Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
Amana SXD23VE quit cooling 3rd time
This refrigerator has quit cooling for the third time. Is there something I can replace or do I need to get another make/model?
  • 1 more comment
  • aj_scifres Oct 26, 2008
    The first 2 times were related to the thermostat and the unit was serviced by Amana certified technicians. Both sides are warm, and the unit is 10 years old.
    Thanks for trying, it's still not cooling on either side. Time for a trip to Sears.
  • Ron Coons
    Ron Coons May 11, 2010
    what was the reason for the machine to quit the first 2 times?? was it serviced by an authorized amana servicer??and is it acting the same way again??? no cool in both compartments?? and how old is it??
    President:
  • Amana Master
  • 2,651 Answers
Wel there are 2 thermostats in this unit, a defrost thermostat(very common to go bad) but would mainly affect refig sect and the freezer only slightly, the other is a cold control thermo affecting both freezer and refrig, if this goes bad you get NO cooling, looking at the diagram for the refrig it has a defrost timer under the righthand side of the kickplate, i would try advancing the timer, with a screw driver you can manual turn the plastic gear on the timer( i believe on yours its problaby a pink knob. its possible that the timer has gone bad and the unit is stuck in a defrost mode, try turning it ever so slightly, youll hear it "clicking" as you do , it should "snap" into arun mode and everthy kick on for it is stuck in defrost(worth a try anyway)
Posted on Oct 26, 2008
NO ICE FROM ICE MAKER
You have a bad water valve or the fill tube where the water comes into the ice maker is frozen full of ice. Check the second problem first then if the fill tube is clear the valve needs to be replaced.
Apr 25, 2012 | Amana Refrigerators
Amana refrigerator model #ARB1914CW fan quit running. quit cooling
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 07, 2011 | Amana Refrigerators
Freezer on amana model arb8057csr quit working.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Nov 29, 2010 | Amana ARB8057CSR Bottom Freezer...
I've got an Amana SXD23VE. The freezer side only cools to about 28 Deg. The fridge side is fine. Any ideas?
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Oct 06, 2010 | Amana SXD524VW Side by Side Refrigerator
I need a diagram for amana refrigerator model sxd23ve locate defrost timer
My Amana refrigerator freezes everything. It has a bottom freezer.
Dec 02, 2009 | Amana Refrigerators
Amana SxS fridge not cooling or freezing
You have a sealed system problem. There is either a small leak or a restriction somewhere in the tubing. This isn't something you could've caused so don't worry about that. Unfortunately this isn't something you can fix yourself either. You require a certified refrigeration technician to fix this problem.
Nov 03, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Not cooling
Replace heater and defrost timer
Aug 09, 2007 | GE Profile PSW26P Stainless Steel Side by...
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
198 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steve
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
