mantinence first then step up. i have a 85 s10 blazer that was a lemon off the lot but has over 300000 on it and it has the same prob i fix it tempurary by flipping the lid on the breather upside down so it gets more air
Mar 12, 2009 | 1985 Chevrolet S-10 Blazer
GM Carts 1985-90 Chevrolet Caprice Car Radio Install Kit Gm1480b Logo
77 people viewed this question
Top GM Carts Car Audio & Video Experts
Robert Monigold
Robert Monigold
Ryan Lutton
Ryan Lutton
Are you a GM Carts Car Audio and Video Expert? Answer questions, earn points and help others
