Question about Zebra 105SL Thermal Label Printer
My Zebra 105SL printer prints a black bar over the entire label..why is that?
When printing a label the entire surface of the label prints a black bar.
    Top Expert:
  • 1,575 Answers
Hi
Try calibrating the printer.Click on the link below for a video tutorial on the same.
www.racoindustries.com/zebra-105sl-printer-calibration-video.htm
Hope it helps.
Posted on Feb 18, 2012
SOURCE: ZEBRA 105SL : PRINTING PROBLEM
Thanks your the solution. This helped me a lot.
Greetings
Thomas
Posted on May 05, 2008
SOURCE: Zebra 105sl - printer does not print correct size
This can happen if you have the wrong dpi setup. For instance the 105sl can be either 203dpi or 300dpi. If your printhead is 300dpi and the label you create is expecting 203dpi, then you will see shrunken label. Your situation doesn't exactly sound like this is the case but it may be worth checking.
Posted on May 19, 2008
SOURCE: Zebra 105 SE Printing Blank Labels
Seagull Scientific has drivers. Their Zebra driver is recommended by many.
http://www.seagullscientific.com/aspx/drvrmain.aspx
That's the link for their printer drivers page. Go to the bottom and click on 'Download a printer driver'. Then scroll the list to find the one you need.
Posted on Jun 10, 2008
SOURCE: Zebra LP2844 printer prints garbage
Sounds like you might be using a bad driver, or the printer is in dump mode.
Try hitting the green button and see if it says exiting dump.
If still having trouble, inside the printer it tells you that if you are having printing trouble:
  1. turn off the printer
  2. Hold down the feed button
  3. turn on the printer and at the third red flash release the feed button
  4. it will then feed some pagessome info and ask you to hit feed again to exit dump
  5. hit feed again and it will say exiting dump
This process re-reads the label length (so only do it with the labels you want to use in, or it will waste labels until you do it again with those in it) - but I'm suggesting it only because it enters and exits dump mode (which I have read can cause the garbage when you try to print).
Posted on Mar 11, 2009
  • 62 Answers
SOURCE: An extra, blank label prints from a Zebra 2746e.
Check media settings in the printer driver. Check version of printer driver. Zebra printersuse an internal printer driver with their Zebra Designer software (Zdesigner driver) or a ZUD (Zebra Universal Driver) for other windows applications. These drivers can be downloaded directly from the zebra website.
Alternatively you can download the seagull scientific driver and use that instead. (used with bartender program)
Label skipping occurs if the media dimensions are not specified correctly. The important ones are label height, and media setting for type of media.
Perform a media calibration before you go changing settings. Power on printer, Hold top and bottom buttons in on control panel for 5 seconds, release bottom button only then when printer starts feeding labels release top button. When printer finishes press feed button.
Posted on Apr 18, 2009
Zebra 105sl printer labels print too small
There are 3 different DPI Printheads for Zebra printers if you print a label set up for a 200 DPI Printhead on a printer with a 300 DPI Printhead installed it will be about 66% of the size.
Feb 13, 2014 | Zebra 105SL Thermal Label Printer
How can you configure Zebra printer 105sl (over network) to print labels in IE and have a regular printer from reducing the document size from a thin client?
I have this issue whenever I set my default printer to a label printer. Use the other printer as the default and set to the zebra only when you need it.
Dec 07, 2011 | Zebra 105SL Thermal Label Printer
We have a Zebra 105SL thermal printer. When I print to it with any application, the data light comes on, but it doesn't print. It has ribbon, media, calibrated, no error lights
The data light indicates that the printer is receiving data. Hold the cancel key for 10 seconds while powering on. This will print printer configuration. Use to troubleshoot. If the data or format is wrong it will not print as you send data. Make sure you are using the 105SL printer driver. To test the printer functionality you can go to www.teklynx.com and download a demo copy of labelveiw, select the 105SL printer and try to print a simple label. If you can print with labelveiw then it is not a printer problem. Double check your driver and label format.
Nov 12, 2010 | Zebra 105SL Thermal Label Printer
Zebra 105sl laebls always come out blank
Power on while holding the pause button for 5 seconds. This should print black bar across the width of the label. If this prints, then check the darkness parameter in your label format or driver. Also check to make sure your ribbon is feeding coated side out. There is a shiny side and a dull side to a ribbon. The dull side should be against the media. If it is leaving an image on the ribbon and nothing on the label the ribbon is either loaded incorrectly or not a zebra ribbon.
Oct 03, 2010 | Zebra 105SL Thermal Label Printer
I am trying to print a label on the zebra 105SL but the font and the "text boxes" are printing too large like it is zoomed out - how do I resolve this issue?
I am trying to print a label on the zebra 105SL but the font ...
www.fixya.com/support/t5406223-am_trying_print_label_zebra_105sl
Jul 11, 2010 - I am trying to print a label on the zebra 105SL but the font and the "text boxes" are printing too large like it is zoomed out - how do I resolve this ...
db:: 4.67::Crystal Report Label Won't Send To Zebra k9
www.hivmr.com/db/k99xad9dfspspddfs1scm9fzxxkdz9dj
My routine can print the label to any other laser printer, but the Zebra. ... I am tryingto find a way to print actual time a smartform label gets printed out on a zebra ... In this i want to changeCross Tab expert Row Label Font,Cross Tab expert ..... And labelpaper too. ..... DB:2.73:Zebra 105sl And Crystal Report Label Issues 1d.
db:: 5.16::Help My printer is printing in 3x5 documents and I ...
www.hivmr.com/db/xkzpajp81937ap7zdf87sdmsxmcm179m
DB:4.06:Printing 3x5 Continuous Feed Labels On Hp Officejet 6100 d8 ... Are they toosmall? ... I want to help you but I am not sure I can be of much help until I know what kind ... If the paper size is 3.5x5 but you are trying to print a 3x5 photo (which seems to be ...... I have a label format issue on a Zebra 105SL label printer.
db:: 4.15::Custom label sizes md - Hivmr
Jul 11, 2010 | Office Equipment & Supplies
Zebra 105SL prints 90 degs to what's on the screen
Print out a Cancel Self Test label:
1. Turn the printer off
2. Press and hold the CANCEL button while you turn the printer on.
If the label that prints out looks normal, you have a config issue in either your printer driver or your label software's page setup.
Mar 04, 2010 | Zebra 105SL Thermal Label Printer
ZebraDesigner Pro is changing my settings
If you have two printers 105se and the 105sl must install the two printers and select the correct model when you print your labels.
Mar 10, 2009 | Zebra 105SL Thermal Label Printer
Poor Quality Print on Zebra 105SL direct thermal
How many labels has the printer printed? Because it sounds to me like you just need to replace the print head.
They are around $400 from whomever your supplier is, and very easy to replace.
Nov 12, 2008 | Zebra 105SL Thermal Label Printer
Prints half the label.
Try reloading the forms from the AS400 by restarting the program. That should get it to work.
Jul 03, 2008 | Zebra 105SL Thermal Label Printer
Zebra 105SL Thermal Label Printer Logo
203 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
