Question about Canon BJC-85 InkJet Printer
Printer cannot be put on
My printer is 1 year old and it wont go on it has 5 ink
HP PRINTER IS PROBLEM USB CABLE FAULTY AND NOT ACC.
Posted on Oct 26, 2008
Printer Ink Jet
Could be a bad new cartridge. Try putting the old ones back in, and see. Unplug the printer for a couple of minutes and try again. Make sure there is nothing between the contacts on the cartridge and printer.
Mar 23, 2015 | Office Equipment & Supplies
Computer wont reconize ink cartidge
Hi there
You can try this it some times works.
Super Canon User's method of resetting IP1600
1.Press Resume button hold for 1 - 2 minutes (count to 1 to 15-16)
2.Open the cover right away
3.Release Both cartridges out and then put cartridges them back again
4.Close The Cover
5.Turn Off Then Turn On again.
You can download the Resetter tools program from my website.
Click Link = http://www.4all2sell.com/reset-tools/ip1600st-RESETTER-TOOLS.zip
1. Download software for Canon iP1200, iP1600, 2200 Printers.
2. Unzip downloaded file by etc
3. Run GeneralTool.exe
4. Select the connected USB port number from USB PORT
5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
Free WinZip http://www.winzip.com/downwz.htm
Please call back to vote
All the best: Pineworks
Nov 02, 2009 | Canon PIXMA iP1600 Printer
The printer flashes orange light five times, and green once
Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
This also applies to the i550, i560, i950, i960
Sep 07, 2009 | Canon BubbleJet i560 InkJet Printer
The printer do not recognize the new replacement cartrige
I have many epson printer, some more than 5 years old. It's ok. some have printed more than 50.000pages, it's ok.
If Ink cartridge Unrecognizable, there are two posibilities : Chip Error at ink tank, or printer error. For chip error, try to plug the ink tank to another printer (same type). If the ink tank recognized by other printer, so the problem is printer.
So ;
1. Check chip conector at head carriage.
2. Check the wiring of the head, and chip.
If two point above is ok, the last action is check the power supply and board. It may be epprom is damage.
May 28, 2009 | Epson Stylus R380 InkJet Photo Printer
Black Ink wont work.
I would take the ink cartridge out, grab some rubbing alcohol and a q-tip, and wipe the bottom of the cartridge where the ink gets dispersed. You should see color on the q-tip after just a few swipes. Return cartridge back into printer and give it a go!!
Please be sure to rate this solution.
Regards,
Joe
May 08, 2009 | Brother MultiFunction Center MFC-440CN...
Wont print
I had this problem recently with my IP90. Both the black and color heads were clogged. After running the "canned" routines several times to clean the heads and deep clean the heads...still didn't help...here's what I did:
1. open the top lid to have the cartridges that are inserted in the print head move to the middle of the printer.
2. remove both cartridges
3. What is left there is the print head holder. Slightly move it to the right and gently lift the print head lock.
4. Grasp the print head and lift it out of the tank.
5. Have several paper towels hand and know that you will have color and bw ink on your fingers
6. Put the print head on the paper towel
7. Pour rubbing alcohol on the blk and color heads and let them sit of about 10-15 minutes.
8. after that dry the heads and re-insert them in the printer
9. I put new cartridges in the printer and ran clean and deep clean a few times.
10. My color and black and white print came right back!
Hope this helps.
Mar 17, 2009 | Canon PIXMA iP90 Mobile Printer
Leaking Printer with the MAC
Please confirm that your printer is a C86. Where did the leak come from? If you are not sure, place a thick wad of newspaper or other absorbent material on the floor and put your printer on it. Tip the printer on its back. Does ink now start to come out from the long joint along the back. If LOTS of ink comes out, it means your waste ink compartment is flooded, and I suspect ink has got into your power supply and shorted something. Please report back; the situation sounds bad, but might be retrievable.
Jan 27, 2009 | Epson Stylus C86 InkJet Printer
My printer will not accept new cartage
if your printer wont take the new ink can only be two things either the ink cartiage is bad of the printer is bad try putting the old one back in and if it takes and the new one wont then exchange get new ink if that dont work suggestion is buy new printer
Dec 04, 2008 | Lexmark Office Equipment & Supplies
Printer not printing e-mail
1) Check the print prefences.
2) Set your email as Text
Check if the printer, print another documents
Oct 08, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Printer wont print
Are you using Genuine Epson Inks??, if you get 3 years out of a printer these days you've done well!,
Dec 08, 2007 | Epson Stylus CX4600 All-In-One InkJet...
Canon BJC-85 InkJet Printer Logo
old marine
old marine
