Combi boiler error codes
E31
4 Suggested Answers
  • 33 Answers
SOURCE: ravenheat he85aaa combi boiler running fault
sounds like low water pressure, check pressure guage, get unit serviced
Posted on Jan 17, 2010
  • 58 Answers
SOURCE: Vaillant Combi boiler
LOOK ON ONE OF THE COVERS 75% OF ALL CODES ARE ON THE INSIDE OF A COVER FOR SERVICE TECHS, NOT MUCH HELP BUT HOPE IT LEADS YOU DOWN THE RIGHT PATH
Posted on Jan 23, 2010
  • 2519 Answers
SOURCE: Hi I have a ideal isar 30100 combi boiler which
jumper links not inserted in to pcb is h5 code
Posted on Mar 21, 2010
Testimonial: "Hi mylandlord eventually sussed it out and blanked of port1 and 3 on the pcb thanks for your help T"
Washer won't start showing code E31. Already changed pressure switch an cleaned drain. Is there a way to reset?
error code e31 frigidaire washer Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Find solutions to your error code e31 frigidaire washer question. ... error code E31, first check if it is a false error code by resetting the power to the appliance by ..
Jul 28, 2015 | Washing Machines
After moving my gas meter from inside the home to outside and having a semi concealed meter connected we cant get the combi boiler to work properly we can get hot water and have the gas fire on but
your boiler needs a minimum gas pressure of 16 mb to light successfully. if your gas pipe has been extended it has to be able to flow enough gas. it may need upgrading to 28mm for even as little as a metre from the gas meter. if your central heating works ok when the fire is off then this is your problem
Oct 12, 2014 | Water Heaters
What does it mean when PO8 and H7 are flashing on worcester boiler dial
Either on the inside of the door or in your manual will have a list of all the codes. You could try turning the unit off, not while its in operation, and turn back on in 20 seconds. But first find the meaning of the codes, or faults. They will be listed. Unless the code is stupid simple, contact a pro. CO and fires kill if you don't know what you're doing
May 12, 2014 | Heating & Cooling
Ferroli boiler optimax he 38 c.Powers up ok,no hot water,no error code.Think its an ignition problem.Heating flame not showing?????
Is there an error code? If not the flow sensor for the hot water could be faulty. Also if you've had a power cut depending which model of Optimax HE you have, you sometimes have to tell the boiler it's a Combi, as they have a generic Pcb fitted which is also used on the system only boilers.
Sep 26, 2013 | HQRP Universal A/C Remote Control...
Baxi duo tec e160 code
Fault Code E160 on a Duotec Boiler is a fan fault.
Mine has just gone for the 2nd time! Gas engineer is on his way......
Jan 31, 2012 | Heating & Cooling
Error E31 on Bushnell V2
Can you check that the new battery is an alkaline battery? If it is, and you are still getting the E31 error code, you will need to return your rangefinder to Bushnell to have it reprogrammed.
E31 is a programming error code. Most of the time this comes from using non-alkaline batteries or from letting a battery die in the unit. Non-alkaline batteries just don't generate enough current for the laser to operate properly.
Good luck.
Feb 28, 2011 | Bushnell Tour V2 Pinseeker Laser...
Jan 23, 2010 | Heating & Cooling
No hot water from combi boiler
i have a combie bolier when i turn the hot water taps on only cold water comes out central heating working fine can any one give some advise ?and can i fix it myself.
Jan 03, 2009 | Combi Centre DX - Mango
Ariston combi boiler
sounds like your diverter valve is passing on the boiler, this diverts the heat either to the rads or to the taps, if its passing through the heating chanel it'll heat up the rads- may also be a scaled up secondary heat exchanger, hope this helps you
Aug 21, 2008 | Combi Centre DX - Mango
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
