Question about Zebra QL 420 Plus Thermal Label Printer
HOW DO YOU CALIBRATE A QL420PLUS PRINTER - Zebra QL 420 Plus Thermal Label Printer
  • RUDY KROCK Feb 20, 2012
    THANK YOU....PROBLEM SOLVED
    President:
  • Zebra Master
  • 2,017 Answers
KINDLY GO THRU THIS VIDEO
http://www.youtube.com/watch?v=iWlfmcG1Xws
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Posted on Feb 18, 2012
Getting blank page feeding while printing with Zebra ql420plus....but it is working with MZ320
I have experienced similar issues between two zebras. I found that the driver was the issue. I recommend:
  1. Confirm the operating system your using. [32 or 64 bit is important]
  2. remove old driver and install new driver from Zebra's support website. https://www.zebra.com/us/en/support-downloads.html
  3. If you are still having issues after all that, I really must recommend contacting Zebra as your printer may be defective and may be under warranty for service or replacement.
Dec 23, 2014 | Zebra QL420 Thermal Printer
Need to have the print darker! /Zebra QL420Plus/ How can I set the darkness?
zgorbe723: The darkness is only setup via software. Adjust it in your Windows driver or including the heat command in your format:
CONTRAST n 'in CPL comtec syntax
^MD+n 'in ZPL zebra syntax
Roberto Martinez
padrino99@prodigy.net.mx
Aug 31, 2011 | Zebra QL 420 Plus Thermal Label Printer
I am printing the supplies print page but that print alinment was shifted
Calibrates the printer again and again to align
Calibrating the printer using HP Toolbox
Use the following steps to calibrate the printer using HP Toolbox.
1 Open the HP Toolbox.
2 On the Troubleshooting tab, click Calibrate now.
Calibrating the printer at the control panel
Use the following steps to calibrate the printer using the printer control panel.
1 Use the (LEFT ARROW) or the (RIGHT ARROW) button to select SYSTEM SETUP and then press (SELECT).
2 Use the (LEFT ARROW) or the (RIGHT ARROW) button to select PRINT QUALITY and then press (SELECT). CALIBRATE COLOR will display on the control panel.
3 Press (SELECT).
4 Use the (LEFT ARROW) or the (RIGHT ARROW) button to select CALIBRATE NOW and then
press (SELECT).
5 Press (SELECT) to start the calibration.
Aug 19, 2011 | HP Color LaserJet 2600n Printer
I have a hp cp4005dn on a network. The prints have color repeating dotts . I have change the toner cartidges and transfer belt. I still have issues.
Calibrate the printer after replacing the ETB.
Full Calibrate Now
Use the following procedure to calibrate the printer whenever you replace the DC controller, the ETB,
the drum drive motors, the drum drive gears, or a laser/scanner. Full Calibrate Now includes theQuick Calibrate routines and adds Drum Phase Calibration and Color Plane Registration. Full
Calibrate lasts for about four minutes.
1. Press Menu to enter the MENUS.
2. Press to highlight CONFIGURE DEVICE.
3. Press to select CONFIGURE DEVICE.
4. Press to highlight PRINT QUALITY.
5. Press to select PRINT QUALITY.
6. Press to highlight FULL CALIBRATE NOW.
7. Press to select FULL CALIBRATE NOW. Wait for the printer to calibrate.
Jul 15, 2011 | HP Color LaserJet CP4005dn Network Printer
On a QL420plus, how do i adjust the darkness?
andy_arnold: You can adjust the darkness in your software desing or in your epl, zpl commands. You cant adjust it inside printer.
Jun 29, 2011 | Zebra QL 420 Thermal Printer
HP3500 all colors are printing too light - black is gray, blue is light blue, red is pink, etc. All cartridges are full, no error message on printer
Calibration is a printer function that optimizes print quality. If experiencing any print quality problems, calibrate the printer.
  1. Press (Select) to enter the MENUS .
  2. Press (Down arrow) to highlight CONFIGURE DEVICE .
  3. Press (Select) to select CONFIGURE DEVICE .
  4. Press (Down arrow) to highlight PRINT QUALITY .
  5. Press (Select) to select PRINT QUALITY .
  6. Press (Down arrow) to highlight CALIBRATE NOW .
  7. Press (Select) to select CALIBRATE NOW .
  8. Wait for the printer to calibrate.
that should solve your problem
Aug 12, 2010 | HP Color LaserJet 3500 Printer
The label prniting is not work properly, print two
you can calibrate from printer driver .Go to printing preference select advanced setup and select Calibrate
Or you can calibrate from printer.go to menu in the printer and select media and ribbon calibration it will calibrate ribbon and label
Aug 06, 2009 | Zebra S4M Thermal Label Printer
When you send a label to the printer (ql420plus) - Prints the label, then a blank, then the label, then a bland until the roll ends.
More than likely you label size is not defined properly. Please make sure you have selected the correct label on the PC side.
Jul 14, 2009 | Zebra QL 420 Plus Printer
Very Light Printer on HP Color LaserJet 3500
Table 7-33. Causes for distortion or blurring
Cause Solution
Transfer unit is defective. Replace the transfer unit. Calibrate the printer
after replacing the transfer unit. See Calibrate
Now, later in this chapter.
Defective secondary transfer roller If it does not rotate smoothly or it is deformed,
replace the secondary transfer roller.
DC controller PCB is defective. Replace the DC controller PCB. Calibrate the
printer after replacing the DC controller. See
Calibrate Now, later in this chapter.
Calibrate Now
the formatter, the color misregistration sensor (PS12), the transfer unit, or the laser/scanner.
1. Press to enter the MENUS.
2. Press to highlight configure device.
3. Press to select configure device.
4. Press to highlight PRINT quality.
5. Press to select PRINT quality.
6. Press to highlight CALIBRATE NOW.
7. Press to select CALIBRATE NOW.
hope this helps
pdouglasss
Dec 17, 2008 | HP Color LaserJet 3500 Printer
Zebra QL 420 Plus Thermal Label Printer Logo
958 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
