Question about Thermador PG304BS Gas Kitchen Range
How do I reinstall the door for my Thermador range?
When trying to move our range, the door came unhinged and we can't figure out how to put it back together. Suggestions?
SOURCE: Flashing Lights on Thermador Oven/Range
Posted on Jan 31, 2009
0 characters
1 Points
Looking for a discontinued backsplash for my Thermador PRG36 range -- part numbers PAG36EITH, PAG36EHSH or PAG36ELBH
I'm trying to get rid of a PAG36EITH that my contractor bought for our Thermador range, but it was the wrong part. I'm sure you've figured it out after 16 months, but if not let me know.
Feb 10, 2012 | Thermador Kitchen Ranges
How do I remove the oven door so I can replace the inner glass?
Open the door to the first stop or the vent location which is about 3 inches open. Lift up on the door, and it will disengage its lever stops and come out. Reinstall the same way, remember the location of the door lever stops (if moved) put in that location to reinstall back into the slots to drop down into the oven.
Apr 09, 2011 | Jenn-Air SVE47100 Slide-In Electric...
How do I put the oven door back on, it was accidently pulled off and the manual does not show how to put it back on. We can't figure it out. The manual had only one small picture showing parts nothing...
We did fix our problem the the Thermadore. Someone accidentally pulled the door off trying to pull it out from the wall during a remodel at our church. We couldn't figure out how to get it back on but i found the info i was needing. It is now fixed but thank you for your time..
Jan 08, 2010 | Thermador PRG364GLUS Gas Kitchen Range
The oven door won't close JGS968
The hinges are sping loaded Take the door off to see how much he bent it maybe you can bend it back or the screws can adjust it.
Dec 04, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Dcs oven door unhinged
easy to install the door,before to remove check it how exactly the position of the door its a clip typr,or get the manual to see the procedure,open the door,pull open then if u see the hinge we have small lock in the hinge u psh it up the lock then slowly close the door,be care bcoz the hinge is powerfull,if u close the door see the hinge how to remove the door.
tnx gerbee
Jun 23, 2009 | DCS RGS-305 Professional Gas Kitchen Range
2002 Thermador Gas Oven door - can't get back on after removal!
You have to get the tension off of the hinge and it will drop right in. The spring loaded arm on the door needs to be drawn back until you can (depending on the style) either lock the u-arm into the notch on the other side of the hinge, or put a small bolt through the aligning holes in the side of the hinge. Once you get the arm straightened out a bit and relieve the spring pressure, you should be able to sit it right in there. Be careful though, that spring is strong.
Oct 25, 2008 | Thermador PGR366 Gas Kitchen Range
Thermador professional
I had the exact same problem. I read someone else turned off the circuit breaker in the electrical panel.. so I tried that. Flipped breaker off for 30 seconds and then turned back on. Oven now works perfectly as before. Go figure??
Oct 19, 2008 | Thermador PG486GEBS Stainless Steel...
Thermador oven doors
I would call Thermador directly to see if they can help you. My oven door didn't have the proper restrainers, it cost 159 dollars for a repair person, and the proper restrainers. It's expensive, but it's a good deal over the life of the oven. Thermador has their own repair team. But if they can't send someone, then see if you can get the parts yourself.
They have told me that now, it shouldn't fall off. Unfortunately, when people take the door off, they often lose the pins that keep the hinges open (for installation) they also lose the retainers.
Oct 16, 2006 | Thermador PRDS484GGUS Gas Kitchen Range
Thermador PG304BS Gas Kitchen Range Logo
29 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
isaac johny
isaac johny
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
