Question about Bissell LiftOff Revolution Pet Vac 37602 Vacuum
No suction, getting hot
Motor runs. very little suction. unit gets hot
Stanley 3.5 wet/dry vacuum motor runs but suddenly suction stopped just like it does when tipped over, but didn't tip over
ck ball that saves the motor when container gets full of water , they sometimes get stuck inside the little cage there in an shut off suction
Jan 19, 2016 | Stanley 3.5-Gal. Wet/Dry Vacuum
I have changed the hepa filter & made sure the washable filter is clean. I checked the brush & it's working fine. The indicator is still red very little green. Not suctioning good at all. What...
check the suction hose where it bends down to the floor unit,, lots of times dirt,hair and stuff collects there when the filter was plugged up. remove the floor plate ( like you were going to change the belt ) and use a wire coat hanger to run up the suction hose and back out and clean out any debris, also check the entire hose for blockage ( top to bottom ). if this is all clear and you still have little suction - then the problem could be the vacume motor itself and you will need to take the unit into the repair shop and have the motor rebuilt or replaced.
c..
Feb 02, 2011 | Bissell 3920 Bagless Upright Vacuum
Have a nutone CV-450. Suction is gone at the
The first thing to do is to disconnect the pipe coming into the unit. If there is suction there than you probably have a break in the line. If there is no suction when you disconnect the pipe coming into the unit than it is most likely the motor gasket. This gasket can sometimes get sucked into the motor causing problems. Remove the lid to the central vacuum, than disconnect the motor, you should be able to tell if maybe the gasket has been off center or if it has been sucked up in the motor.
Dec 13, 2009 | Broan-NuTone CV450 Central Bagged Central...
The region of the motor gets very hot during use. What can I do?
The Hoover is likely built with a temperature overload protector, to shut down the unit if it gets excessively hot. All the units will get heat build-up from the suction motor during use.
Sep 29, 2009 | Hoover Vacuums
DC25 Overheating after a filter cleaning
you need to not use this until you get it fixed at a vacuum store.they can probably help you with it.might be there is a short or a little water got on the motor.
Jun 29, 2009 | Dyson DC25 Vacuum
My Bissell Little Green won't spray the solution. The suction seems to be working fine and the lines are all connected as they should be. What's up and how can I fix it?
I also had the same problem as you.
Try suctioning up a full tank of hot tap water into the collection tank to soften/release a possible kink in the tubing inside of the vacuum hose that carries solution out to the spray tip.
I did this a couple of times and it worked. This info I found on the Bissell website.
Good Luck!
Aug 15, 2008 | Bissell 1425 Little Green ProHeat Handheld...
When the vaccum is running the motor gets hot & smells & is very noisy.
Sounds like yu may have a clog, either in the inlet by the brush roll, or the hose. If the hose comes loose, see if there is suction there. If no suction then it is clogged. If suction, then the inlet maybe clogged.
Jul 22, 2008 | Dirt Devil Reaction Twin Cyclone Upright...
Electrolux central vac problems
I work on many types of units. If you electric floor brush runs but you have no suction then there is possibly a problem with the relay board that allows you to turn on the suction from the hose handle. This is a low voltage (24 V) switching loop circuit that will cause the 120 V motor in the unit to run.
Inside the wall valve are two brass pins. NOTE: there are 120V valves installed on some systems known as a Super Valve. A shock hazared exists if you work on that type of valve. That being said. In the round portion of the valve you can use a garage hose that has a 360 deg. chrome ring to test the valve. The ring completes the circuit causing the unit to power up and suction at the end of the hose. If the suction is weak, there is a colg in the pipe. If you hear no airflow, the relay inside the unit did not energize or the motor is bad.
To test: go to the unit and turn the switch on the side to "manual" if the unit turns on the motor should be ok. DO NOT RUN THE UNIT without and open valve. In some brands dammage to your motor will occure.
If the unit did not run, look for a small button near the switch. This is a circuit breaker for the motor. If it is poped out and you hear a "click" when you press it in there is most likely motor problems and someone should be contacted for repair.
Hope this helps!!
VR
Mar 07, 2008 | Electrolux Central Vacuum
It sounds fine but it is sucking very little
If the suction at the port that the hose hooks into has low suction, then most likely you have a problem with the motor. Some of these Rainbow motors sound ok running, but are running at a slower speed, thus reducing the suction and replacing the motor is the solution.
Dec 24, 2007 | Rainbow E series Canister Wet/Dry Vacuum
Eureka Model 4351 vacuum - motor runs but no sction.
On my vacuum the "vacuum fan" (my name for the part which creats the suction) broke off the motor shaft. The vacuum sounded like it was working, but there was no suction. If you are sure there are no clogs (drop a marble down any hoses you can't see through), then this is the likely cause.
Oct 12, 2007 | Vacuums
Bissell LiftOff Revolution Pet Vac 37602 Vacuum Logo
35 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
