Kenmore 92002 / 92004 Kitchen Range Logo
joe ford Posted on Nov 21, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Oven wont turn off
I have the kenmore super capicity with ultrabake system. 1 woke up one morning and noticed that the oven was on(top heating element was hot)but the unit was off.I tried to shut the power off to the unit and restart it but that did not work.when i flip on the breaker the top heating element gets hot all by itself,please help.
  • 1 more comment
  • dlalib Mar 14, 2008
    Kenmore oven model 977974890 won't shut off.oven elerment has bright red heat spot on right side
  • ajcastle Oct 19, 2008
    Our top heating element will not turn off unless we unplug the oven. When we plug the oven back in it turns on by itself.
  • Anonymous Oct 28, 2008
    I have the same problem. I was baking something at 425 degrees and then noticed that smoke was coming out of the oven. The temperature was definitely higher than 425 degrees. So I tried to turn the oven off and the heating unit continued to stay on. I tried unplugging the oven and then plugging it back in, but it didn't help. The oven will not turn off and the temperature is extremely hot (like it is in cleaning mode).
David Emmel
Level 2:
Sergeant:
  • Expert 295 Answers
  • Posted on Nov 21, 2017
David Emmel
Expert
Level 2:
Sergeant:
Answers
295
Questions
Helped
128297
Points
781
Turn off the power to the range and contact an authorized technician.You may have a fire producing issue.that needs immediate attention!
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
5 Related Answers
A
Anonymous
  • Posted on Oct 24, 2007
SOURCE: Error code E1 -F5- Broil element comes on and wont shut off
I just did the self clean option and when it was done I received the error code E1 -F5- and it does have to do with the door latch. After turning off the power to the stove I was able to open the door and wiggled the latch and that solved the problem.......
jessee007
JP Services
  • 310 Answers
  • Posted on Jan 01, 2008
SOURCE: Oven gives me an -F3- message and stops working
F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Anonymous
  • 5911 Answers
  • Posted on Feb 11, 2008
SOURCE: Kenmore electric range
The problem is caused by a shorted BROIL relay on the Electronic Oven Control board. I have experienced this problem before. The oven will continue to heat because it's being provided a constant power source. You are right to assume the reason for the oven temp error. This is common too.
Here's a TEMPORARY fix you can try:
1. Secure power to the range and remove the back panel from the console.
2. Unplug the BROIL element wires from the EOC and wrap them with electrical tape. It should be marked on the circuit card.
This will leave your broiler out of service, but you should be able to use the bake function. This should only be a TEMPORARY fix. The real fix is to replace the EOC. In the mean time, DO NOT leave the range plugged in while not in use (especially, if you are not going to be home, or while sleeping). This could be a definite fire hazard. If you post back with your model number (located around the oven door, or bottom drawer opening) I can give you an idea of how much the EOC would cost, and give you advice on how to replace it.
Anonymous
  • Posted on Sep 25, 2008
You need a new mother-board.
I had the same issue, it overheated my kitchen in a matter of minutes. If I didn't turn off the circuit-breaker, I probably would have had a fire - the heat being emitted was intense. The cost is running around $300. with tax and delivery. I'm not sure if I want to repair or purchase a new oven.
Anonymous
  • 725 Answers
  • Posted on Dec 11, 2009
SOURCE: I have a Kenmore Super Capacity with UltraBake
We have parts for your Kenmore range. You have a series of 3 numbers before the model number that's on your range. Those numbers tell us who manufacured your oven. Once we have this information, we call tell you which part you need to stop the E2 F3 error codes.
You may contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
from 7 AM until 7 PM CST Monday through Saturday and we can get you cooking again!
We look forward to working with you and getting you up and running again soon.
Thanks, Ella
1helpful
Kenmore Ultrabake GAS oven is trying to light but just clicks
Don't use this oven, turn off the gas and call a service techinican
I have Super capacity ultrabake system electric won't turn off.
I had this with my oven, it just kept getting hotter and hotter. Had to replace the whole control panel. Mine was a Kenmore but I suspect they are similar.
2answers
I have a Kenmore Super Capacity with UltraBake System. Model number 92004102. I keep getting error message E2 F3 and my oven door locks and my oven turns off. What does this earor message mean?
Thanks, Ella
1helpful
My whirlpool super capicity 465 does not heat when bake button is pressed. the broiler and stove top both work.
Your bake element is probably out. No biggie! We sell parts and will be happy to help you with this. Just call us with your model number. Hope this helps! Ella
Aug 18, 2009 • Ovens
2helpful
Water leak from washer
The element is likely failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
We have a Kenmore glasstop self cleaning electric range (super capacity w/ ultrabake)- not sure of the model # or year. We were baking and the heat suddenly went up on its own and we have a message EZ F3...
Sounds like bad control if it ran when it should have been off. Please contact me if you need further help and leave feedback. Thanks for letting me help you!
Kenmore ultrabake lights up when stove top is on but wont heat up
Hard to know...First thing I'd check is the power supply to the unit.  Turn off both breakers.  Check wiring all the way through for tightness.  Turn both breakers on.  Next, you'll need to check the elements for continuity...with the power off.
1helpful
EO F2 code
hi, this appears to be a fault caused by a short in your keypad - electronic range control (ERC)
this needs to be replaced unfortunatly.
To assist you finding the proper part your model numbel means that the oven is manufactured by Whirlpool for Sears/kenmore.
Microwave fan won't turn off?
hi i would think that the power problem has fried the processor
cheers grant
Top Kenmore Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
