Question about Traxxas 4910 T-Maxx RC Monster Truck
Traxxas tmax ezstart problem turns engine but no spark has soon has i swap to a seperate glo starter it works
2000 rav4 2.0 Diesel engine turns over but does not start
run the fault codes first.
may be air in the fuel system
does the starter spin the engine fast ( slow cranking speed will not start a diesel)
are the glo-plugs working
Mar 10, 2015 | Cars & Trucks
Traxxas Monster truck won't start
i always gave mine half throttle for 2 pulls, attatched the glow plug batt, and bam, started right off next pull
Feb 25, 2013 | Traxxas T Maxx 3.3 Monster Truck
Have a glow plug light and motor light wont start
if you cant turn the engine over with the pull starter, you have locked up the engine by running it too lean and hard, a rebuild is in your future
Dec 05, 2012 | Traxxas T Maxx 3.3 Monster Truck
I have a problem with my 1998 yamaha125 breeze atv, i think the engine is turning over backwards, there is an arrow on the flywheel, pointing to the front of the bike, does that arrow indicate engine...
most engines turn the same way, looking from the left side the flywheel turns anticlockwise.
never checked for spark on a backwards turning engine, I guess it should still spark
Jul 08, 2011 | Yamaha Vorona Motorcycles
I have a tmax 3.3, and I was driving it and ran into a curb and the engine rev'd up to high rpm and wont stop, when I start it up it still runs at a high rpm and it will not move, but when I pick up the...
Check the throttle servo linkage to make sure it is not damaged or binding. Also make sure that the throttle servo is going back to neutral position and did not get damaged.
Aug 16, 2010 | Traxxas T Maxx 3.3 Monster Truck
Car is not starting. Engine is not turning over. Has a half tank of gas and good battery. Ideas for a quick fix?
try hitting the starter with something, hammer,steel rod, several times, if this makes it turn over, your starter is bad, and you can jump the starter smaal lead to large lead if it just sparks and not turn it's bad can also swap starter relay to see if it is bad, check crank fuse, ifnone of this works you have wiring problems
Jun 14, 2010 | 2002 Nissan Sentra
Truck won't stop cranking
starter selonoid is stuck
Feb 17, 2009 | 1983 Chevrolet S-10
1990 Lexus LS400 won't start. No check engine light.
check the fuel filter or the air filter they may be clogged and check fuel pressure
Nov 12, 2008 | 1990 Lexus LS 400
Traxxas 4910 T-Maxx RC Monster Truck Logo
66 people viewed this question
Top Traxxas Toys Experts
Michael Brisco
Level 1 Expert
gbob59
cwradio73
Are you a Traxxas Toy Expert? Answer questions, earn points and help others
