Canon imagepress C1 error codes
Code e000820-0003
barkencoa
  • 3463 Answers
SOURCE: getting error code c1
Hi
Error code C1 indicates problem with drive motor-thermal protector-or motor controller
Overloading may also cause the problem.
Press( stop/cancel) to clear the display.
Hope this helps
Posted on Nov 24, 2008
SOURCE: C1 error code
CL code stands for overloaded motor. Motor is drawing to many amps and cuts out. I suspect a failing motor or something binding that causes the motor to draw to many amps. Don't know how to fix it.
Posted on Sep 01, 2008
  • 1126 Answers
SOURCE: I have error code E000732-0001 on Canon imagepress C1
Error :
E732 code
Workaround :
E732 code is a Reader communication error.
If the Reader is disconnected from the Printer a E732 code will result. Once the Reader is disconnected the logic on the MAIN-Controller is changed to a "0". The copier is now set up to be a Printer only, and will not recognize the Reader.
To correct this, you must enter service mode, COPIER>OPTION>BODY>W/SCNR and set that to "1". Then you must turn the copier off, then on.
To enter service mode: press "Additional Functions" then "2" and "8" together, then "Additional Functions".
Which User Guide? Reference, Easy Operation Guide, Printing Guide, Mailbox Guide, Sending Guide etc....
Posted on Sep 09, 2009
  • 82 Answers
SOURCE: Canon ImagePress C1 error E000747-8000
E747 from what I remember is the connection cable from either the scanner to the print device, or scanner to the copier. Make sure that none are loose and they are in the correct slots.
Mismatching the cables may result in the error.
Posted on Dec 10, 2009
blueextc3221
  • 15935 Answers
SOURCE: What is error code C1? Also what causes the
The C1 error is displayed when the motor tries to pull more than 26 amps to run.
This indicates a problem with the motor or motor controller.
Overloading or excessive suds can also cause this error.
If you like to make a few more checks then the image below contains the instructions for entering the diagnostic test mode.
Its a short cycle that runs all of the components so the operation of each can be checked.
I hope this helps but an intermittent C1 error can be hard to pin down.
http://media.fotki.com/1_p,wbrrkqqwkwbqsdgxgtqsskgwtqkq,vi/kdkftbfkwxkfsqdgqsg/1/1303472/5961857/image5668img-or.jpg
From the service manual....
"C1 = Average current limit Or Instantaneous current limit.
If a status signal comes back from the motor controller that a current
limit has been breached, the unit will return to standby mode and
display either CA for average current limit trip or Cl for
instantaneous current limit trip.
Average current trip occurs if there is a 2 second average of current
draw greater than 5.55 amps
at the motor windings.
Instantaneous current trip occurs if there is a spike of 26 amps
instantly at the motor windings.
This may signify problems with the drive motor, thermal protector, or
motor controller. Over-loading the unit may cause this problem."
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 23, 2010
I have a machine canon imagepress C6011VP with error E00000-0201-05
hi if u get error E00000 as main code that's mean the heater problem
u should have to check the hater lamp and the thermal fuse in fixing unit if every things are good this is only malfunction just reset error code.
Oct 27, 2014 | Office Equipment & Supplies
Canon ir c3200 error code e0100-110
get manual here
http://www.scribd.com/doc/61327440/Canon-Irc3200-Service-Manual
Mar 23, 2014 | Canon iR C3200-C1 PS Ver1.0
When I turn on my canon ImagePress C1+ printer it stays in warmimng up state and never gets ready. what is wrong? how can I fix it?
when i turn my conon imagepress c1 printer it state and this error code come it e00001 - 001 what the problem and how can i fix it
Nov 17, 2013 | Canon Imagepress C1 Color Copier,...
Canon ImagePress C1 cannot calibrate from Windows 7
The problem is it doesn't recognize Java 7. Install Java 6 (latest version) and it will work. You can have both Java 6 and 7 installed at the same time. As well make sure if you are running a 64bit machine you install the 32bit version of Java (so you will have 4 versions installed). Java 7 32 & 64 bit, Java 6 32 & 64 bit. I had the same issue and solved it this way.
Jul 26, 2012 | Canon Imagepress C1 Color Copier,...
Waste toner canon imagepress c1
if it is the 2nd transfer cleaning waste toner, you have to clear copier-counter-misc-2TC-Box
Jun 10, 2012 | Canon Office Equipment & Supplies
Error e020 0180 on canon imagepress c1 please give me a reply
getfile.asp?rid=1258 November 02, 2010 getfile.asp?rid=3215 Product : imagePRESS C1 / C1+ Title : E020 with Multiple Sub Codes for all Colors Problem :
Solution :
Check for a pinched or damaged wire harness from PS3 Patch sensor #2 from connector J426 back to the Side Driver p.c.b at connector J3415 and at PS7 ATR sensor from connector J209 back to the Rear Driver p.c.b. connector J3802.
getfile.asp?rid=33199
getfile.asp?rid=33201 Canon USA, Inc. Systems & Technical Support Division
Dec 19, 2010 | Canon CLC 1120 Color Copier
Canon imagepress c7000vp error code e000061-0481-05. what does it mean??
The laser shutter is faulty. The laser unit is faulty. The potential measure
Jan 16, 2010 | Office Equipment & Supplies
Dec 10, 2009 | Office Equipment & Supplies
Error :
E732 code
Workaround :
Sep 09, 2009 | Canon imageRUNNER C3200 Copier
Washing Machines Logo
502 people viewed this question
Top Washing Machines Experts
