Have vizo 32 inch tv with black sreen
Have sound no video
  • Anonymous Dec 09, 2008
    No video picture or sound just horizontal lines
  • Anonymous Apr 05, 2009
    I have a vizo tv 42 inch with a black screen. What's the problem?
5 Suggested Answers
SOURCE: i have sound but no video at all
for the LCD TV Inverter go to moni seriv.com
Posted on Jan 29, 2008
ramon49
  • 111 Answers
SOURCE: 32 inch tv goes from normal sound during program to extreme loud
May be a defect but, if you notice the sound changes with different channels or movies or HD or Standard, look for a volume limiter control button in the menu setup under audio control. Sometimes the menu has a control that you can turn on to limit different volume levels during the shows origination.
Posted on Mar 12, 2009
  • 53 Answers
SOURCE: The price for a screen
Vizio does not, on the whole, provide panels for repair.
You will need to purchase a new set (or, if you have an extended warranty or manufacturer's warranty, a new set will be provided to you at no cost).
Posted on Aug 01, 2009
toolkits
  • 1099 Answers
SOURCE: soyo 32 inch TV, no sound
First check that any muting control is not activated. This might be
a button on the remote or set itself. If you have a headphone jack, it
may have dirty contacts as plugging in a headphone usually mutes
the speaker.
If the set is mono or only one channel of a stereo set is out, then
check for bad connections to the loudspeaker. Test the loudspeaker by
disconnecting one of the wires (with the power off!) and measuring its
resistance with an ohmmeter (it should be less than 100 ohms - probably
less than 8 ohms). Or momentarily touch a 1.5 volt battery to the speaker
terminals - you should get a click or pop from the speaker.
Next, trace back from the speaker output terminals to the circuit board
and look for bad solder connections or a loose or dirty connector.
If these tests do not reveal anything, you probably need a scope (or
audio signal tracer) and schematic. Or at least the part number off of
the chip. Is the final amp a chip also or just a transistor? Have you
tested the transistor? If there is little or no buzz from the speaker,
that would indicate a problem fairly near the output. If the tuner/if were
bad, I would expect some noise/humm pickup from the low level audio stages.
Get the part number off of the chip. If it is in a socket, check the
contacts for corrosion or looseness.
Hope this helpout.....
Posted on Jul 14, 2010
joeguest2
  • 2080 Answers
SOURCE: I HAVE A VIZO TV 42 INCH) MY DOG ATE MY REMOTE
Find the model number on the back of the VIZIO remote control.
Go to the link below and enter the model number in the SEARCH BY MODEL NUMBER space provided or look for it in the scroll down SELECT YOUR PRODUCT menu.
http://www.vizio.com/support/
You should see a picture of your product and underneath it a small grey tab marked SUPPORT about halfway down the page.
From there you should be able to safely download a copy of the USER'S MANUAL which will contain the codes for your TV. Just click on the user manual link highlighted in red.
While you are there you can also download a copy of your TV's user manual if you don't still have it. The tv's model number will be on a sticker on the back of the set.
Good luck, hope this helps. Keep us up to date on your progress.
Posted on Jan 21, 2011
My tv image goes off while watching tv,I do have audio but no image.
LG 42LS5700 - LG.com
www.lg.com > Home > Support > Product Support
LG ElectronicsTV/Audio/Video; TVs; 42LS5700 ... TV Support Landing Page - HDTV/Netcast/webOS 1.0/webOS 2.0 ... Adjusting Picture Settings - webOS 2.0 Video ... quality and convenience of complimentary shipping when buying directly from LG.com. ... Curved TVs · 22 Inch to 29 Inch Class TVs · 32 Inch to 39 Inch Class TVs · 40 Inch ...
Amazon.com: Customer Reviews: LG 42LS5700 42-Inch ...
www.amazon.com/LG-42LS5700-42-Inch.../B006ZH...
Amazon.com, Inc.LG 42LS5700 42-Inch 1080p 120Hz LED-LCD HDTV with Smart TV (2012 Model). byLG. Size: 42-Inch ..... images are nice and crisp when viewing HD content.
Widescreen TV Black Screen - Repair LCD LED PLASMA ...
? 3:41
https://www.youtube.com/watch?v=RbZncfiOXQA
Jul 13, 2011 - Uploaded by FixItUrselfDummy
Fix your tv with black screen blinking light, popping sound noise. ... Watch QueueQueue ... TV Black Screen - Repair LCD LED PLASMA - Problems SONY LG .... I have a 60 inch samsung DPL tv how can I stop the humming or ... What do I do if my tvturns on but its just a black screen so sound no picture?.
Jan 11, 2016 | LG 42LS5700 42 Inch 1080p 120Hz Smart TV...
MY PHILLIPS 32 INCH TV HAS NO SOUND.
the problem may be in the main video/av card get on ebay to see if you can find one
Dec 18, 2014 | Televison & Video
L32W961 screen goes black then comes back on. later when video comes back sound does not
That is definitely a manufacturers error.
If it has been less than a year since you purchased it i would contact them.
They will send you to a service center. If it cant be fixed they will replace your tv.
It is all covered by them.
If it is past a year its honestly not worth fixing it,
You can find name brand 32 inch tv's for less than 250
while fixing it would cost around 150.
Mar 30, 2014 | Envision L32W761 32 in. LCD TV
I have a solid black line across my 32' Element tv with sound,
If the line is about an inch thick, it might be due to a bad CCFL in the panel.
Jun 09, 2012 | Element Electronics FLX-3211B 32 in. LCD...
I HAVE A 32 INCH FLATE SREEN TV THE SREEN IS CRACKED CAN IT BE FIXED @ A REASONABLE COST? It IS A VIEWSONIC
unfortunately not - if you can find one from a tv that has other problems it may be worth it - but generally its a parts tv at the moment.
thanks,
michael
Apr 05, 2011 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Aug 01, 2009 | Vizio L32 32 in. LCD HDTV
Crawling lines on lcd 42 inch
that sounds like a power supply problem check your filter caps in the power supply they are leaking.theyare not filtering the voltage properly.if you are not a tech kindly have one look at your set
good luck
Apr 07, 2008 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
176 people viewed this question
Top Televison & Video Experts
Electro Med Services...
