Question about Asrock P4I45GV R5 Motherboard
No display on monitor but cpu is running
Hello all i am facing a problem of no display on monitor but cpu is running . monitor not shows the intel motherboard logo and no bios is seen on the screen.............can any one help me out
thank u
  • Susan
    Susan May 11, 2010
    What happened? Did you install something before this happened? Were you doing anything with video cards or video drivers?
    Did you delete any files by accident?
    Have you checked connections? Does the chord look damaged?
    Can you tell if the monitor is getting any power at all?
    Sometimes when people remove a video card this problem can happen.
    Its fixable though.Sometimes they add in a video card and forget to plug the monitor into the new card.
    Either way though I need more input *S*
    Ok? Thank you.
  • 34 Answers
The main problem is in the RAM or MEMORY CARD, just detach it and place it back or on another slot beside it.... if this dont work, buy a new memory card. but this usually works
Posted on Oct 27, 2008
    New Friend:
Remove ur ram and clean ithe slots and ram ....remove and insert all the wire connections and clean the slots..then it works..
Posted on Apr 16, 2013
I have the same problem. My monitor is fine but when i connect the CPU there is no display why is that? and What can i do to fix it
Posted on Jul 14, 2012
    Scholar:
  • 40 Answers
Shut down,remove the video card, clear your bios, and reboot.
When installing the video card the basic procedure is to install the drivers first, then shut down, plug in the card, plug the monitor into the new card, and boot up.
If it does the same thing again, it means the card is NOT compatible with your motherboard.
Thank you and good luck.
Posted on Oct 28, 2008
P4I45GV R5 Motherboard: i have intel 945g motherboard the cpu fan runs but...
Check you Ram. If possible, try with another working ram. Clean the port. It is also possible that your cpu is overclocked, remove the bios battery and leave it outside for few minute and reinsert it and boot the system. If this doesn't helps, you'll need to check your display card also. Try the monitor on another pc. Still here to assist you further. good luck and thanks for using FixYa.
May 16, 2010 | Asrock P4I45GV R5 Motherboard
Intel dg31pr mother board why dont show display?
First check your num lock led if it on and off when you press num lock key then your cpu is ok.
Then therer is issue with monitor to cpu loose connection
or
Screen resolution problem.
For that when you power up press F8 key then enter in enable vga mode.then go to control panel and dispaly then settings then change screeen resolution to 1024*768 then apply and ok.
Aslo reconnect connection from monitor to cpu vga port.
Also check in bios some times your harddisk is not detected proeprly.
If problem still remains open cpu cabinet and reconnect data cable and power cable to harddisk.
Refix RAM memory.
Pull cmos cell for 15 minutes then check.
Thanks for using fixya.
Pls rate solution if it help you .
Jul 18, 2009 | Intel DG31PR Motherboard
Intel DG31PR Motherboard BIOS menu and motherboard LOGO not visible properly in my HP 7550 CRT MONITOR. but i plug LCD MONITOR and it show menu and logo properly. pls solve this problem to me because i...
The reason is that your CRT monitor has a low refresh rate, and the motherboard logo etc just displays for briefly seconds.....so your monitor doesn't react as soon as the signal is sent from the motherboard... Sorry you can't change monitor....
Jun 11, 2009 | Intel DG31PR Motherboard
Intel DG31PR Mother board BIOS menu
le quitas la bateria(pila) antes de encender, la enciendes y espera unos minutos. Luego colocas la bateria y actualizas la hora en el setup
entonces reinicia y problema resuelto
Jun 10, 2009 | Intel DG31PR Motherboard
Intel D865GVHZ (Gateway Hazelton) motherboard system cooling fan
This fan error message shows up when the CPU fan is not plugged into the CPU FAN plug on the motherboard. The Intel D865GVHZ
motherboard has a total of 4-fan plugs so it is easy to plug the CPU fan into one of the other fan plugs that is not marked CPU FAN on the motherboard.
Apr 12, 2009 | Intel (8W501B1M3G) CPU Fan, CPU Cooling...
No display
it may be the problem of your monitor.check it
Jan 11, 2009 | Intel Motherboard
No Display
hi i am enver parson can you tell me wot tipe of graphics card are you using
Dec 07, 2008 | ASUS K8V-MX Motherboard
Mother board dead
Hello how are you. Please give me ome detailed information the make and model of the computer. i will help you with this. Easy. This is what I do for a living.
Thank you hope to here from you
Feb 10, 2008 | Intel Motherboard
Fan, HDD... everything is working but no display.
You have no display, and cant even get to the bios screen.
OK, does anything at all show on the monitor when starting?
Logo,etc?
If that is the case, look to your video card or monitor.
I cant tell you how many times I have seen pins that are bent or proken on the VGA cable. or even plugged in.
Please check these things and let me know what you find
Nov 18, 2007 | Intel Desktop Board D845WN Motherboard
Asrock P4I45GV R5 Motherboard Logo
1,157 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
