Question about Garden
What kind of oil does my mower takev 6.5 briggs stratton engine troy built
  • 2,239 Answers
Most Briggs engines will be fine with a straight SAE 30 grade oil.
Posted on Feb 18, 2012
canbruce75
  • 1776 Answers
SOURCE: I have a troy bilt mower with a briggs &
There should be a drain plug on the underside of the mower deck. Raise that side of deck, remove the plug and drain the oil. Replace the plug and add new oil. Hope this helped.
Posted on Jul 19, 2009
mowerman1857
  • 389 Answers
SOURCE: white smoke and oil spewing out of troy built
Check your oil level. If it is way over full, smell it to see if it smells like gasoline. If it does, you have a carburetor leaking gas into the engine crankcase. If you recently had the mower over on its side for blade changing or inspection, you have gotten oil up on top of the piston and it should burn off in a few minutes of running. Check your air filter to see if it is soaked with oil, replace it if it is.
Posted on Sep 19, 2009
SOURCE: Troy-Bilt Briggs & Stratton 550 restarting
Troy, Unless you are using old fuel (it breaks down after 1 week) it sounds like you have a faulty spark plug. Replace this first, drain any old fuel and replace with fresh fuel (premium unleaded). A faulty plug will work one minute but then fail like you have described.
Posted on Oct 25, 2009
  • 152 Answers
SOURCE: LOOKING FOR A MANUAL FOR A 21" CUT SELF PROPELLED
try putting your serial number and model number here. http://www.troybilt.ca/troybilt/troybilt_manual_search.asp
Posted on Aug 08, 2010
SOURCE: I have a Troy-Built Series
You have to tip the mower sideways and the drain plug is above the blades on the underside of engine. It's easiest to use a 3/8 drive ratchet with an extension to loosen the drain plug that typically has a 3/8 square recessed hole.
Posted on Sep 08, 2010
What kind of oil do I need for a troy - ilt 675 series
do you mean a briggs & stratton 675 series engine? if so it SAE 30 oil
Apr 29, 2015 | Troy Garden
Wiring diagram for a 250cc 11.50 briggs and stratton engine on a troy built wood chipper
http://www.briggsandstratton.com/us/en/support/faqs/horizontal-shaft-replacement-engine-specifications
Jul 11, 2014 | Parks Optical 13.5hp Briggs And Stratton...
I have a Troy-built gtx2654 lawnmower with a Birggs & Stratton engine mod 47777 typ.0229E1 want to troubleshoot charging sys.
You can test the charging system by starting the mower and then unhooking the negative terminal from the batter, if the mower stays running, the charging system is working, if it dies immediately the charging system is faulty, you can also use a tester at the engine to test the voltage at the connectors
Oct 12, 2013 | Briggs & Stratton Briggs Stratton...
Valve adjustment on 23hp troy built mower
Model, Type and Code are required if this is a Briggs and Stratton engine. Thanks; George
Apr 21, 2013 | Briggs & Stratton Garden
What kind of oil is used in crank case for a troy built 5 hp rotortiller?
If the engine is a Briggs and Stratton use SAE 30 only. If you run synthetic, (which I recommend) then you can use a multi-viscosity oil like 10W-30 or 10W-40, but only if using synthetic.
May 20, 2011 | Garden
What kind/type engine oil for the 17.5 H.P. Troy-Built Pony garden tractor?
sae 30 weight is used for most garden tractor engines. This is straight 30 weight oil not a multigrade. Most big box stores that carry this kind of gear have it.
Feb 16, 2011 | Briggs & Stratton Briggs Stratton Intek V...
I have a Troy-Built Series 550 mower with a Briggs & Stratton engine. I cannot find the drain plug. Is there a good diagram available?
Most professional shops no longer drain the oil through a drain plug because of all the covers under the engine. With your Briggs and Stratton engine, the best way is to drain through the dipstick. You can purchase a suction device to **** out the oil, or you can drain it. To drain, place you mower on the tailgate of your truck, or on the picnic table. Grab a drain bucket, remove the dipstick and tilt the handle to the ground. The spark plug should be pointed straight up into the air. Might be a good idea to do a test run before removing the dipstick, so you will know exactly where to hold the bucket. All 20 ounces of oil will drain through the dipstick in about a minute if the engine has been warmed up. Refill with a good quality SAE HD30 weight motor oil. Remember...only 20 ounces. Check the oil level after filling before you start the engine.
Good luck.
Sep 08, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Misplaced operation manual for Troy-Bilt Briggs & Stratton Super Tomahawk Chipper/Shredder 8 HP Can it be downloaded? What kind of oil does the chipper use?
Straight 30w NOT 10w-30
prefer air-cooled engine oil from mower dealers or some auto supply stores have air cooled engine oil.
Oct 07, 2009 | Troy-Bilt® Briggs and Stratton Chipper
White smoke and oil spewing out of troy built briggs and stratton 650 series 190cc mower
Sep 19, 2009 | Briggs & Stratton Garden
Garden Logo
67 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
