Question about Play Inc BOB THE BUILDER - TALKIE TALKIE FRICTION POWERED BRISTLE
How do i replace the batteries on a talking friction travis the tractor, (bob the builder)
Replace friction wheel Snapper 3317523BVE (7800254) - Snapper 33" Rear-Engine Rider
Warren, Could not find your particular model, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
HowTo Replace Your Disc Drive Friction Disc Wheel
Riding Lawnmower doesn go foward Drive Disc Replacement
snapper clutch repair for beginers friction disc
Snapper Friction Drive Modification
May 13, 2016 | Snapper Garden
On the 1967 sears super 12 tractor what part number replaced sears part number 606A190 for the voltage regulator
you have a starter generator... you can go to most specialty 12 volt shops ( starter re-builder ) or online and find a good quality universal V.R. can't remember if thats a 6 or 12 volt system... google 12 volt external voltage regulator and you will get an idea what I am talking about. I've done this repair a number of times
Oct 23, 2014 | Garden
Lost the charger, need a replacement
You should be able to find one here scroll down some and there is a 6v charger http://www.impactbattery.com/catalogsearch/result/?q=bob+the+builder+scrambler+charger
Jul 05, 2012 | Learning Curve Toys Bob the Builder...
After using the computer twice,it stopped working.we changed batteries to no avail. it was bought dec2009.smyths was contacted where it was bought,but couldnt be replaced as it had gone out of stock....
Usually the manufactures warranty covers material defects for a limited time, and ranges from 90 days to 3 years. I have never seen a warranty for a computer more than 2 years personally, and you bought the computer 8 years ago. Unfortunately I think you will need to pay for the repairs yourself.
Dec 01, 2017 | Bob The Builder Toys
good day,
hope this link below answer your query.
toys
Mar 27, 2009 | Learning Curve Toys Bob the Builder...
WE NEED TO PURCHASE A REPLACEMENT CHARGER
You should be able to find a replacement charger at www.batteriesplus.com
Mar 23, 2009 | Learning Curve Toys Bob the Builder...
Slow starting Lawn Tractor Engine
after 10 yrs you would have less friction and less compression - did you have your battery load tested ? if you did and it checks ok then it could be a starter prob . try using jumper cables from your auto . neg to ground then pos directly to starter . if it still winds over slow its the starter
Oct 05, 2008 | Garden
Play Inc BOB THE BUILDER - TALKIE TALKIE FRICTION POWERED BRISTLE Logo
148 people viewed this question
Top Play Inc Toys Experts
degroot2940
Tom Chichester
Bill Boyd
Are you a Play Inc Toy Expert? Answer questions, earn points and help others
