Computers & Internet Logo
chris walls Posted on Feb 17, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can I change settings on bt home hub 2.0
Change router settings
Jason Morris
Level 3:
  • Master 362 Answers
  • Posted on Feb 18, 2012
Jason Morris
Master
Level 3:
Answers
362
Questions
Helped
179593
Points
1276
  • Open Internet Browser
  • Navigate to http://192.168.1.254
  • Enter your password that you have specified, or the primary one generated when you got it and haven't changed yet (it will be on back of the router on a sticker), if you have forgotten you can reset the router by pushing the button then it will go to the one on the back sticker
  • Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
    How do I change my bt broadband username
    Telephone BT, and ask for their Help Desk, to get technical support. They can change your ID.
    2answers
    How can I recover the password for my bt homehub 2
    This page will show you where the default password is for all the BT Hubs. Where to find admin password BT Home Hub Help BT com Help If you need to reset the device as the password has been changed then look here How do reset my BT Home Hub to its factory settings Help BT com Help This will change the passwords to what are written on the BT Hub.
    Hi, I have an acer aspire 5535 and I am experiencing problems connecting to my TP-LINK router. After resetting the router and my laptop I can occasionally connect to the internet, however after a period...
    Had similar problem with a kindle and BT home hub - had to manually change the wireless channel on the router but couldn't get a channel that worked when the microwave oven kicked in.
    I had two kindles and 2 home hubs and came to the conclusion that some devices must be slightly our of calibration and will struggle to connect on certain channels especially if there are near by routers.
    In the end I changed my BT router for a Linksys and its been fine since.
    2helpful
    Connecting TLWR743ND to BT hub
    I spent ages trying to use tp- as an ap client. tried every setting I could think of. Then........ Changed wireless security setting on home hub 3 to use JUST WPA2 not WPA/WPA2 and all worked. Give it a go. :-)
    Bt Homehub 3 + dell 1450 wireless router asking for network key
    if the routor is wireless then the key is on the bottom or side of router. the ip address should be on it too and pass key to change the settings on the routher
    Iv got a BT home hub 2 cant get conections for utorrent even though opened firewalls
    There are ISPs that block utorrent. I found this explanation of how to do port forwarding on the BT home hub, though: http://portforward.com/english/routers/port_forwarding/BT/BTHomeHub/Utorrent.htm
    So, all I can suggest is to open the ports on your home hub as suggested above and to connect your computer straight to your home hub rather than to your CWR-854 (unless you actually have no such router and just picked that to ask the question under).
    It is possible that someone has decided that you should not use torrents (they slow down everyone because they actually have the nerve to use the internet) and they are associated with thieves. Not to mention that there are tons of legit uses for them,
    This could be someone in your ISP or your house. So do you have access to everything? You can poke around with telnet - can you access the ports on the other systems that utorrent accesses to make itself part of the network of systems that are downloading and sharing the torrent?
    But if one knows the ports it is easy to block torrent.
    If you have multiple routers that do nat, the home hub has to forward to your router, not to your system. So if your router is 192.168.3.12 and your system is 192.168.5.6, the BT home hub has to forward to the port on your router, on 192.168.3.12 , and your router has to forward to your system on 192.168.5.6. If the home hub tries to forward directly to your system (if you have multiple routers, which you might have because of the way you asked your question) then it won't work since your router hides 192.168.5.6.
    1helpful
    Bt home hub change my nat from strict to open
    you will need to change some settings on the router.
    reduce the MTU. If the MTU settings is1500 then change 1365.
    also you will need to open the some ports on the router.
    Click Here for more info
    D-link 2100AP as Client for X-box
    You need to disable the dhcp server on the access point. This will conflict with the bt router since it too has a dhcp server. Hope this helps
    Ive got a 40gb ps3 and a bt home hub wireless router how do i connect ps3 to computer ps ps3 is upstairs and pc downstairs
    look on the back of your home hub. there should be a Wireless Key in a Grey box. (BT Home Hub wireless settings)
    note the wireless key.
    go to your ps3. and turn it on log on ect. go to settings and down to network settings (right at bottom).
    (Im not sure of the next section because im currently on a network but it should be an option to find network).
    anyway you search for networks. should find your home hub.
    keep going right untill you have to enter any settings. and write your WEP Key (Not WKA). (wireless key from back of router).
    Grand Canyon Tech
    Grand Canyon Tech
