Question about Foxconn 650M02-G-6L Motherboard
Hi i have a P4M800P7MA-ERS2H foxconn M/B that powers up but nothingelse -doesnt boot how can i tell if its a cpu or motherboard fault ty warren
As stated it powers up but thats it,1 day its working fine then it does only this.
    Scholar:
  • 99 Answers
Normally the only way to be sure is to use a CPU that you know works in another computer and test it in the motherboard that is not working. Also make sure that everything is connected to the motherboard properly and you can try disconnecting everything except CPU, RAM, video, and power to see if the computer boots like that.
Posted on Feb 17, 2012
  • 112 Answers
SOURCE: nead motherboard oweners manuel
Goto the web page and download it from there.
Posted on Apr 02, 2008
map9966
  • 2351 Answers
SOURCE: motherboard
Are you looking for this. (click the link). Foxconn.
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?ID=en-us0000189
Manual for MS-7091
http://217.110.237.67/Manuals/Medion%208383XL%20mit%20MS-7091.pdf
If I can be of more service, just post back & let me know how thing go.
Good Luck!
Mike
Posted on Apr 29, 2008
map9966
  • 2351 Answers
SOURCE: Need Drivers
Hi jaff, to download the VGA driver software for you're Foxconn P4M800P7MA-RS2. Just click on the link below.
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=P4M800P7MA-RS2&TypeID=en-us0000004
That's it. You will see the VGA driver, click the download arrow.
Have more questions? Please feel free to ask.
Enjoy!
Mike
Posted on May 07, 2008
Roshan89
  • 271 Answers
SOURCE: can,t overclock after update bios(foxconn p4m800p7ma)
Try clearing the CMOS (CMOS reset)...and restoring defualt bios
Posted on May 08, 2008
map9966
  • 2351 Answers
SOURCE: please help me in my RAM
Hi hope13,
you had it correct the first time. The DDR2 533MHz memory should be in the Blue slots. When using two DIMMS the motherboard requires the DDR2 533MHz memory be of the same size, brand & speed. For you to get a blue screen has nothing to do with you're memory. If there was a problem with you're memory, you bios would let you know by beeping a series of repeating beeps. Blue screens are usually caused by software & some hardware like you're hard drive. If you have data on you're hard drive & you do not want to erase it by re-installing windows fresh (That includes a must format), than I can suggest you download this software from this site. Click on the link.
http://www.ultimatebootcd.com/ Read what the software can do for you. If you do not want the software. Than break out you're windows CD & load it into you're CD-ROM drive. Boot the PC to the CD-ROM drive & in-stall windows. You're PC will function again when you finish installing windows & you're motherboard driver cd.
Good Luck!
I would have posted sooner but I though another was answering you're question.
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
Posted on May 22, 2008
How do you replace the ignition switch on a 2002 buick century?
What do you mean no sound when turning key ? Does the car start an run ? Or the car doesn't crank ? Ignition switch's do not work the same way they did in the old days , especially on GM vehicles . The ignition switch is an input to the BCM - body control module , the BCM processes these inputs an then energizes relays to turn things on . Also sends messages to other modules for them to turn on or energize relays .
The power mode signal may be as simple as a B+ input wired to a particular ignition switch contact. If this is also the B+ supply to the module/device, the module/device will only operate with the ignition contact closed to B+. An example of this is the starter relay when it is wired directly to the CRANK/START contact of the ignition switch. When the CRANK/START contacts are closed, the starter relay is energized and provides a current source to the starter and starter solenoid. When the ignition switch leaves the CRANK/START position, the switch contacts open and the starter relay is de-energized. This removes the current source from the starter and solenoid and the starter operation stops.
Serial Data Power Mode
On vehicles that have several control modules connected by serial data circuits, one module is the power mode master (PMM). On this vehicle the PMM is the Body Control Module (BCM). The BCM receives 4 signals/circuits from the ignition switch. These are the Ignition 0, Ignition 1, Crank and Accessory 1 ignition switch signals/circuits.
To determine the correct power mode the BCM uses:
The state of these signals/circuits, either switch closed (B+ = 1) or switch open (open = 0)
The sequence of switch closures received by the BCM
The status of the engine run flag.
Important: Any ignition switch states not covered in this table indicates a DTC setting situation.
