Question about Fujitsu fi-5750C Flatbed Scanner
Scan highlight turns black
When we scan in black & white, highlighted areas are showing black. Is there a way to prevent this and make the text visible?
How do I highlight words on notepad?
To highlight text permanently, similar to a highlighter on paper, use WordPad instead of Notepad. Find WordPad by searching on the Start menu or Windows 8 Start screen. In WordPad, first select the text you want to highlight, and then open the drop-down menu next to the highlighter icon, located near the font settings. Pick a color to highlight the text. After setting the color, merely click the highlighter icon to highlight selected text with the same color. Word 2007, 2010 and 2013 offer an identical feature, used in the same manner. Word also includes the option to click the highlighter icon first and then select text to highlight
How Do Highlight Text in Notepad eHow
Sep 30, 2015 | Samsung 10.1 Galaxy Tab 4 16GB White
I could not read messages with white letters on blue back ground pl suggest how to convert the text in black color
well did you try highlighting them? as the background is white and the writing is white, possiblity is that you cant see it because white on white = white?!?! amazing right, so if u highlight it you will be able to see them, if thats what your asking??
Mar 03, 2010 | Smith Micro QuickLink Mobile for Pocket PC...
How do i turn off the subtitles on my toshiba 36hf72 tv, without the remote
The subtitles in dubbed videos VCD/DVD the process to follow are :-
The closed caption feature has two options:
• Captions—An on-screen display of the dialogue, narration, and
sound effects of TV programs and videos that are closed
captioned (usually marked as “CC” in TV listings).
• Text—An on-screen display of information not related to the
current program, such as weather or stock data (when provided
by individual stations).
To view captions or text:
1. Tune the TV to the desired program.
2. Press MENU, and then press x or • until the CUSTOM menu
appears.
3. Press z or y to highlight CC.
4. Press x or • to highlight the desired closed caption mode, as
follows:
• To view captions, highlight C1, C2, C3, or C4 (C1 displays
translation of the primary language in your area).
Note: If the program or video you selected is not closed captioned,
no captions will display on the screen.
• To view text, highlight T1, T2, T3, or T4.
Note: If text is not available in your area, a black rectangle may appear on your screen. If this happens, turn the Closed Caption feature OFF.
To turn off the Closed Caption feature:
Highlight OFF in step 4.
Note:
A closed caption signal may not display in the
following situations:
• when a videotape has been dubbed
• when the signal reception is weak
• when the signal reception is nonstandard
PS: If you do not want to set these function & their commands can be entered via the buttons on the TV set. Using the remote is much easier to operate............ sodeep
Oct 08, 2009 | Toshiba 36HF72 36" TV
Black and white negatives produce scans that show too much contrast......any suggestions?
1) Decide which problem is the worst: shadows too dark or highlights too light. 2) Run your scan with Nikon 4 software tool "Digital DEE" adjusted for EITHER Shadows or Highlights (not both; Highlights setting will "trump" a Shadows setting, even though you have a non-default setting at all DEE sliders).  Generally good choices for Shadows are 39 to 55. (39 = lighten the shadows a little; 55 = lighten the shadows a lot.) Experiment; do several scans. Generally good choices for Highlights are about 17 to 42 for amount and about 4 to 30 for threshold. (17/4 = dim the highlights a little; 42/30 = dim the highlights a lot.) Again, you have to experiment to get some experience. 3) When in Photoshop PSD format (After first doing a Levels adjustment): Try using the Adjustments/Shadows and Highlights tool to AGAIN brighten your too-dark shadows and/or tone down your highlights. (I.e., the effect is cumulative on top of your Digital DEE effect. But Digital DEE is a more "magical" feature and is somewhat preferred to PS's Shadows and Highlights tool. DEE, however, will often produce an annoying "light smear" [bright area "dragged" into an adjoining darker area]. In case of a "light smear" from DEE, do not use the tool; too hard to fix.  Use PS's Shadows & Highlights tool instead.)  4) Proceed with other PS adjustments such as Curves, etc.  5) Still not satisfied?  Go to Levels again and look at your histogram. Is it really "stacked" to one side or the other (a mountain way over at the left or at the right)? You might want to try the rather severe command of Adjustments/Equalize.  This "spreads out" your pixels more evenly across the histogram. Note: this is a scary adjustment that requires misc fixes to tone-down certain aspects of the Equalization adjustment.  No free lunch, right? 6) After experimenting with the above tools, you should be able to get a handle on too-contrasty pictures. There will be a learning curve.
