Question about Frigidaire FRS26H5AS Side by Side Refrigerator
Freezer not freezing - Frigidaire FRS26H5AS Side by Side Refrigerator
  • haydenwse Feb 20, 2012
    it seems to be making normal sounds but there is no frost on the finns.
  • Electrolux
    Electrolux Feb 20, 2012
    Ok well good news is it is making normal sounds. If you hear anything like knocking or vibrating then you're getting into the compressor. If you do not hear the compressor running then you have a bigger problem on your hands.
    Most cases this turns out to be a Freon issue. If the evaporator coils inside the freezer are only partially froze, the freezer cannot get down to the proper temperature. However, the refrigerator side doesn't need to be as cold, so it appears to be fine. When you have a compressor failure or a Freon issue it's best to have a professional repair the problem for you. It takes special tools and licenses to work with the Freon.
    Another thing that may cause the freezer to appear not to be working is the ice maker. If your freezer has an ice maker installed an you are not using it, make sure that it is turned off. The icemaker will continue to run through it's cycles even if there is not water. The only problem is that it goes through the cycles much faster. And every cycle it goes through the heater under the icemaker tray comes on. So anything that is close to the icemaker will thaw. Bread will not freeze in this case and your ice cream will stay soft.
My kenmore upright freezer is running but not freezing is there a reset button
**Freezing gas may have leaked out at some point. Compressor works but freezer not freezing.
**Thermostat setting not suitable for freezing to occur; check and adjust
**Check whether evaporator at the back of your freezer is hot/slightly warm to touch. If it's not; call your freezer service/repair man asap
Oct 14, 2017 | Kenmore Computers & Internet
My freezer will not freeze or cool. I checked the compressor and us cool to the tough but the copper is very hot??? Help please
Repair for a Freezer That Is Running But Not Freezing ...
homeguides.sfgate.com > ... > Other Types of Mortgages
Also, using a freezer to cool hot items or opening the freezer frequently will affect the... the freezer is running but not freezing is improperly packing the contents.
Fix a freezer not freezing but still cold - YouTube
? 1:34
www.youtube.com/watch?v=hCUewYVyiFQ
Aug 19, 2013 - Uploaded by Dave Here My freezer wasn't doing a good job freezing but there was ice on the back ... If not, approximately how often will I need to repeat the process?
Oct 19, 2015 | Refrigerators
MODEL AFG 5496-C FREEZER WHICH BUTTON SHOULD BE LIT WHEN SWITCHED ON TO FREEZE
Green light means that freezer is connected to the mains/electric
Red means that your freezer has not reached minimum working freezing temperature, this is not good news, something may be wrong with your freezer, get it checked by a competent person.
yellow light means that you have switched the fast freeze button on. This yellow switch allows the freezer to run continuously so that the frozen food you brought home from shopping can freeze up quicker. You must not leave this light on for more than 3 hours. It will cause you to waste a lot of electric and will place a lot of stress on the working component in the fridge.
Feb 10, 2015 | Whirlpool 10 cu. ft. / 283 liter Chest...
Magic chef freezer not working unless on "fast freeze"
Fast freeze is overriding your thermostat so the freezer compressor works all the time.This will kill your compressor.Try change thermostat.Jan
Feb 11, 2009 | Magic Chef 5 cu. ft. / 142 liter Chest...
New 3.6 Danby freezer not freezing
maybe you should go with a different brand???
Feb 04, 2009 | Danby 3.6 cu. ft. / 102 liter Chest...
Refrig not cooling but freezer is
The freezer door not closing properly would caused the freezer to freeze up
Feb 21, 2018 | Whirlpool GB2SHKRLS Stainless Steel Bottom...
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
Not freezing
check to see if your condenser is dirty, that can be the problem if looks clean, suspect low refrigerant charge
Mar 19, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer will not freeze except when using fast freeze
the electronic controller is faulty,make sure you have been supllied a freezer stat and not a refrigerator stat..
Nov 05, 2007 | Freezers
Frigidaire FRS26H5AS Side by Side Refrigerator Logo
27 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
