Question about AEG Lavamat 16810 Front Load Washer/Dryer
My aeg lavamat L washer/dryer has suddenly stopped working and there is no power
It stopped suddenly after using the tumble dryer. Display unit no longer lights-up and whole machine has gone dead. We have changed the fuse and checked the electricity which is ok.
Sorry this isnt a solution .. Im just wondering if you did manage to get this sorted as it happened to my machine this morning?
Posted on Jun 27, 2012
rizla
  • 1463 Answers
SOURCE: AEG Lavamat 1000
hi
dont know if this is the one you need AEG 1000 Washing Machine
you may need to scrool down to download the manual .
riz.
Posted on Mar 03, 2008
  • 44 Answers
SOURCE: AEG Lavamat Turbo 12830 - error code E20
Hi
E20 means there is a bolckage in there
remove filter and clear any debris in there and check impeller is turning ok.
regards
Posted on Mar 21, 2009
  • 44 Answers
SOURCE: AEG 16820 Lavamat-turbo
Hi
this sounds like the fill vavle is fauty you can check this if you have a muiltmeter.
remove lid and unplug the green soliaod and check to see if open circuit.
if so replace and should be ok.
regards
SOURCE: I have an AEG Lavamat 16820 washer dryer and the
The lock is rubbish on this machine but as a temporary measure you can feed a string down behind the door lock from the top and out the bottom. Then yank it to the left to open the lock. It will take a few tries but you get the hang of it!
We got sick of this so ordered a new lock off the net. I basically had to break the old mechanism to fit the new one because the door layers were so strongly glued together. Now fitted, the lock works perfectly but the machine thinks the door's open the whole time! Next step is either new door or new machine. Great.
Posted on May 12, 2009
SOURCE: My aeg lavamat 16810 washer dryer won't dry. The
I had the same problem and fixed it by replacing the triple valve. One of the inlets passes water to the condenser and this had failed. You can tell this by opening up the top and when the drier starts you here the drain working and then should hear a gentle hiss as the water is let through. If you don't hear anything then after 10 mins you get the E10 error. It cost me £27 which is cheaper than getting a new machine or a call out charge. If you feel competent then all you need is a philips screwdriver, pliers to get the clips off and a flat head driver to remove the rubber hoses.
Posted on Nov 11, 2009
Just purchased 2nd hand Miele novotronic w310. Does machine automatically stop? Cycle ends, anti crease light on and machine just tumbles clothes makes odd noise, then tumbles again. Is the normal?
NORMALLY WHEN A DRYER COMPLETES IT'S DRYING TIME IT WILL GO THROUGH A COOLING DOWN CYCLE,
DRYER WILL START TURNING WITH FAN ON ONLY FOR A FEW SECONDS THEN STOP, AFTER A SHORT PERIOD IT WILL DO IT AGAIN AND AGAIN UNTIL UNIT HAS COOLED DOWN, HOPE THIS IS WHAT YOU ARE EXPERIENCING
GOOD LUCK
Sep 22, 2016 | Miele Washing Machines
Why is my Zanussi dryer stopping after 4 minutes it is heating and tumbling
As you are aware, every year manufacturers of products in this country try to make their products safer, and in the case of clothes dryers, they try to make them less susceptible to fires from accumulated lint.
To that end, it is probable that your clothes dryer has accumulated lint internally, and either some fuse (or fuses) or one of the "shut-off-thermostats" is kicking in every time you start it.
Someone will need to take the whole machine apart and clean out the lint, and check the fuses and thermostats with an electrical tester.
The lint that accumulates is not caught by the lint screen, it is throughout the inside of the machine in the tubing.
God bless your efforts.
( P.S. I have taken several machines apart and found a whole shoe-box full of accumulated lint inside.)
Jun 30, 2016 | Zanussi Dryers
Hotpoint ctd40 tumble dryer gone dead changed the fuse still dead any ideas ???
Check the mains lead for continuity! Thats making sure the lead to the dryer is not broke anywhere internally.
It may mean removing panel to get access to where the mains lead goes into the dryer, You can do this with power off, check with a multimeter that both the brown wire and blue wire as well as the green and yellow earth wire has continuity from the plug to the dryer!!
Mar 27, 2016 | Hotpoint Dryers
On an aeg lavamat washer dryer l12710 where is the filter for the dryer I have cleaned the front one for the washer ?/
If you go to www.aeg.co.uk and look under "service and support" you will see a box to insert your model number. I've put your model in and there's service manuals in several languages. Happy hunting.
Nov 03, 2014 | AEG Lavamat 12710 Front Load Washer /...
How do I fix my AEG Lavamat T57800 dryer
E51 - Motor power triac short-circuited
Motor faulty ; Wiring faulty ; Electronic board faulty ; Motor capacitor ; also check tension of belt
Dado
Jul 15, 2014 | AEG T57800 Electric Dryer
Lavamat 12843 no power
Maybe a bit late by now noting your question date.. If you have L & N from supply through suppressor to pcb it could be board u/s but well worth checking for low insulation on elements as oddly this can cause the display not to light!. If you don't have a suitable meter disconnect all wires to elements and see if it works.
May 08, 2014 | AEG Lavamat 12710 Front Load Washer /...
AEG Lavamat 64809 error code E30
Lavamat?! Where in the *&%^ is this machine from? Yugoslavia! I'm guessing it will not allow water IN Because only the Spin (Centrifuge) cycle works?! So if that is so you need your water inlet valves replaced, there are Two. Even in machines named after a Bar of Soap!
Jan 04, 2014 | AEG Lavamat 16810 Front Load Washer/Dryer
Vhv680f hoover tumble dryer not turning on
-There are couple thing cause this problem.
Here try this if you are basic repair person.
-disconnect main power.
-Open back panel cover.
-Check all thermal fuse. Possible 3 (if open replace new one)
-Check heater element. (If open replace new one)
-Check door switch. (If open when door is open, replace new one)
*If every thing is good. How about the timer switch. Dial to on position and check continuity. If open replace the whole assembly.
-You can t get these part from difference places like
-Part appliance, Reliable part or Amazone.
Good Luck\
Mai
Dec 20, 2013 | Dryers
Dryer suddenly does not heat and dry clothes.
sounds like a tub wheel that the drum runs on may be bad ,youll have to take the front off and look,check for a burnt wire at the heating element or the heating element itself
Jan 15, 2013 | Kenmore Dryers
AEG Lavamat 16810 Front Load Washer/Dryer Logo
622 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