Sep 18, 2009 | Nikon Super Coolscan 5000 ED Film Scanner
On the viewfinder, parts of the picture flashes black.
It sounds like you have the display set to show image "highlights", this is a mode that shows parts of the picture that has become over exposed and have no detail contained within that area, in other words the parts of the photo that are pure white.
The camera Highlights as one of several different modes that can be flicked through after looking at a photo you have taken. hope this helps  Ian
Sep 07, 2009 | Nikon D60 Digital Camera with 18-55mm lens
When ever there is a picture taken there is a flicker when i view the picture in my camera it happens only on the bright spots ...ehy is it
It's normal.
The Nikon dSLRs have various LCD display modes, and one of them is called "highlight clipping warning display". Basically, when you set your LCD display to "highlight clipping warning display"(it's the mode right before the "histogram display"), it blinks white/black wherever your picture has blown highlights (i.e. where your picture is overexposed)
A histogram display is very helpful in telling whether you've got the exposure right, but to it isn't adequate by itself. With digital cameras, it's very important not to blow-out the highlights in a picture (they're similar to color positive film in that respect), since once you hit the maximum brightness, the image just saturates, and any highlight detail will be lost. A histogram display does a pretty good job of telling you how the image as a whole is doing, but what if there are just a few critical areas that you're worried about for the highlights? If only a small percentage of the total frame is involved, it won't account for many pixels. That means any peak at the "white" end of the histogram graph would be pretty small, and easy to miss (or just plain invisible). What to do? The folks at Nikon recognized this problem some time ago, and so have provided another special display mode on the D60 (as on most of their dSLRs) that they simply call "highlights," accessible via the Playback settings menu, under "Display Mode." This mode blinks any highlights that are saturated in any of the color channels. It does this by taking the nearly-white areas on the LCD and toggling them between white and black.
Aug 03, 2009 | Nikon D60 Digital Camera
When viewing photos some white areas blink black on the lcd.
This is becasue those flashing areas are over exposed highlights. Reduce you exposure compensation a stop to capture those white areas. Increase your shutter speed or use a smaller aperture (f-stop) to let in less light. When you loose highlight detail in a digital image it is hard to reclaim back on a computer program.
Jul 06, 2009 | Nikon D40x Digital Camera
Printing pdfs with highlighted text/shaded areas
That just means that you don't have a postscript enabled printer, or possibly you're using a black and white only printer. You might be able to print highlighted items normally on other printers, but will have to remove the highlighting to see the text on the one that you have. Alternatively, if removing the highlights isn't possible, you might try selecting all the text and then pasting that into a new document in a word processor or another similar program. If you do have a color printer, and need to print what you're seeing, you can arrange the document so that it is centered on your screen and then press: "Alt + Print Screen" at the same time. You can then open MS Paint or a similar photo editing program and paste ("Ctrl + V") the screen capture into the program.
Let us know if you need further help.
Hope this will FixYa!!!
Oct 30, 2008 | Adobe Acrobat 7.0 for PC
Nikon D40 - Flashing black on the light/white areas of inside & outside pics
It sounds as if you have changed the viewing setting so that the camera highlights over-exposed/highlight areas of the image.
While playing back images, press the multi-selector (4 way cursor) up or down to cycle through the various options.
This should be explained on page 51 of the cameras manual.
Hope this helps.
Matt.
Mar 04, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Fujitsu fi-5750C Flatbed Scanner Logo
52 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Chris Larocque
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
