My case is Azza Orion 202EVO and it has the large red/black/yellow wires going into the 1 in white connector that on one end has 4 female connectors and the other has 4 male connectors. My motherboard has the the Chassis Fan connectors as the 4 real tiny pins that are approx. 1/2 in across
The connection for the fan in that case connect directly to your power supply, not the motherboard. You can get an adapter that would work, but it would be easiest and best to just plug it into the power supply.
Testimonial: "Thanks! i thought I should have to connect to both... You've put my weary mind at ease!!! "
SOURCE: chassis intrusion
You need to check the chassis intrusion pin setting located on the motherboard. See page 1-30 (Number 11) in your manual.
You need to add a jumper as shown.
The system should no longer halt.
Cheers!
Mike
SOURCE: what is chassis intruder
Chasis intruder is a warning that your CPU has been opened by someone
it is normally used to warn you against unautorized BIOS or SYSTEM PASSWORD removal
There is a switch in your casing that detects this.
Leave this setting to enabled (recomemded)
Thanx and i hope this info is helpfull
Please dont forget to rate this solution
Just to add; Here is a pictorial guide showing the various Power Supply cables, and details of their functions. Scroll the page down to see all, and click on each photo for more in-depth info,http://www.playtool.com/pages/psuconnect...
