Question about Watches
Men's geneva watch
I have a men's geneva watch product code 4094 it has $ signs around the whole band and a big $ is on the face i am unsure about price, and if it's real or not.....please help
SOURCE: Armitron mens watch band link removal
Try http://www.webjeweller.com/jewellery/removelinks.shtml
Posted on Jul 14, 2008
SOURCE: Lost manual TGHK
I was trying to find a solution to this problem on line, and then I stumbled on it myself while playing around with it. Here it goes:
Your 4 buttons on you watch are:
Light Start
Mode Reset
While looking at the time, hold in the Light and Reset buttons at the same time with 2 fingers from your left hand. This will put the alarm time in the display. While still holding those 2 buttons down, use you right hand to press the Start button. This will cause the alarm signal to go away (or go on if it off when you do it). Problem Solved !!!!!!!!!!!!!!!!!!!!!
Posted on Jan 09, 2009
SOURCE: i dont know how to set the time and date on my watch{arnette model ar 2041}
do you have the button on your watch named "el" its the top left one, press and hold it for 3 secs. after you can change the time. you can press the mode button to change it :)
Posted on Jan 18, 2009
escapement
  • 2334 Answers
SOURCE: how do I adjust band on a guess g95290g guess steel mens watch ?
You may or may not have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Feb 16, 2009
SOURCE: casio pathfinder SPF 70-s titanium band adjustment
I purchased a Casio Pathfinder solar/atomic watch, with compass, altimeter, barometer, thermometer, model 1200T-7WC (titanium).
Has the titanium band - on this particular band each link is somewhat waveshaped {i.e., there are 2 "arms" from the link making contact with the middle part of the link above (above meaning towards the watch body), and 1 arm fitting between the 2 arms of the next link down). Unlike described in the first solution, the pin is not split, but solid (doesn't look like a slotted screw on 1 end, so the solution at http://www.wikihow.com/Adjust-a-Casio-S-935L-Watch-Band is no help). Here's what to do if you have this band:
1. Note: before you start, be advised there is a tiny loose 1/8" part (sleeve) that will fall out as you pull the links apart, so work over an appropriate surface to "catch" it. Push pin (from the upper "arrow end) of one of the removeable links (those with the arrows on the backside) out of its hole with a fine poker (I used a 1/32" jeweler's screwdriver, an unbent paperclip would also work, just more likely to bend as you push pin out). This takes some force to do - in my case, after pushing, the pin projected out about 1/2 of it's length, I used needle-nosed pliers to gently pull it out the rest of the way). CAREFUL - once pin is removed and you pull the link away from the one above, a small (1/8") constriction sleeve should fall out of the center arm of the link above. SAVE THIS SLEEVE!
2. Using the same procedure, remove the pin from the bottom end of the link you're removing. again, SAVE THE SLEEVE.
3. to rejoin the band once the link is removed, look at the single/middle "arm" of the upper link, looking for the hole where the pin goes through. One side of the hole should be noticeably larger/wider than the other side - this is where you will place the SLEEVE - I used tweezers, or needle-nosed pliers will work - it will drop into hole. Keep this upright so that sleeve doesn't fall out, and slide the 2 arms of the lower link in place around the center arm.
4. Slide the pin you removed into one of the outer link arm holes - I found it easier if I started from below, pushing it into the center arm - it will stop when it reaches that 1/8" constriction sleeve. I set the extruded end on the pin on a magazine (i.e., slightly padded surface) and then pushed the top side of the band down, forcing the pin through the constriction sleeve and up into the upper arm hole, and Voila, your band is reconnected. The sleeve is important (without the sleeve in place, the pin will simply fall back out).
Posted on Mar 07, 2010
I need a replacement band for a fossil watch number 741010; I see a number on the band of 7413500. Could you help me find a replacement band?
On the back of the watch should also be a 6 digit code consisting of 2 letters and 4 numbers. For instance CH3000.
With that code you should be ablte find your strap here: http://www.mastersintime.com/en/straps/
Oct 17, 2017 | Fossil Watches
Where can i get links to add to band or replace band?
Parts Archives - Citizen Watch - English (US)
www.citizenwatch.com/en-us/faq-category/parts/
Citizen HoldingsQ: Why can't my jeweler or I order parts for my watch that is marked 'factory ... We domake some components such as bands and band parts available directly. ....Determine how many links of this size are needed to make the watch band the ... Q:Can you use substitute parts if the replacement part I need is discontinued? A:.Missing: timberland
How To Easily Remove a Watch Link - YouTube
? 3:10
https://www.youtube.com/watch?v=8uxpDXKOPqA
Dec 29, 2011 - Uploaded by TheBiggerKid
I got a watch for Christmas but the watch band needed a little adjusting. I thought ... Real Men Real Style 310,589 views ... How To Resize A Citizen Watch Band - Add & Remove Links At Home ... Get video URL at current time.Missing: timberland
Your Guide to Adding and Removing Links in a Bulova Watch
www.ebay.com > ... > Jewelry & Watches > Watches > Wristwatches
If the current watch does not fit properly, find another watch, a bracelet, ... When a metal watch band is too small, add links to make thewatch band ... How to Choose the Right Strap Replacement for... ... Bulova Men's 98E112 Diamond Set Stainless...... Bulova Men's 96A28 Black Leather Band Quartz Watch NIB Image ...
Jan 31, 2016 | Timberland Mens Quartz Watch Qt7117302
Armani Exchange AX 1066 in need of a replacement part.
