Question about Refrigerators
How do I pull out the refrigerator Norcold model #N811RT in or travel trailer to get to the Reset Button Refrig is not working
  • 51 Answers
SOURCE: norcold rv refrigerator freezer
Make sure the thermister is attached firmly to the fins in the back. The boards on a Norcold can be reset a service center familiar with this process is your best bet. It takes disconecting the board and then shorting it out best to leave it to some one who is familiar.
Posted on Sep 08, 2008
Gort007
  • 1187 Answers
SOURCE: How do you reset circuit board on norcold refrigerator
No way to do that other than to unplug refrigerator for at least ten minutes and then plug back in. Don't use surge protector, power strip, or extension cord.
Posted on Sep 21, 2009
motor1258
  • 6674 Answers
SOURCE: need instructions on how to light a rv Dometic refrigerator-
Go to this link and download 2600 PDF, last few pages are operation.
http://www.dometic.com/enus/Americas/USA/Customer-Support/Operation--Installation-Manuals/
Posted on Jun 27, 2010
SOURCE: RV model norcold n811rt not cooling
I have a norcold fridge model #N811RT and the flash code blinks 5 times then stops then repeats. both fridge and freezer are not cold were are currently living in are 5th wheel and it was currently -30c for 3 days any help would be of assistence.
Colin
Posted on Nov 25, 2010
tunde007
  • 2382 Answers
SOURCE: I have a Norcold fridge
Hi, if the light is on, but flashes off 5 times about every 3 seconds. The refrigerator cooling unit has stopped cooling.
1st time - Before you reset
Check: - That the vents are not blocked. - That a door(s) is not open. Close door(s). - That the vehicle is level.
2nd time - After reset This is not owner serviceable. See your dealer or authorized Norcold Service Center.
There is a large reset button that is easy to locate and use, so the Norcold can be reset in just a few minutes, without much hassle.
Take the unit out of its resting spot and turn it around so the back is facing you.
Use a rag (or canned air) and get all the dust out of the back of the unit. Dust can hamper the reset, and can also lead to further problems with the Norcold unit.
Look for the large red "Reset" button, near the top. Pull the tab, and the Norcold will turn off for a few seconds and will then turn back on.
Place the unit back into its resting spot.
Posted on Feb 17, 2011
A travel trailer with norcold refrigerator comes on but want get cold
probably needs freon added . see a refrigeration person
Oct 03, 2017 | Refrigerators
I have a Norcold Model N811RT. Freezer and refrigerator stopped cooling and freezing. Days later they're working. I live fulltime in the RV, is there something I should check?
I would check the evaporator coil and see if it is occluded with dust and dirt. Freezing up is usually the result of inadequate air flow over that coil. It looks kind of like a car radiator. You can buy evaporator, and condenser coil cleaner on Amazon. I do this every year to both of mine, it makes a huge difference in output.
Jan 13, 2017 | Cars & Trucks
Norcold fridge model N811RT 5 blinks on light code what is the problem
This would be a great answer if you also provided instructions on how to 'remove the unit from it's resting spot'.
Thanks!
Dec 04, 2011 | Refrigerators
Smelling burnt gasses
Make sure your roof vent is not clogged immediately. If you are in a full service park, you should be running on electricity not propane. You don't describe the gasses you are smelling, if it is ammonia, your frig is probably done for.
Ammonia is the primary ingredient in the cooling process. What happens is the ammonia is boiled and then sprayed throug an orfice. The spraying creates the cooling (heat removing) effect. If you are smelling ammonia, your boiler has developed a leak.
You can purchase replacement units to install in your present frig. Some people have success with this. My experience was not so good. I spent about $225.00 plus shipping for a rebuilt unit (with a 'core' charge). I did the work myself. I got about a year out of the rebuilt unit before I simply replaced the frig with a new replacement 3 way Norcold. My new Norcold was much improved over the earlier model and included a ice maker! It was expensive, however, at more than $1300.00. Find sources for replacement cooling units for your "Thetford" refrig at FixYa.com advertisers or through your RV dealer or in the back of travel trailer magazines.
I hope this is NOT your trouble and I hope you find resolution. Thank you for your interest in FixYa.com and please come again.
Jul 24, 2011 | Thetford RV Refrigerator - N300 Model -...
Want to reset board on N611 norcold ref
The Norcold board reset is done by jumping a pin terminal to ground. There are several steps involved but it's all pretty straight forward. Here is an article on the steps of doing this: Norcold Refrigerator in Lockout Mode do you need to reset your power board
Jun 09, 2011 | Thetford Refrigerators
Norcold N1095 model stopped working during very cold weather spell. No defaults codes at all showing--just will not cool down. AC and LP both work fine. Refrig just stopped cooling. Contacted norcold...
I have the same problem with my extra fridge in the garage. It has to do with the oil used as a refrigerant in newer models. The cold temprature thickens the oil and it stops cooling. Nothing you can do about it other than opening the door to the fridge to warm the insides up. It works for me. And thank god it's only when it gets very cold outside that this happens. Ps...my garage is insulated and drywalled and it still occors during cold spells.
Dec 17, 2009 | Refrigerators
Colin
Aug 03, 2009 | Migali Refrigerators
Norcold Fridge will not work on LP gas while traveling.
One of two problems. The auto switch is bad or the lower circuit board is not doing its job. You can call norcold technical or take the board to a service center and have it checked with the tester they should have. The lower board retails for 176.00. I looked at my tech file and it is a little vague on your particular situation. If I were repairing your fridge I would take the smart route and call technical. Hope you get your problem solved. If you need more help please feel free.
Regards
Mar 24, 2009 | Dometic NDR 1292 Refrigerator
Norcold rv refrigerator freezer
Aug 16, 2008 | Dometic NDR 1292 Refrigerator
Refrigerators Logo
109 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
