Question about Cutler Hammer Electrical Supplies
Have a cutler-hammer 210 responder drive inside the box is a relay marked NJ it is going bad how do I find the # to replace it THANKS
On a DC drive for a web printing press News King
  • 47 Answers
There should be information on the relay itself. Boettchers in Beloit handle Cutler Hammer (Eaton) products. You may be able to pull the relay and take it to them for an exact replacement.
Posted on May 10, 2014
3 Suggested Answers
  • 66 Answers
SOURCE: 20 AMP Cutler Hammer CH GFI wont fit in the breaker box
It will fit, the extra bump out on the back makes it a bit harder to hook the back locking tab before you push it on the bussing. Also, make sure no wires are in the way obstructing the bump out since it hangs out further than the standard breakers. The most common problem is the bump out making it hard to hook the locking tab onto the outer rail. Make sure the breaker is in the off position, then try holding it more flat as you insert it keeping it close to the bussing. This will help keep the extra bump out from obstructing the locking tab from hooking the back rail. Once it's hooked on the back rail you can push it on the bussing like normal.
Posted on Oct 10, 2009
  • 760 Answers
SOURCE: can i use murray in a cutler hammer
You should only use a breaker that is listed for use with your panel. Use of a breaker that is not either listed or classified for use in the panel is a code violation. Check the breaker to see if it will fit your panel (probably not) Murry is now Siemens I believe, and Cuttler Hammer is Eaton. There was a Murry-Cuttler Hammer-Challenger connection for awhile, but just because it fits doesn't mean it's ok.
Posted on Jul 04, 2010
How To wire a cutler-hammer A/C Disconnect Box 60amp-240V Non- Fusible
"LINE" is typically the incoming power.
"LOAD" is typically the outgoing wires to the machine.
Sep 19, 2014 | Cutler Hammer DPU222RGF 60 Amp Out A/C...
How to take apart cutler-hammer series B1 contactor
contactor itself replace it, to remove it from housing you should be to find some screws holding and just remove and replace. if you have the replacement already mark where the wires come from that u take lose
Jan 30, 2014 | Cutler Hammer Electrical Supplies
Bought a Eaton Cutler Hammer Arc Fault 15 amp Single Pole circuit breaker for my old CH20 model Cutler Hammer CB Box (vintage about mid 1960s). CB package says "Use in Type CH" boxes. It...
I used to run into that being a service electrician all the time Smains! These problems can involve a little more legwork to figure out than some. The best advice that I can give you is, if at that age you can still find a part number on the breaker panel (they renamed them load centers to sound fancy lmao), if you can actually fine a legible one. Write it down and go to Eaton's website, then to load center. They have a parts number search that should take you right to your PANEL lol, and all the specs. I'm not there or if do it for you, hope this helps!!!
Aug 18, 2017 | Cutler Hammer "CUTLER HAMMER" ARC FAULT...
Hi, I have the Cutler Hammer fusible ac disconnect 30 amp, my question is with the 10-3 wire from the fuse panel to the pullout do you only use the Black White and Ground and lay back the Red? Also, can...
If you use a white wire to carry a 120 Volt line it would have to be taped with either black or red tape both at the breaker box and your fuseable disconnect so the solution is to use the black and the red wire into your curcut breaker, the white and the bare ground both tie into the grounding post at the circut box and at the fuseable cut off, Yes the fuses are neccisary per code.. to eliminate a short or fault from traveling all the way back to the breaker box.. often times found inside the building the fusible pullout is attached to. check your local codes and regulations for more specific details.
Aug 09, 2010 | Cutler Hammer Fusible AC Disconnect Switch...
I have installed a fusible cutler hammer disconnect switch 30 A, 600V. I have connected the incoming wires at the bottom. Will it be a hazard to change the fuse inside the box if it is blown. I mean will...
It will be a hazard to some else who opens it someday thinking the hot wires are at the top. Best answer is to check you counties electrical code. My answer is no I wouldn't hook incoming wires to bottom lugs.
Jul 09, 2010 | Cutler Hammer Fusible AC Disconnect Switch...
I have a cutler hammer breaker box & my question is where do the white & ground wires go cuz the bars for them are not the same length one is on the left of the box & the other is on the right
Look at the how the bars are mounted within the box. The neutral wiring (white) goes to the bar that is insulated from the box metal, while the bar that is mounted directly to the box is for circuit ground wiring (bare). Hope this helps!
May 14, 2010 | Garden
I purchased a 60-Amp Cutler-Hammer Fusible Pullout Air Conditioner Disconnect to replace my older (over 20 years) one for my AC/Heating unit inside the house. Looking for a wiring diagram as I have 2-wires...
The two wires coming from the breaker box go to the terminals marked "LINE". The two wires going to your AC unit go to the terminals marked "LOAD".
Hope you find this to be very helpful. :-)
Mar 22, 2010 | Heating & Cooling
Electrical Supplies Logo
205 people viewed this question
Top Cutler Hammer Electrical Supplies Experts
Steve
Hippy_dd
Craig Butler
Craig Butler
Are you a Cutler Hammer Electrical Supply Expert? Answer questions, earn points and help others
