Question about Hyundai X93W 19 inch Monitor
I need the manual for Hyundai X93W 19 inch monitor.
    Scholar:
  • 99 Answers
2 Suggested Answers
SOURCE: I need to know how to reset my monitor to factory defaults
Factory Setting & EEPROM Initialization Method
Factory Setting Method
- Connect the signal cable and power cable to the LCD monitor.
- Press Power switch with pressed MENU key.(Menu key + Power key).
- Then, a User can change the factory setting value in OSD menu.
- Save changed value and Turn off the power s/w.
- Turn on the power, adjust the screen.
Posted on Apr 13, 2010
As soon as I turn on the Hyundai X93W monitor, it stays on for a couple of seconds, then the screen goes black, but the green light next to the power button is still on. I'm not sure when this problem...
josealvajr, Check YOUTUBE again!! Use search terms: "lcd monitor repair" and "lcd monitor disassembly" and you will find some video clips that may not be for your unit, but will help you. All ccfl back-lit lcd monitors use same basic electronic design to display text and images on the lcd panel!!! Hyundai probably won't sell you a inverter/smps board. Look for swollen capacitors on the power supply board. Lots of pic's on web for you to look at. 12fixlouie
Oct 19, 2010 | Hyundai Electronics Hyundai LCD 19"...
Backlight of Hyundai X93W dead
The fault is most likely a faulty inverter board.
For service, parts and DIY info check out LCD Parts - click on this link to their WEB site :-
www.lcdparts.net
Jan 09, 2010 | Hyundai Electronics Hyundai LCD 19"...
Hyundai 19
yes any electronics shop should be able to replace the bad capacitors for under $55 dollars. common problem
Jan 01, 2010 | Hyundai Electronics Hyundai LCD 19"...
No display the monitor power led on the front panel flash's between yellow and blue
Did you check the computer with another monitor? If so, and you get the same result, then your video card is suspect.
If another monitor works, then it's your monitor.
Dec 23, 2009 | Hyundai L91D / 19-Inch / 1280 x 1024 /...
I have a hyundai 24 inch lcd monitor which is just a couple of month old. Today I see a pink vertical line on the monitor. Do you know if there is a solution for this ?
The problem could be a faulty CCFL lamp. If you try to fix it yourself you most likely void your warranty.
The LCD monitor should still be in the warranry period. Take it back to your supplier to have it repaired or replaced.
Oct 18, 2009 | Hyundai L91A 19" LCD Monitor
Apr 15, 2009 | Hyundai ImageQuest 19 L19T LCD TFT 19" LCD...
Entire image shifted
Press the Select/Auto button. The monitor will then automatically adjust to match the incoming signal and will save that setting in the internal memory of the monitor.
Nov 06, 2008 | Hyundai L90D+ 19" LCD Monitor
Hyundai X93W 19 inch Monitor Logo
362 people viewed this question
Top Hyundai Computers & Internet Experts
Tom Stevenson
Level 1 Expert
Randy Schumann
Randy Schumann
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