The chart indicates the modes detected and transmitted by the BCM:
Power Mode Selected/Expected
Engine Run Flag Serial Data
Sampled Ignition Signal State
Power Mode State
Accessory
Ignition 0
Ignition 1
Crank
OFF-LOCK
0
0
0
0
0
OFF
Accessory
0
0
0
ACCESSORY
RAP
0
1 to 0
0
0
0
RAP
OFF-UNLOCK
0
0
0
UNLOCK
RAP
0
1 to 0
0
RAP-UNLOCK
Run
0
RUN
Crank
0
0
CRANK
Crank
CRANK
Run
RUN
Fail-safe Operation
Since the operation of the vehicle systems depends on the power mode, there is a fail-safe plan in place should the BCM fail to send a power mode message. The fail-safe plan covers modules with discrete ignition signal inputs as well as those modules using exclusively serial data control of power mode.
Serial Data Messages The modules that depend exclusively on serial data messages for power modes stay in the state dictated by the last valid BCM message until they can check for the engine run flag status on the serial data circuits. If the BCM fails, the modules monitor the serial data circuit for the engine run flag serial data. If the engine run flag serial data is True, indicating that the engine is running, the modules fail-safe to "RUN". In this state the modules and their subsystems can support all operator requirements. If the engine run flag serial data is False, indicating that the engine is not running, the modules fail-safe to "OFF-AWAKE". In this state the modules are constantly checking for a change status message on the serial data circuits and can respond to both local inputs and serial data inputs from other modules on the vehicle.
Discrete Ignition Signals Those modules that have discrete ignition signal inputs also remain in the state dictated by the last valid BCM message received on the serial data circuits. They then check the state of their discrete ignition input to determine the current valid state. If the discrete ignition input is active, B+, the modules will fail-safe to the "RUN" power mode. If the discrete ignition input is not active, open or 0 voltage, the modules will fail-safe to "OFF-AWAKE". In this state the modules are constantly checking for a change status message on the serial data circuits and can respond to both local inputs and serial data inputs from other modules on the vehicle.
You probably won't understand any of this info. your best but would be to take it to a qualified repair shop that has proper diagnostic test equipment !
Sep 29, 2016 | Buick Cars & Trucks
Total battery power remaining: Unknown
Well you can try a system restore.
1.) start
2.) programs / accessories / system tools
3.) system restore
follow the on screen instructions too restore the computer to a few days before it started having problems.
Chances are that the battery is shot if system restore fails.
Mar 01, 2010 | Acer TravelMate 5720-6635 Notebook
Action replay ds
1/ With the console powered off, hold A+B.
2/ Power up the console while still holding A+B.
3/ As soon as the Nintendo screen is displayed, before our screen stating this product is not endorsed by Nintendo, press and hold Start and Select while keeping hold of A+B.
4/ Continue to hold these buttons until the Main Action Replay screen is displayed, then release. Your product is reset, and will accept codes once more.
But all the codes you had before will be gone.
It looks like the day you got it.
Oct 04, 2009 | Datel Action Replay for Nintendo DS
General error message
I would purchase an extended warranty because the problem will not just go away. It will eventually get worse
Dec 23, 2008 | GE Profile Harmony DPGT750GC Gas Dryer
Laptop touchpad
Look for a driver on dell... if that doesnt work then get a new touchpad or send it back to dell and tell them to shove it.
May 03, 2008 | Dell Inspiron 6000 Notebook
Cannot insert addresses!
Got it!! For those getting the "No Matches Found" headache. Here's the solution:1. Go to "Settings" 2. Go to "Map" 3. Go to "Map Info" 4. MAKE SURE that "City Navigator North America NT 2008" is CHECKED. It fixed the problem for me. Hopefully it will fix yours all the same. God Bless.
Apr 02, 2008 | Garmin nuvi 350 GPS Receiver
T V Shuts off by itself, after a couple of minutes.
here is some tips for ur TV which blinks 4 time.
1 Probable
Cause
Location
Solution • +13V is not supplied.
(A Board)
• IC503 voltage list is faulty.
(A Board)
Detected
Symptoms
• Has entered standby state
Solution after horizontal raster.
•Vertical deflection pulse is
stopped.
•Power line is shorted or power
supply is stopped.
this info must remady ur problem.
Dec 03, 2007 | Sony KV-36XBR400 36" TV
Picture has no Blue (sometimes)
Try taping on the top and sides to see if the set reacts and the color blue returns,if it does it is likely a loose conection and the repair should not be expensive and you already know whats wrong,if you are familiar with tv service this information will give a place to start but if you are not too familiar be safe and call fos assistance from a servicer.
Oct 05, 2006 | JVC HD-61Z575 61" Rear Projection...
Foxconn 650M02-G-6L Motherboard Logo
78 people viewed this question
Top Foxconn Computers & Internet Experts
Rommel Balcita
David
David
Gareth Cockram
Gareth Cockram
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
