I have a T.V. RCA model #32V420T,manufacture date July 2005. It quit, does absolutely nothing. Does this have a reset button or something I could check? The fuse lookd good.
  • 899 Answers
It will need to be tested to determine the cause
Posted on Oct 26, 2008
Mitsubishi WD-52525 was working fine and now it will not turn on
This is just a shot - but it worked with my Sony (same problem).
Pressed remote power on button AND held Power button on TV on at the same time.
Set clicked 4 or 5 times and then came on....
Other, most have a (VERY small) reset switch on the rear - near where the power cord enters the TV... Use a flashlight and a mirror to locate it on your set....
Nov 26, 2009 | Mitsubishi WD-52525 52" Rear Projection...
GE Tv, replaced flyback... still nothing.
Have you ck 3 capacitors on deflection board cp150 2200uf 16v, if it is bad other 2 caps are 220uf 35v cp114 cp120 Your TV is really a RCA
Sep 16, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
RCA Scenium HD50LPW166XY1 DLP Projection HDTV ''scream''
RCA has discontinued the color wheel for your model and its on nationwide back order, so you cant buy the replacement. You can get your color wheel rebuilt at the following link and the rebuilt color wheels are fully guaranteed.
http://servicemanuals.vstore.ca/product_info.php/pName/rca-color-wheel-267888-rebuild-option/cName/color-wheels
Jun 14, 2009 | Televison & Video
Rca rear projection broke?
This may help with yours since it was built in 99
Product Safety Information Product Safety information is contained in the appropriate TCE Service Data covering models/chassis referenced herein. All specified Product Safety requirements and testing shall be complied with prior to returning equipment to the customer. Servicers who defeat safety features or fail to perform safety checks may be liable for any resulting damages and may expose themselves and others to possible injury. First Edition ¾ First Printing Copyright 2000 ¾ Thomson Consumer Electronics, Inc. Printed in U.S.A. ¾ Trademark(s) ® Registered ¾ Marca(s) Registrada(s) Symptom: Shutdown during channel change, shutdown during autoprogram, dead set or unexplained random shutdown. Cause: Incorrect F2PIP Power on Reset (POR) timing Cure: Product Support · Mail Stop INH 900 P.O. Box 1976 · Indianapolis, IN 46206 -1976 TV 00-003 Television TTI TV 00-003 MODELS: CTC195/197, MM10x, CTC203 Chassis with F2PIP DATE: July 14, 2000 TOPIC: F2PIP The following modifications are required to change FPIP POR timing for added reliability. NOTE: All chassis manufactured after 950XXXXXX have the modification installed. Follow these steps in order. All CTC195/7 – All CTC203 1. Insert a 2.2K ohm 0805 size SMD resistor from pin 21 of U18100 to ground (192096). Note: This may require “piggybacking” the resistor on top of C18114. MM101 Chassis 1. Insert a 2.2K ohm 0805 size SMD resistor from pin 21 of U18100 to ground (192096). Note: This may require “piggybacking” the resistor on top of C18119. The next steps are dependent upon the chassis under repair. CTC195F, F2, F3 chassis 2. Replace R18111 with a 100K resistor (192084) 3. Replace C18118 with a 330nf cap (220132) 4. This concludes the modifications for these chassis. CTC195/7 (except CTC195F,F2,F3) and all CTC203 2. Replace R18116 with a 100K resistor (192084). Both are off pin 23 of U18100 3. Replace C18121 with a 330 nanofarad cap (220132) 4. This concludes modifications for these chassis. MM101 Chassis No further modifications are necessary.
Apr 02, 2009 | RCA P52921 52" Rear Projection Television
The tv just randomly turns off by itself
Check to see how many times it blinks when turning off and then look for the codes for Sony tv blinks. this will tell you what's wrong. This set is notorious for Shorted tubes.
Feb 27, 2009 | Sony KP-57WS500 57" Rear Projection...
RCA T.V. model #32V420T, manufacture date July 2005. It quit, does nothing, no pop humm lights nothing. Does it have a reset button or is it dead? Thank you for your time.
be sure to check the plug and wall socket first if there is no problem there , then a fuse in the tv went or there is a component problem and it will need to be tested to determine the cause of the shut down , then you will need to call your local repair shop to see if they can fix it at your home or they will take the main board in for the repair
if you need any more assistance don't hesitate to ask
electech
Oct 26, 2008 | Televison & Video
FLASHING GREEN LIGHT CONTINUOS, NO PICTURE OR SOUND
check your lamp and see if it is either broken or the filament is black on any part
Aug 01, 2008 | Akai PT46DL10 46" HDTV-Ready Television
HELP MY TELEVISION HAS NO POWER!!!!!!
have you checked the fuse inside the powersupply ? Where the power cord enter into the Power Supply.Or look for a red or black button that says reset.
Jul 30, 2008 | RCA P61960 61" Rear Projection Television
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Electro Med Services...
