Question about Kirby G4 Bagged Upright Vacuum
Transmission not engaging
I have a g-4 kirby, the n/d is hard to shift, und the nutruel has quit functioning but the trans engages foward and reverse when pluged in and on
  • altorres0703 Oct 29, 2008
    first i would like to thank RockyNR1 for his advice, and the see it photo's. Well i located the bracket cam and i tell you it was filthy and rusty , i soaked it in wd-40 and cleaned it up the arm now moves freely (but) when i reassembled the unit i lost the foward drive and gained the nutruel back , so now i have nutruel , reverse but no drive . If you have an illustration on how exactly the bracket cam sits inside casing could you please foward it to me
  • Kirby Expert
  • 324 Answers
In Kirby vacuums with tech drive there is a part called Bracket cam (see it here) that is designed to disengage wheels from transmission. When it starts wearing out Kirby would make crackling noise when on neutral and eventually may not disengage at all. If there was no stage where it was noisy on neutral it may be something else - most likely the pedal assembly broken (see it here). It is not very hard to replace it.
Posted on Oct 26, 2008
  • Rocky
    Rocky Oct 30, 2008
    I do not think you would have been able to to put the bracket cam assembly wrong.
    I am almost sure that you removed the slide bracket (thing where you install upright handle) and you put it back wrong. See last two pictures on this page.
Have you a picture of the drive engagement mechanism
Thanks
Posted on Nov 25, 2008
  • 357 Answers
Here is the best site I've found for solving this particular problem,,,
http://www.greatvacs.com/Kirby%20Transmission%20Adj.shtml
Hope it helps,
Marci
Posted on Oct 30, 2008
Kirby sentria diamond pulls to one side while transmission is engaged
The transmission wheels should turn in unison. If one wheel is not spinning equal to the other the vacuum will turn rather than going straight which likely indicates the transmission will need replaced.
Nov 17, 2016 | Kirby Vacuums
Belt placemaent
There is a great video on youtube showing how to do this
It's not nearly as hard as they say at the beginning.
look up
"govacuum kirby belt replacement"
http://www.youtube.com/user/GoVacuums?v=At7tqnjD-Kc&feature=pyv&ad=3175996882&kw=replace%20kirby%20belt&gclid=CMvQ0fOe7Z4CFQJaagodg0r9Ug
Dec 12, 2009 | Kirby G6 Bagged Upright Vacuum
Kirby G5 gearbox clicks, why?
most of the time the small fork that comes off of the transmission and connects to the top slide wears out which doesnt allow the transmission to engage properly
Oct 10, 2009 | Kirby G5 Bagged Upright Vacuum
Kirby g3 tech drive
so when u pull it back it's like it's not engaged at all? then it maybe the reverse is out....with the fwd soon to follow. remember the vac is 20yrs old; & working that long? it definately served it's purpose.
depending how much money you wanna spend on it buying a new or used trans. plus labor...or just an ebay used unit.
Mar 31, 2009 | Kirby Generation 3 Bagged Upright Vacuum
G-4 Kirby self propel unit works in reverse but not foward
Jon,
Here is a helpful link to use to adjust the tranny. About a 7 on the difficulty level.
Marci
Dec 10, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Slef propell is not working correct
The transmission may be out of adjustment.Remove the top cover exposing the pivot handle assembly.On top of the pivot handle assembly,you should clearly see the adjustment screw along with the adjustment spring.Once the adjustment screw is loosened,the spring should automatically adjust the pivot handle to the factory setting.Just make sure the screw is tight
Oct 23, 2008 | Kirby G6 Bagged Upright Vacuum
Self propelled function
There are few things that may have gone wrong:
First thing to check is if when pushing pedal it moves gears located on the rear axle (you will have to take cover shell off to see that)
If that works fine then primary belt may be broken (see it here). Then just replace entire set to make sure that belt type matches gears
Last - the most expensive problem - the main transmission belt within transmission is broken (then I would recommend replacing entire transmission)
Sep 10, 2008 | Kirby G4 Bagged Upright Vacuum
G5 Kirby drive problem
Gary...
You need to adjust your transmission. Here's a link that may help...
Marci
Sep 05, 2008 | Kirby G5 Bagged Upright Vacuum
Kirby ultimate power off
Make sure the bag assembly and either the power nozzle, or hose attachment are correctly attached. The kirby has safety swithes that are only engaged when these components are correctly installed. They look like small resessed buttons on the base unit. if they are not engaged the vacuum will not turn on. Keeps curious fingers from getting into the "spinny" parts ;o)
Jul 04, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Electrical
PROBLEM: THE KIRBY WILL NOT TURN ON AT ALL
POSSIBLE CAUSES:
Please note......The Kirby has TWO safety switches that need to be engaged before it will operate. One is on the fan case in the front. It is activated by having an attachment attached to the front. (hose, power nozzle, etc.) The other switch is on the side of the Kirby where the cloth bag attaches and is engaged by the little tab that sticks out from the side of the hard plastic cloth bag "boot". The bag boot MUST be completely engaged to activate the safety switch and allow the Kirby to power on. If you are having trouble getting the bag to properly engage, (sometimes they are STUBBORN) simply lubricate the black gasket that the boot fits onto with gasket lubricator, VASELINE, or try a tiny drop of DISHWASHING DETERGENT or HAND CREAM. It doesn't take much, so use the smallest amount possible to get the desired effect. You should hear a slight "pop" when the bag completely engages.
If neither of these things are indicated, it is probably again, either the power cord, switch or the carbon brushes.
If your Kirby is sparking there are a few causes...
PROBABLE CAUSE (MOTOR): Worn out carbon brushes, bad armature or perhaps BOTH
PROBABLE CAUSE (CORD): The cord has a short in it. Replace the power cord
PROBABLE CAUSE (POWER NOZZLE): There is something metallic stuck in the fan or power nozzle
I think you have a problem with the carbon brushes and amature because of where you describe seeing the sparks. I would suggest taking it to an authorized dealer for repair if it is the motor that is going bad.
Apr 01, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby G4 Bagged Upright Vacuum Logo
610 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