Google is your friend in such cases
Armani Exchange Watch Repairs ' Creative Watch Co
https://www.creativewatch.co.uk/repairs/armani-exchange
  1. Cached
  2. Similar
Armani Exchange watch parts & repairs are available from Creative Watch Co at the Birmingham Jewellery Quarter watch shop.
A'X Armani Exchange Watches ' eBay
https://www.ebay.com > ... > A'X Armani Exchange Watches
  1. Cached
You are here. eBay · Jewelry & Watches · Watches, Parts & Accessories; A'X Armani Exchange Watches. Skip to page navigation. Filter (1). A'X Armani Exchange Watches. Limited Time Deals. Free Shipping Included. Armani Exchange Women's AX5216 Gold Stainless-Steel Plated Fashion Watch. $128.57. was -$190.00 ...
Armani Exchange - New Watch Strap Band
https://newwatchstrap.com/armani-exchange-watch-strap-band.html
  1. Cached
Items 1 - 24 of 44 - You will find the cheapest price for your watches of band types of the Armani Exchange brand.
Watch Straps - Buy Armani Exchange watch straps online
www.mastersintime.com > Watch Straps
  1. Cached
  2. Similar
Masters In Time home · Watch Straps; Armani Exchange. Universal watch straps. Morellato Watch Straps. Strap Brands A-Z. Adidas (34) · Alessi (2) · Armani Exchange (26) · Boccia (15) · Braun (27) · Breil (27) · Casio (532) · Citizen (113) · Cluse (95) · Daniel Wellington (74) · Danish Design (101) · Davis (756) · Diesel (1236) ...
Armani Exchange Watch Repair Specialists - Watch Repairs USA
www.watchrepairsusa.com/armani-exchange/watch-repair
  1. Cached
Armani Exchange Watch Repair Specialists - Get your Armani Exchange watch repaired the fast and easy way. Free Estimates, One Year Warranty.
Watch Parts ' Replacement Watch Supplies ' Esslinger.com
https://www.esslinger.com/watch-parts/
  1. Cached
Find a wide variety of watch parts that come in handy during watchmaking and repair work, such as replacement watch parts.
Armani Exchange Men's Watches ' A'X Store
https://www.armaniexchange.com/ca/men/mens-watches
  1. Cached
Shop the full range of Men's Watches from the latest Armani Exchange collection. Browse the A'X official online store today.
Armani Exchange Watch Straps & Bracelets for Replacement ' Babla's ...
https://www.bablas.co.uk/watch-straps/armani-exchange-watch-straps.html
  1. Cached
Items 1 - 20 of 31 - We also offer a selection of Armani exchange watch straps available by special order. All replacement watch straps are genuine manufacturer replacements. Replacing your watch strap with an original replacement watch band maintains the original appearance of the watch. Please contact us if an Armani ...
Warranty & Repairs - WatchStation Official Site: Watches
www.watchstation.com/webapp/wcs/.../ContentView?...warrantyRepairs
  1. Cached
  2. Similar
Shop Watches, Wallets, Bags, Belts, Sunglasses, Jewelry & More for Men and Women. Incredible looks at ... Click on the corresponding link below to download a PDF of a specific brand's warranty, US-only repair form, or international service center information. To view PDF files, you will ... Emporio Armani Swiss. Warranty.
Armani Exchange Watch Repair - Total Watch Repair
https://www.totalwatchrepair.com/pages/armani-exchange-watch-repair
  1. Cached
Total Watch Repair provides online Armani Exchange Watch Repair Services including battery replacement, band repair and internal mechanism repair.
armani exchange watch replacement parts Google Search
Dec 27, 2017 | Watches
My Akribos XXIV Men's Large Dial Diamond Quartz Chronograph Bracelet Watch wirst is dangling the screww that connects the face & band came out & i can not locate im trying to gain info where to...
Most makers have a limited warranty and does not cover anything outside the case.
Have you tried any of the local watch repairers; on the face of it, it sounds to me that a watch repairer should be able to fix it for you.
May 19, 2011 | Watches
What is the best way to de-mist a watch face? Left crown unscrewed then got in a hot tub!! face mists up after wearing it for about 5 minutes
Try putting it in a warm cupboard (with the crown unscrewed) for about a day or so).
Otherwise its to a watch repairer to take the back off and dry it out.
Goof luck!
Mar 18, 2010 | Bell & Ross Geneva 123 G123WTE Sl Watch...
I need a replacemnt mesh band for the skagen 281LSS
go to skagen.com they have cheap replacement bands for your watch you can even send it in and they will send it back to you like new.
Aug 05, 2009 | Skagen Signature Mesh watch
Skagen 596XLTXM Titanium Mens Watch
good morning ! you need a puncher pin and anvil to remove the pin on your watch band punch or push the pin use the puncher pin according to the arrow sign,full the pin to remove,and fush to fix again,do it carefully,thank you ! god bless .
Aug 27, 2008 | Skagen 355LGSC Wrist Watch
Watch bands f/ Kenneth Cole
Replacement watch band (f) can be purchased from amazon, take a look here: Amazon com kenneth cole band Watches Women Clothing Shoes Jewelry Wish you best of luck. Cheers
Jun 22, 2008 | Watches
Geneva watch bracelet
I Have a Geneva Made Pga Tour Partners Club watch that needs a new band and I have not been able to find one.It is a special band and the PGA partners club says they are no longer available and were not helpful in finding a band.
Apr 01, 2008 | Geneva J06345 Wrist Watch
Dec 25, 2007 | Watches
Watches Logo
62 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
