Question about Garden
Replace chain sprocket on stihl 101 pole saw - Garden
  • 211 Answers
SOURCE: Stihl chainsaw
Hi
First remove the cover,air filter and the carburator.Then remove the gas tank cap and the fuel filter from inside of gas tank,at the end of fuel line.Take off the fuel line from the hole of the gas tank(at the top),replace the fuel line,put all back together and start the engine.
best regards savumihai71
Posted on Feb 14, 2009
  • 188 Answers
SOURCE: Remington Pole Saw Model # 106890-020 - Chain Oil Cap broke
Call Master Parts at 1-800-446-1446, or go online at www.masterparts.net. They have the part (107512-01) you need. I hope this helps...
Posted on Apr 27, 2009
SOURCE: Chain Saw, Stihl Model 011, cutting off
I've been messin with my poulan 2150 that was doing the same thing. Good, fresh gas, good spark,etc. I noticed whenever I loosened the fuel cap it would literally spray gas out! alas, I removed the muiffler assy and the darn thing fired up the first pull! I've got the muffler parts soaking in gas right now and I'm sure this the problem. It just makes sense especially if you use the same 'mixed fuel' can for weed eater, blower,etc. Check your's out, it could very well be your problem too! GOOD LUCK
Posted on Apr 29, 2009
  • 188 Answers
SOURCE: i can't seem to find a replacement chain for the pole saw
The replacement part number is a 10SC. You can contact Master Parts to order one. You can find them online at www.masterparts.net or you can call them toll free at 800-446-1446. I hope this helps...
Posted on Jun 04, 2009
  • 4088 Answers
SOURCE: I have a Stihl ht101 pole saw that is not oiling
Remove the bar and chain and run the saw. Does oil come out of the side port? If not, check the pump, lines, and in-tank filter. If ok, clean all the holes in the drive end of the bar including the small holes that pass oil to the chain slot. Compressed air helps here. Clean the chain slot. Oil the chain manually after assembly.
Posted on Sep 12, 2009
STIHL pole saw 101
Hi Little Bird
Chances are that the clutch needs servicing or replacement.
Here's a link that explains:
http://www.lilredbarn.net/Stihl-HT-101-Pole-Pruner-Clutch-s/29554.htm
Cheers
Jun 06, 2016 | Stihl HT101 Pole pruner
Stihl pole saw model HT75--Was cutting a limb and the chain stopped cutting--What is the problem?
Could be a few things.
1. Clutch slipping at engine end.
2. Drive shafts have become detached from drive or broken.
3. Clutch behind the drive sprocket on the cutting head may need tightening.
4. Chain too sharp/aggressive and is trying to cut too much and the stopping the chain.
5. Chain too tight.
Nov 11, 2015 | Stihl Garden
Power pruner sprocket removal
Which model pole saw? it does matter.
Oct 07, 2014 | Garden
Stihl pole saw chain turns but when I put it up against a branch the chain stops.
Sounds like the chain or chain sprocket may be worn out, though it could be clutch or driveshaft issues.
Jul 06, 2013 | Garden
Ht 131 chain does not engage
More information please. Where will the cain not engage in the bar sprocket or on the drive sprocket
Mar 25, 2013 | Stihl Hl Ht Km 87 90 95 100 101 110 130...
I have a stihl pole saw ht101. The saw starts fine and runs for a minute or two, then loses power. What ido I check?
If you mean the engine is losing power your more than likely have a restriction in the exhaust. The sut from the two stroke mix builds up and restricts the exhaust gases. Hence looses power. Happened to me lots of times
Aug 02, 2012 | Garden
Stihl 066 does not start. Replaced ignition module. Weak or no spark.
Are the poles on your flywheel blue? Are you using an open-air inline spark tester, or holding the plug against the cylinder and turning it over?
Jul 14, 2012 | Stihl Chainsaw 051 075 076 Drum Chain Saw...
REMINGTON POLE CHAIN SAW
The chain has to be tensioned when replaced. You lift the chain away from the bar about halfway and the tangs that run in the bar should just almost come out of the groove. There is a screw that extends the bar near where it attaches near the sprocket. adjust that with the bar mounting nuts not quite tight till the chain is tensioned correctely.
Sep 28, 2009 | Remington Electric Pole Saw
Garden Logo
144 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
