Question about Epson ACULASER CX11NF All-In-One Printer
Release carriage lock - Epson ACULASER CX11NF All-In-One Printer
  • juan bustos Feb 17, 2012
    where is located the carriage lock
    President:
  • Epson Master
  • 2,017 Answers
Kindly go thru this link it has all the guidelines
http://files.support.epson.com/pdf/cx11n_/cx11n_ss.pdf
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Posted on Feb 18, 2012
Olivetti Lettera 22 Typewriter carriage does not move
There are two ways to deal with that (before taking you olivetti to an authorized dealer):
  1. There's a lock key under the carriage. Have you unlocked it?
  2. The carriage might have been locked by a piece of paper or something else. Release it (pull it) and clean its passage (there is a button you press in order to release it - proceed with care).
Apr 09, 2016 | Olivetti Office Equipment & Supplies
Epson 4000
The error relates to a carriage movement error detected by the printer. This means the printer has detected too much power is required ti move the print head. Reason : All these Service Requests (Service Requests 00010004 , 00010005, 00010006, 00010007, 0001000A, 0001000F, 0001001D) are related to a Carriage movement error that is not automatically due to a Hardware fault. The reasons can be : - The carriage is lock not completely released. - The carriage lock has been partially pushed in after a paper jam or maintenance (for example). Reminder : The carriage lock must be released after unpacking the printer (see setup instructions) as follow : Points to check : In case such an error appears: - Power off the printer. - Ensure the Carriage lock is released (pulled to the left side) - Pushing down the cutter blade, slide the carriage to the left ? At the same time, please check if there is any foreign materials / dust / paper jam in the carriage path. If so, remove them. - Also, make sure that the carriage encoder (T-Fence) isn?t dirty and is correctly set and centered. Let me know how you get on with this info.
Aug 17, 2007 | Epson Stylus Pro 4000-PS InkJet Printer
How to unlock electric type writer?
Christine: According to VintageTypewritterShoppe.com: "Underwood portables have a simple carriage catch on the left side right below the carriage. Move the carriage to the right a few inches to disengage. Remington portables have two systems. Early portables require the sliding out of the platen shaft/knob on the right end of the carriage. The lock lever is located on the left end of the carriage and is spooned against the left side carriage release lever. Newer Remington's(Model 5/Streamliner/Deluxe) have a small lever on the left end of the carriage located in the same spot as the earlier models. There is a little ball on top of the lever. Push the lever to the rear to disengage the lock."
May 18, 2015 | Office Equipment & Supplies
Where is the lever that releases the carriage on the olivetti 32
There is a chrome lever on the right side of the carriage on top that should manually release the carriage by pushing down on it. If this works but there is no spring tension pulling the carriage to the left, then the drawband is probably broken. If pushing the lever down doesn't work then eithor the mechanism is broken or locked up or there is a carriage lock that need to be released. If there is a carriage lock it would be located under the carriage on the left or right side. It would be a small chrome lever sticking out the side.
Apr 15, 2013 | Office Equipment & Supplies
Epson stylus SX 200 one of my cartridges isn't working correctly but how can I change it when no indicator light is showing?
Release carriage lock, and move carriage to replacement position. If you can not remove the lock, then turn on the printer and immediately unplug power when the carriage is moving.Then move the carriage by hand to the replacement position.
Oct 06, 2011 | Epson Stylus Multifunction Inkjet Printer/...
I am Eric, I have this error message on my epson stylus pro 9600, SERVICE REQ. 00010004
Service Request errors in the range 00010004 - 000101D are related to a carriage movement problem. In some instances like paper jams, the carriage locking tab may be partially pushed in, causing the carriage locking mechanism to put a drag on the carriage or lock the carriage completely. This will cause a carriage error. Make sure the carriage locking tab is pulled to the left. Then turn the printer's power off and release the carriage by pushing down on the cutter blade. Slide the carriage to the left and look for any paper that also may be restricting the carriage from moving freely.
00010004 CR Motor encoder check error
Hopethis helps. If it does, please accept and rate the solution! Contact me withany more questions you may have. Thanks for using FixYa!
Jun 24, 2011 | Epson Stylus Pro 9600 InkJet Printer
I have an epson 4880 with an error reading "service req. 0001001d" How can I fix this
00010004 CR Motor encoder check error 00010005 CR Motor out of step 00010006 CR Motor over current 00010007 CR Motor in-position time-out 0001000A CR axis detection error 0001000F CR Motor PWM output faulty 0001001D CR servo parameter error
The T-Fence may also be dirty or out of the carriage encoder. Check to make sure it is clean and in the center of the encoder. Contact Epson for additional assistance.
May 09, 2011 | Epson 4880 Stylus Pro InkJet Printer
Olivetti Lettera 32 typwritter carriage doesn't move
If the locking lever is off, then the carriage is bound, or one of the tabs is hung, try releasing all the tabs, pushing the space bar or the tab key while gently moving the carriage.
Try all of the function like shift while gently pushing on the carriage always to the right..
also check the that the margins are not locked.
This could be a lot of different things...
Dec 18, 2009 | Olivetti Lettera 35 L Typewriter
Can't move cassette carriage.
hello savvychris
If you can not get to the carriage motor, can you get to the one of the gears attached to the motor or the carriage gear itself. either of these should allow you to release the carriage.
Can you post some pictures of the carriage, this includes front, top, and side shots? what I am looking for is a way to advance the main motor forwards and thus release the carriage locking system.
If possible, if you have the technical documentation, send me a copy of it, I might be able to figure out what is going on for them.
Thank you,
Shuttle83
Jul 05, 2008 | Televison & Video
How do you unlock a locked carriage?
The solution is not right--there is a carriage return release lever on the far right of the typewriter, that engages a notch on the underside of the roller/carriage return--push it forward to release the lever and you are in business--it has a spoon shaped end and its on the right side
Jan 24, 2006 | Olivetti Lettera 35 L Typewriter
Epson ACULASER CX11NF All-In-One Printer Logo
276 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
