Question about Dryers
Wiring placement inside housing on ceiling fan
Got it all wired up, just can't seem to get the right placement of everything to go back up in the housing and screw the light fixture back on to the housing.
Hi Steven
Would you happen to know how I can modify the wiring of an Xpelair DX100HP?
I have an external switch, with which I can switch off the fan. When I switch it on, I want it to run by the timer, or by the humidistat if needed. I want to cut off the pull cord.
However, I have only 3 wires from the external switch to the fan, two of them carying power. Can I use the 1 unused wire to activate the timer?
I was thinking to modify the internal wiring so that, when it receives power, it will start through the timer and then stop untill trigerred by the humidistat.
Any ideas?
Cheers
Lode
Posted on Nov 01, 2012
    Problem Solver:
  • 17 Answers
Is this a small fan around 120mm square, if so you need to ensure that the wiring is run in from the correct wiring inlet, there is usually a small spigot the wiring has to go round too, otherwise cover catches wiring. This is general on Xpelair, Vent Axia and GET fans.
If this doersnt help, let me know what the fan is, ie; model No
Posted on Feb 17, 2012
Wires coming out of ceiling to connect ceiling fans with lights
I don't know what the question is! I don't know that fan but if it's a ceiling fan & you only have one hot wire then you would wire it this way; White to white, green to green or ground, & black & blue from fan to black house wire.
Aug 16, 2014 | Dryers
CONNECTING WIRES FROM CEILING TO WIRES IN CEILING
Don't know that fan because it's a low-end store brand, But, if it has no remote;
White to white
black to black
blue to red ( usually)
If no red wire in ceiling then put black & blue to black house wire.
Sep 06, 2013 | Hampton Bay 24002 Ceiling Fan
Tail light wires
I just solved my identical problem on a 2003 750 ACE. The four way connection in back of the license plate housing was pushed inside the back of the housing with the left turn signal wire crimped a little between the housing and the fender (probably at the factory)., It wasn't crimped enough to break the wire, but just enough to apparently short out the circuit. The clear vinyl cover was melted just a little bit where the wire was crimped but it didn't look like there was enough damage to cause a short. I stripped the clear vinyl cover off, taped it with electrical tape, and made sure that all of the wires were pushed inside the back of the housing. Everything works, plus the 15 amp fuse doesn't blow anymore. Hope this helps.
Rick.
Aug 19, 2012 | Honda VT 750 CD Shadow A.C.E. Deluxe...
I installed model 27303 ceiling fan with light. I had an electrician inspect the wiring to make sure everything was wired correctly, and it was. With the power on the fan/light operates with the remote...
Is it possible that there is another remote, either yours or a neighbor's, close enough to operate it?
I installed a remote operated ceiling fan & it is hard wired, there is no switch. If that happened to me, I'd be stuck never knowing when it will come on.
Can you change the remote code?
Gary
Aug 25, 2011 | Hunter Dryers
How do I get the wires out of the old 3 speed ceiling fan switch so I can replace it with a new one?
Usually, there is no way to remove the wires from the switch. Turn off the circuit breaker that powers the circuit going to your fan. Then, match up the new switch with the old one to make sure you have the correct one, with the correct amount of wires. Mark the placement of of these wires with masking tape or draw yourself a diagram. Next, you need to cut the wires as close to the old switch as possible, and strip back about 1/2" of the insulation on these wires. Now connect those wires to the leads (wires) coming from the new switch with small wire nuts or crimp fasteners. When connecting the cut wires to the new switch leads, follow the same pattern as the old switch (refer to your masking tape labels or your diagram). Now you can secure the switch to the fan casing with it's locknut, and carefully tuck the wiring back inside. Re-secure the casing to the fan.
Aug 01, 2011 | Speed Ceiling Fan 3-speed Switch By...
I have the Hampton Bay Ceiling Fan and Remote. Model UC7083T. My son was playing with the battery cover and i think he moved the switches. The problem is i don't know what their original position was....
You have to go inside the actual ceiling fan. If you look on the part right above the light, there should be 3 or 4 screws in the side, connecting the light setup to the body of the fan. Unscrew those screws and disconnect the wiring harness. Inside the now open fan wiring, you should see a little box, that is the remote receiver. Either on one of the sides of the box, or inside that box will be the code. It will look just like the code switches on the remote. Make sure they match up, clip the wiring harness for the light and the fan back together, screw those screws back in, and you should be good to go.
May 09, 2011 | Hampton Bay 24002 Ceiling Fan
Our switch for the ceiling fan burned out today. Instead of getting the same type of switch (rotary knob with push on/off) I bought a Pass & Seymour combination toggle switch (dual on/off toggle...
The wire to the ceiling fan are meant to send voltage to the fixture only and are not usually wired to control both the light and the fan independently. In order to do that, you may have to pull another set of wires to the switch box and then connect them to the light circuit in the box where the fan is. In regards to the other wiring that you mentioned, it makes no sense that the wires go to the stove fan and the bathroom fan unless those wires are source wires that carry the incoming voltage.
Mar 17, 2017 | Pass & Seymour #690IGCC6 15A Ivory DPLX...
I installed a ceiling fan with light, fan works but notthe light.
Are you sure you got the wiring correct?
Ceiling fans usually have 4 wires....a black a white a blue and a green
the black & blue wire from the fan need to be connected to the black wire the white to the white and the green to the ground
Sep 18, 2009 | Hampton Bay 52 In.Carriage House II in...
Need to replace socket in Hi hat ceiling fixture
Do you have a discription? In order to get to the main wires of a flush mount fan turn off power to fan, remove Lt kit if applicable, Take off blades. Does this sound right ?
Nov 13, 2008 | Electrical Supplies
Dryers Logo
69 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
